Question about Kyocera Office Equipment & Supplies
Kyocera Taskalfa 400ci how to calibrate the color
I really need help please how to calibrate the color developer
  • 523 Answers
Under system menu. maintenance run color calibration and auto grad adjustment.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Apr 24, 2016
SOURCE:
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
sodeep
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
SOURCE: reset all originals in DP
reseat orignals on DP.
Posted on Sep 05, 2011
SOURCE: Free service manual with code
To reset -
C-TECH INFOWAYS
Posted on Nov 19, 2011
How do i fix error code C7103
you need to replace the magenta developer unit
Sep 03, 2015 | Kyocera Taskalfa 250ci Color Copier...
How to fix error code c 9540 for kyocera taskalfa 250
should not try to copy money!!!! you need to call kyocera they will help you or something
Aug 30, 2015 | Kyocera Taskalfa 250ci Color Copier...
Copystar c2300 error code
You first need to pull the fuser out and manually check that it is running smoothly. More times than not, it will be the fuser rather than the motor.
If the fuser is fine, locate the motor then turn the machine on and visually inspect. If the motor does not run before the code pops up then replace it.
/uploads/images/copystar-c2300-error-code-34884244-4-1.jpg
Dec 11, 2014 | Copystar Office Equipment & Supplies
Error code taskalfa 500ci , c3300
C3300, AGC Error. something in the copy lamp or optical section
Jul 08, 2014 | Kyocera Task Alpha 400ci / 500ci Yellow...
How do you clean the hard drive on a Taskalfa 400ci Kyocera machine
drill holes in it or purchase the data security kit. if you connect the drives (there are 2 in tandem) via sata cable to a mac or pc and format them they will not work in the copier anymore
Jul 03, 2014 | Kyocera Office Equipment & Supplies
Error Code C 7460 On Kyocera Taskalfa 8000i
Developer shutter locked - open front cover and slide the developer shutter to open/unlock, restart the machine. The shutter is locked to prevent developer spilling when transporting the machine.
Oct 30, 2012 | Office Equipment & Supplies
I got the 400ci color kyosera copier. installed the cartridges, waste basket, when i turn on the copier it gave a "c3100" message. please advise.
c3100 is an error associated with the scanner carriage. open your document feeder and check if the carriage cables are OK.
Jun 13, 2011 | Kyocera TASKalfa 180 Copier
Open Questions:
203 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Marvin
Marvin
Adorjani Laszlo
gggg
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
