Question about LG Televison & Video
Vertical green line
LG 50' Plasma TV has continuos visible vertical line in the middle of the screen. I did change channels and different inputs sources but the line still appears.
    Top Expert:
  • LG Master
  • 11,573 Answers
Probable board problem inside TV, solder joints are known to crack after a while on these control boards.
Posted on Jan 16, 2016
    Top Expert:
  • LG Master
  • 9,098 Answers
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
2 Suggested Answers
SOURCE:
Slinteriors
  • 8617 Answers
SOURCE: My LG 50' Plasma TV has continuos visible vertical line in the middle of the screen. I have tried to change channels and different inputs sources but the line still appears. It appears as a red verti
I will need the model number of your set to assist you with the most probable cause of the problem.
Posted on Dec 14, 2011
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
? 4:45
Jan 16, 2016 | LG Televison & Video
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Plasma TV with vertical lines
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
50" LG Plasma - Thin red vertical line in middle of screen
I work for a auth LG service center and each time I have had this symptom we had to either change what called the T_CON control board or the Plasma display panel itself. You need to cocntact LG @ 800-253-0000 report your problem and they will find a service center in your area you should have 1 year warranty parts and labor.
Feb 11, 2008 | LG 50PX4DR 50 in. Plasma TV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
A 12" high by 4" wide block of colored vertical lines in middle of screen
I have the exact same problem as sal1965. Does anyone know which circuit board may have a problem?
Aug 16, 2006 | Samsung PPM50H2 50 in. Plasma Television
Televison & Video Logo
579 people viewed this question
Ekse
RONALD CARTER JR
