Question about Tablets & eReaders
Neither port works to charge my prestige elite 10 tablet (wall charger or USB to computer) and the metal tongue inside main charger port is loose/broken &
  • 12,731 Answers
Your tablet's port is broken or malfunctioning. It probably needs to be replaced.
Posted on Mar 05, 2016
SOURCE:
Gort007
  • 1187 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Posted on Sep 03, 2009
Blondie Girl
  • 25 Answers
SOURCE: the place where i enter my charger has broken inside the tablet
That you would need to go either to where you purchased it to be repaired, or they will have to send it out to the manufacturer to be repaired. That is not something you can fix yourself. At least, I would not recommend you trying.
Posted on Feb 17, 2012
jasonnashjlu
SOURCE: Both Charger Ports Wont Take Charges
i can suggest you get a Duracell wireless charger which you just place your tablet on and it charges?
Posted on Nov 09, 2013
  • 717 Answers
SOURCE: can I use usb to charge it
Yes
Posted on Dec 12, 2013
yhgbwertg
SOURCE: My VIZIO Tablet 1008 micro USB charging port is looseand charging indicator comes on some times when I move the wires around. ow do I get to charge the Vtab?
Hi, you can buy new ones from here 2 pcs Replacement Micro USB Charging Port Connector for Vizio Tablet... and change it . take a look. enjoy
Posted on Nov 23, 2014
Charger fot my acer tablet only goes half way in and wont charge
The pin inside the charger port might be broken.
Look in the hole where you put the USB (on the device) there should be a tiny flat tongue sitting in the middle, if it's bent and touching the inside of the hole, it will need repairing. It's a very common fault.
You might be able to temporarily fix it yourself by trying to straighten it with a tooth pick. It's supposed to slot inside the micro USB plug.
Oct 20, 2016 | Acer Tablets & eReaders
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
I can't figure out how to charge the battery. I rec'd a AC wall charger but I can't figure out where to plug the male end in on the tablet
The charger plug should plug into the mini-USB port. This is the same port for the USB cable that would connect to the computer, and in fact the tablet can be charged from the computer if the computer is on.
Mar 23, 2015 | Tagital Tm 9" Android 4.0 Tablet PC...
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My prestige elite 7 tablet will not charge even when plugged into pc through usb chord.
Try using a USB charging cable that plugs into a wall socket (via adapter), rather than using a cable plugged into the computer. Computer USB sockets sometimes have lower power ratings and are insufficient to charge tablets.
(It is not clear if you have successfully charged on computer before or not). Also just try a new cable if you have not as they can become damaged (get one with a decent make - sometimes the very cheap cables and charges are poor quality and do not work well)
If none of that helps / you have tried it all please reply and I will try to help further.
Dec 07, 2014 | Tablets & eReaders
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit.
The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest.
First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method.
25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
Oct 18, 2014 | Trio Mach Speed Stealth G2 Tablet - Teal...
What charger can I use to charge tablet
That depends on the tablet.
Many tablets charge via the USB port, the power coming either from a computer's USB port or from a wall adapter.
If you require further assistance, please add a comment to this question and specify the make and model of your tablet.
Oct 12, 2014 | Tablets & eReaders
Is the only way to charge this tablet by plugging it into a computer?
Depend what model "this tablet" is. Generally tablet chargers have a USB connector at the wall plug end , plugged into the wall charger and a mini usb or proprietary connector at the tablet end. The USB connector can also be plugged into a USB port on a computer or other device. Charging rate will depend on how much current the device can deliver to the USB port, they are not all the same.
Aug 24, 2014 | Tablets & eReaders
Repair 2012 nexus 7 charger port
The micro usb charging port on the nexus 7 is notorious for becoming useless b/c cords fit loosely in the port right out of the box. Micro usb cords get wiggled and jiggled because of the size of the opening and then the port will no longer charge b/c solder breaks from the board, or the tongue inside the port partially breaks apart.
You can buy the replacement micro usb / headphone jack assembly for about $50 and do the repair yourself (hopefully) ...or you can send it to us and we\'ll replace just the jack and ship it back to you all for $54.95
More info and our repair form is on this page:
http://www.rockhoptec.com/services.php#t...
Mar 04, 2014 | Tablets & eReaders
Tablets & eReaders Logo
66 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
