Question about Sharp Televison & Video
How can I copy a recorded disc and create another copy through my sharp dv rw 360 recorder ?
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 99 Answers
DVDxCopy if it's still available
Posted on Jun 14, 2016
    Master:
  • Sharp Master
  • 883 Answers
Why not just use some dvd copying tools to get a copy without a long time of waiting? Try Leawo DVD Copy which can copy within a short time.
Posted on May 16, 2019
SOURCE:
How do i select finalise on sharp dv-rw 250h remote control
If you are using the original remote or one which matches all of the functions, make sure that no DVD or VHS tape is being played and that the recorder is on. Make sure that there is sufficient space left on the disc. (The space needed depends on chapter/disc titles.) Then press Setup on the remote; it should be below the arrow keys but the position may vary. Use the Up/Down arrows to select System Setup and press Enter. Select Disc Setup and press Enter. Select Finalise and press Enter. Select Start with the Right/Left arrows and press Enter. Wait for the procedure to finish.
Note: only discs recorded on this particular device can be finalized on the DV-RW250H. On some other Sharp DVD recorders, the Disc Menu is accessed directly from the Setup menu.
I hope this helps.
Sep 20, 2016 | Sharp Televison & Video
Keep getting disc error c211 when dubbing from VHS to DVD on Sharp combo
Very interesting. It fails for me with DVD-R 16x discs, fair enough, but also with DVD-RW 2x discs, so what next?
Mar 08, 2013 | Sharp DV-RW340U DVD Recorder/VCR
Recorder works great but cannot play DVDs recorded from television on my computer. These recordings were made of several films over six hours on DVD-RW discs. I have Windows 7 and have tried all types...
Recordings made on DVD-RW discs cannot be played in other players, including many PC DVD-ROM drives; incompatible format. If you had recorded your TV/video material onto a DVD-R in the recorder, for example, then finalised the disc, it would work in your PC and any DVD player.
But since you used a re-writable video/data DVD, it won't work outside of the recorder - that's why you can't play it (or if it was written on your PC, your recorder won't read it - incompatible disc).
If you don't wish to finalise the RW disc (I don't recommend it - plus I wouldn't blame you for not wanting to do that), you could copy it from one recorder to another, unless your PC has a capture card - which allows the outputs of your DVD recorder to connect to the PC inputs. Using relevant DVD software (for example, ULead DVD factory), you may be able to 're-author' the contents of your recording, and create a DVD-R copy which WILL work in all players that way - use DVD-R (or DVD+R if your PC and other players allow that format) for 'permanent' video recording - use re-writable discs for backups, test recordings, temporary stuff, and PC data files. There are many inexpensive software programs available. Have a look sometime at your leisure. See what they are like.
Even if you could copy the DVD contents in a Windows program, regardless of the software used, there is no guarantee that the copy you make will work outside of the player and/or original recorder, because it would require a lot of time and effort to achieve, and unless you know what you're doing with the program, you could waste a lot of time (and blank discs) in the process - it only adds to the frustration.
I am glad to hear your recorder has no major faults at present - that's great. No expensive workshop repair cost headaches; just frustration with discs (especially if they become drink coasters).
DVD-RW is ideal for test video recordings and PC data, but is limited when it comes to compatible playback/usage outside of the device it was written/recorded on.
DVD+RW discs on the other hand, when titled/ top menu created, can be played on a PC or player without finalising. You can even direct copy a DVD+RW straight to a DVD-R - it works in most cases.
The upshot of this is you haven't lost anything, and with the exception of perhaps a few dollars for a pack of either DVD+RW, DVD+R, or DVD-R discs (any brand), it didn't cost a fortune. You can also retain any DVD-RW discs you have previously used.
The simplest and cheapest options are often the best ones.
Mar 24, 2011 | Panasonic DMR-ES10 DVD Recorder
Instructional manual for a Sharp DVD RW/recorder model number DV-RW370
Please click hear to download the manual for the DVD Recorder.
Please let me know if you require any further assistance.
Thanks
Mar 21, 2011 | Sharp DV-RW340U DVD Recorder/VCR
I need a manual Sharp DVRW550U DVD Recorder / VCR Combo.. when i record into the dvd it say that i cannot recorde into this dvd i already try so many diferent one and it say the same thing.. when i think...
I have three possibilities for you. One obvious answer would be that you are trying to record onto either a CD-R rather than a DVD-R, but I'm assuming that's not your problem. The second would be that you are trying to record onto a dvd that your recorder doesn't support (i.e. DVD-RW and your recorder only supports DVD-R). The final possibility is that the disc is a "dud." I have had this problem before and just had to try another disc. Good luck and let me know how it turns out, will you? Der Strom
Apr 02, 2010 | Sharp DV-RW340U DVD Recorder/VCR
Sharp DV-RW340U will not record new dvds, give error message :E24
ensure you are using DVD-R not DVD+R discs. if what you are attempting the record is copyright protected, depending on the protection, you may not be able to record.
Feb 08, 2009 | Sharp DV-RW340U DVD Recorder/VCR
Trouble recording to DVD - connections are not done right - Sharp DVD-RW340
I had to run from the RCA outs of my DVR into the inputs that are on the front right of the RW340...behind the little door.  Now I can easily record from live cable or from my Comcast DVR recorder.  Couldn't get it to work from the backside inputs.
Mine is just the DV RW340 (no U).  And yes, the manual is brutal.  We had to call tech support to find what disc will actually work in the darned thing.
Now my big problem is finding more 4x DV-R disks. Shoulda bought more when Comp USA was clearing them out a few years ago!
I have had great success with Dynex Model: DX-DVD-R25 discs.  And they play equally nicely on my Toshiba DVD player in the livingroom.   I have also given several away to people after I had transfered home videos to DVD and those people all had good results playing the discs that I made on my lowly Sharp Dv-RW340.
Sep 13, 2008 | Sharp DV-RW340U DVD Recorder/VCR
Copying video to dvd
1st, does it come with a driver...if it doesn't, just make sure it is installed properly in your PC, then you just need to install a dvd writing software in your PC e.g. NERO Pro (v7 or later)...then, all will fit in...
Jul 23, 2008 | Samsung DVD-R130 DVD Recorder
Disc error
I have this same problem so I called Sharp.  This model is  a little older.  When you buy the disks there is a number with an X after it.  If you buy the - R disk the number has to be 4X or less,  for the -RW it has to 2X or less.  Apparently they can still be bought at Office Depot or online.
Aug 11, 2007 | Sharp DV-RW340U DVD Recorder/VCR
Televison & Video Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
