Question about Parrot Cell Phones
Parrot car kit is stuck on good bye screen.stays on all the time even when key is removed ....any ideas .many thanks
    Habit-Forming:
  • 39 Answers
You could try remove the fuse and let it sit without any power to it for about 30 seconds that should reboot it and remember there is two power wires one for memory and one for ignition on the ignition power wire is disconnected when the key is off but the memory wire is the one you need to find if you can get to the main control box you can just unplug it for about 30 seconds and that should do it
Posted on Sep 20, 2016
5 Suggested Answers
SOURCE:
SOURCE: 3200 LS installed in '07 Chev Sub-Parrot Won't Power Off
try switching the red and orange wires. one is constant and one is switched. you can try by just reversing them at the inline fuses. hope this helps.
Posted on Jan 03, 2009
  • 5 Answers
SOURCE: Unable to pair Nokia N85 to Parrot car Kit
It's possible that you need to reset the parrot - seems it might only accept pairing with one phone. On mine you hold down the red and green keys together until she tells you that she is clearing the memory, then she prompts you to pair your phone
Posted on Jul 05, 2009
dancandoit
  • 436 Answers
SOURCE: New Nokia 6700 phone cannot find the right pass
1234
Posted on Jan 11, 2010
  • 95 Answers
SOURCE: fitting hands free car kit Parrot CK3000 Evolution
Just make a look:
http://www.parrot.com/uk/support/onlinehelpguides/parrotck3000evolution
Posted on Mar 26, 2010
Parrot ck3100 stuck on goodbye screen any way to reset it ,thank you
Found this on the net, not sure if it works or not:
"Hard reset the CK 3100 by pressing all three buttons for two seconds and then pressing them a second time (warning initializes factory settings)
2. hard reset thisback to factory settings"
Straight copy paste out of fixya website
and the link to the source:
Parrot CK3100 Bluetooth car kit hard reset
Oct 08, 2016 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Wont switch off even when key is removed from ignition
Check the 12v supply to the red (permanent) supply & the orange (ignition supply) if the orange is staying 12v with the key turned off then you must seek a 2v supply elsewhere. What car is the kit installed into?
Feb 28, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How do i pair my blackberry with parrot 3200 ls, asking for numeric key
The first time that you switch on the 3200 LS-Color, you must pair your mobile phone with the kit.
1.Enable the Bluetooth mode on your phone.
2.On the hands-free kit, scroll through the menus until you come to Settings Pair with phone and select the relevant option for your phone. A 4-digit PIN code then appears on screen. Memorize it.
3.Then from mobile serach the 3200 LS-Color device
Once the search has finished, "Parrot 3200LS / Parrot 3400LS" is displayed on your phone.
4.Select the kit. Your phone prompts you to enter a code: key in the code shown on the kit screen and confirm on your phone.
5.The kit's screen displays "Pairing".
6.Once the data has been exchanged, "pairing successful" appears on the 3200 LS-Color.
Thank You
Oct 08, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Hi I have a parrot hands free kit which was
You can purchase a special adaptor lead to allow the parrot to just plug in to the back of the radio, this is called a SOT lead, do a web search and you will find the right one. Try autoleads or kram are good manufacurers.
Jun 17, 2010 | Parrot Hands-Free Car Kit with LCD Display...
Parrot ls3200 displaying goodbye
Good bye appear when the car kit switch off. Then suppose to be in relation with the question of the 12 ignition. If it doesn't disconnect of switch off in relation with the car, maybe the kit has a 12 DC and not an ignition connected.
If you can disconnect the power supply of the kit, just do it, and it should normally coming back to the main screen.
Mar 20, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Feb 11, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My parrot CK3100 flickers when i turn on the contact...when I turn of the contact it stays flickering and my cars battery dies...
First, you will have to ensure that the install may taking account of the specificities for some vehicles.
(Ex: in some cars, the 12dc red and the 12 ignition orange are inverted.
You can see it when you switch off the ignition key, it should appear good bye).
In that case, the product is still on and then this may explain the trouble.
But it may be also in relation with wires trouble between the box and the screen.
Feb 07, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Dec 27, 2008 | Parrot 3200 Ls Color Handsfree Bluetooth...
Cell Phones Logo
586 people viewed this question
Top Parrot Cell Phones Experts
donny ardalando
donny ardalando
ray gallant
ray gallant
Marvin
Marvin
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
