Question about Tablets & eReaders
If the charging port for my zeiko 10 inch is broken,what other way can I charge
  • 5,459 Answers
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Posted on Jul 11, 2016
SOURCE:
  • 3 Answers
SOURCE: My charging port is broken or loose can't charge
have you tried any other cables i have had problems with loose cable connections that were fixed by a new cable
Posted on Sep 08, 2013
  • 508 Answers
SOURCE: My Samsung galaxy s3 charging port is broken, my screen is also cracked. Will i have to get my screen fixed in order to get my charging port fixed?
No, charging port can be repaired without having the screen replaced, you might want to consider this though, since they are already in there fixing the power connector they might as well fix the screen and save you the disassembley charge next time. Up to you though
Posted on Mar 17, 2014
  • 9 Answers
SOURCE: I have an XO tablet for my kids but they've broken
Hi Johhnie,
To repair a charging port you will need the following:
  • fine tip soldering iron (Weller 15 watt)
  • Dremel tool with cut off wheel
  • De-soldering Braid
  • Torx T5 screwdriver
  • small flat bladed screwdriver (optional)
  • Diagonal cutters
  • small hemostat or fine tweezers
  • Panavise, helping hands or similar bench top holding device.
Take off the back cover and remove the battery.
Next, whip out that Torx T5 and remove the screws holding the phone together. On this one, there were only four to remove.
With the screws out, gently pull the phone apart. The lower half of this Motorola clips together, so I gently worked around the edges with a small flat screwdriver until it came apart.
The SIM card board easily separates from the phone via the flat SMD connector. Just gently apply pressure near the connector and it comes right off.
Next, the flat ribbon cable needs to be detached in the same manner, and the main PC board removed from the phone. It should pull right out once the cable is disconnected.
As you disassemble the phone, put each of the pieces into a parts bin. Any sort of container will do, but I'd avoid a static generating plastic Tupperware container.
Carefully place the board in your clamp/Panavise/whatever - I had to line up the buttons with the slots in the vise, or I probably would have damaged them when I clamped the board
You'll need a new connector before you can fix anything.
In order to check the condition of the pins, clip the two tabs that hold the rear shielding on to the connector with a pair of diagonal cutters.
With the rear shield removed, we can access the rear pins - Unlike the front, everything looks pretty good. The advantage of surface mount parts is that they don't require much solder to hold together. Unfortunately, when you're replacing a surface mount part, a small amount of solder can keep you from removing the part without damaging the board.
To keep from burning this foam seal, peel it back and stick it off to the side.
Enter the rotary tool. Sliced the top off of the connector by cutting the sides lengthwise.
Next, cut across the center of the connector. The bent pins should be gently cut loose and the upper half of the plastic connector will probably fall apart. The shielding on the sides should be cut to allow each leg to be removed individually. (Be careful not to cut the PC board below!)
Working from one side to the other, heat up the solder pad on each pin. Then use some tweezers to grip each pin of the connector. (I used a small pair of alligator forceps) If the solder is hot enough, the surface mount pin should come loose with little to no force. It's vitally important to be as gentle as possible with each one. The solder pads on the PC board are very delicate, and easy to pull up if you're not careful. Unfortunately, overheating the pads can also cause them to pull up. So be quick about it!
With the delicate pins out of the way, I carefully cut apart the remaining plastic and removed it.
Finally, the remaining legs of the shielding were heated and removed from the board.
After the new port is aligned (double check the pins in the rear!) solder one of the shielding legs to the board. Double check the pin alignment again, and solder the other legs. Now the port should be solidly mounted.
Next, the pins on the new port need to be soldered. The super fine tip on my 15 watt Weller pencil made this easy. Alternatively, you can use a wider tip to solder things and go back over the pins with de-soldering braid to remove any solder bridges. If you forgot to remove the rear shield, you'll have one hell of a time soldering the pins. On this particular phone, the metal shielding behind the port made it impossible to access the pins without removing the rear shielding.
Regards
Martin
Posted on Jun 19, 2014
mileso
  • 3324 Answers
SOURCE: The charging port is broken off, will the pad still charge wireless?
No. The wireless charger has to connect to the charging port via an add on cover on the device. Powermat Wireless Charging Pads from Duracell
Get a new tablet.
Posted on Mar 11, 2015
vaibhavnath
  • 72 Answers
SOURCE: the charging port hub on my 7 inch tablet Android operating system RCA model numberRCT 6378 w2 DC charging port is broke how to replace how to get the part for the replacement thank you
buy it from the online hub like ebay, or lookout for it in the local market.
Posted on Mar 19, 2015
Battery port
Depending on how hot you may be right. It is normal for the battery to heat up when you charge it. I have an RCA tablet that while the charge port (which doubles as the micro USB) fits tight and the battery still heats up to the point where it is hot to the touch but not to hot to hold. If your charging port is broken then the tablet will nont charge at all. If it is loose and not getting good connection then the battery will charge intermittently. Again either of these issues will not cause the battery to get abnormally hot. However, if there is an issue with the battery itself then it may get too hot. If so the charging circuit thermistor should cause the battery to stop charging.
Aug 24, 2016 | Tablets & eReaders
Port on 10 inch tablet not working can it be fix
Linda, if it is the charge port, mini USB, yes they can be fixed or replaced by cell phone/computer repair shop.
Check the attached links videos showing port replacement. Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Android tablet charging port fix
Toshiba Tablet AT300SE AT305SE Charging Port Repair
Samsung Galaxy Tablet 10 1 Tab 3 10 1 P5200 P5210 Micro USB Port Replace HD
May 03, 2016 | Tablets & eReaders
Why wont my kendle modle no do1400 hold a charge
Does the kindle work when you have it plugged in? It could be that the charging port is broken. These models are notorious for broken charging ports.
Jul 16, 2014 | Amazon Kindle Wireless Reading Device
How do I fix my nexus 7 charging port
If the port is broken and you only need it for charging the device, consider getting a wireless charging accessory instead:
Finally charging for our multi device world
Jul 13, 2014 | Google Nexus 7
Power port broken
you can charge it through USB from any laptop or multichannel charger, if it's 7 inch or 10 inch you can use any charger for car toys for kids it will work fine.
Jan 13, 2014 | Tablets & eReaders
Thecharging port on my Toshiba tablet is broken, is there any other way to charge it?
I'm afraid there's no other way. Is there a physical damage on the charging port as evidence that you're saying it's broken? It might be the charging cable itself (hopefully).
Sep 22, 2013 | Toshiba Tablet. Excite 10.1 in. Android...
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
Aug 09, 2013 | ZEEPAD 7 inch Android 2.2 Tablet
Tablets & eReaders Logo
52 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
