Question about Saws
How do you remove the grinder assembly from the motor housing? Thanks.
  • 1,807 Answers
Please state the make and model. It will help an expert to answer your question
Posted on May 30, 2016
  • Veronique bourdais
    Veronique bourdais Jun 01, 2016
    It's a motomaster from Canadian tire, and it's called a spin saw. Comes with different attachments. Don't have al the info with me but will look. Thanks.
6ya staff
SOURCE:
How do I remove the gear from the gear housing assembly?
first grinding wheel > flange> safety cap > 4 screws >remove axis with drive shaft crown wheel > then 4 screws remove front with the armature if you must replace cone wheel and crown wheel. remove first the carbon brushes before take the armature out.
Dec 29, 2015 | Dewalt 4 1/2" Small Angle Grinder D28402
Kitchen Aid Burr Grinder
If the parts are not listed separately, the motor and gears are a completely separate assembly. A replacement motor (assembly) would include the gears
May 06, 2013 | Kitchen Appliances - Others
Milwaukee 6153-20 grinder is running extremely hot.
Your grinder is either working too hard because of broken or seized bearings or the fan is broken or detached from the armature. Take the brushes out then remove the four screws holding the gear housing on the motor housing. Remove the armature and check the fan and both bearings. If the armature bearings and fan are OK check the bearings and gear teeth in the gear housing.
Jan 31, 2013 | Milwaukee tools Milwaukee Tool 6153-20
Is there a fuse inside the grinder to protect it from an electrical surge. I accidentally plugged it into a 220 volt outlet.
My MDF was built in September 1993. It has a fuse inside a black cylindrical fuse holder on the electronics board that sits aside the motor. If you have a right-angle flat blade screwdriver, you can get the fuse out without removing the motor unit from the case. I didn't have the right tool, so I ended up removing the motor/grinder unit from the case to replace the fuse. The fuse is a 2A/250V Slow Blow. I used a Buss CDC-2A to replace the factory "5TT 2A/250V" fuse.
May 09, 2011 | Gaggia MDF Electric Burr Grinder
My grinder starts slowly and takes time to build up to speed. It is a model 612 and does not appear to be a capacitive start motor. All I can see under the base plate is a relay. Thanks for your...
Hi and welcome to FixYa, I am Kelly
Inside your grinder either the stationary switch or the rotating assembly that actuates the stationary switch has failed.
Download this pdf file:
http://www.baldor.com/pdf/literature/CA506_0806_WEB.pdf Then go to page 9
The rotating assembly is this part number: (most common failure)
34RS2060SP
You must remove the end plate / cap to change this part.
The statonary switch rarely fails unless the rotating assembly damaged the contacts when the rotating assemble failed. When the rotating assembly fails you often find a spring and flyweight loose inside the grinder during disassembly. Should your stationary switch have failed try and get a number off of it so you can get the right switch. Otherwise you have to use NEMA code / Body type numbers.
Thanks for choosing FixYa,
Kelly
May 06, 2011 | Baldor 612 6" Bench Grinder 3600 Rpm Stamp...
Display saying GRINDER
my machine does not say grinder block but it saying coffee bean holder is empty when it is full.
Aug 03, 2010 | Gaggia Titanium Espresso Machine
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
How to disassemble it to fix the start button, which fell into the machine
Just adding to dhelkamp's instructions (which helped me immensely!).
The front quantity knob kan be pulled right out - it's held in place by friction only.
The side knob has 3 latches holding it in place. Releasing 2 is sufficient. Use 2 small flat screwdrivers.
As for the assembly, there are 4 latches in the inner assembly holding it in place. The location of these latches can be seen by looking at the edge of the outer shell. The front latches are just behind the holes for the rubber feet, and the rear latches are just in front of the rear holes. Use a flat screwdriver to release one of the front latches, while pressing down on the outer shell - it should give way 1-2 mm. Repeat on each of the other 3 latches, whilst keeping pressure on the outer shell. The cover should easily slide off the grinder assembly. Beware of getting pinched!
Jul 26, 2008 | Krups GVX2-12 Electric Burr Grinder
Stuck motor?
bert, to get to the sump and chopper assy. First remove the lower spray arm by holding the top tab and turning the spray arm off. Next grab a hold of the rear feed and turn it to the right until it unsnaps from the rear feed assy. Now you remove the filter and accumulator assy. It has torq screws, remove and lift off. Now the chopper cover will be on the left, one torq screw and it will lift off exposing the chopper blade. This is probably where it's jammed. Look at the attached pics. It will help you. Catriver.
Jun 15, 2007 | Whirlpool GU1200XTLS Stainless Steel...
Saws Logo
592 people viewed this question
Top Saws Experts
Bill Boyd
Tom Chichester
ray gallant
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
