Question about The Watches
I have a GC 20500 and need to replace the crown. Not sure what type to order. Thanks
Silver, blue face
    Top Expert:
  • The Master
  • 11,573 Answers
Eric, pop into a local jewelers, they may have the correct part or order it and make repair reasonably.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Posted on Aug 27, 2016
6ya staff
SOURCE:
Add 18K to Stainless EBel Discovery.
this can be done at ebay sir.
you need not pay anything extra.
but it will consume some time for you for getting it done in a effective manner.
Jul 29, 2008 | Ebel Discovery 9172321/0665P Wrist Watch
How to set time on a Gc mens watch x7 series
Customer Service - Gc Watches
gcwatches.com/en/service/
Gc Watches Customer Service. ... Make sure not to activate the time-setting crown and/or the pushers while the watch is under water. Cleaning. Do Use a soft ...
[PDF]GUESS Watches - Rackcdn.com
fe1299bd296a03009be3-3739e7c3010127be61fd7a8237f120ed.r81.cf5...
BEFORE USING THE STOP WATCH, reset the stopwatch hands to the "60" .... 13MeNS. Congratulations on owning your new GUESS Watch. Developed from ...
[PDF]WARRANTY/INSTRUCTION BOOKLET - Rackcdn.com
Dec 28, 2015 | Watches
GUESS I HAVE A 3000 GC COLECTION HANDLE IS BROKE WHERE CAN I FIX IT
Take it to your local jewellers or watch makers, or even a shop that stock them. It is a readily available part. You may need the stem aswell as the crown
Oct 01, 2013 | Guess GC Collection watch
CROWN-STEM WILL NOT STAY IN PLACE
possibly you will need to clean around the threaded part of the case (pipe), when screwing the crown down push against the case and rotate gently back and forth until the crown catches the thread.
Jan 01, 2018 | Watches
How do I set a Danbury pocket watch with date display
If it is this pocket watch, then the crown (the bit you turn to wind the watch) has 3 positions. Position 1 is when the crown is pushed in all the way. Position 3 is when the crown is pulled out as far as it will go. In between position 1 and position 3 is a place where the crown will stop, this is position 2.
To set the day of the week, pull the crown out to position 3 to set the time. When you set the time, the bottom dial with also turn to set the hour on the 24 hour clock, if you turn the crown enough to cycle through a whole day the day of the week dial will also turn. Keep turning the crown until the time is set on the proper day of the week.
To set the date, pull the crown out to position 2, and turn it clockwise until the hand on the date dial points to the correct date.
Hope this helps!
Sep 01, 2012 | Watches
Can I get a crown replaced without sending it back to the company? This is my second time.
A local watchmaker can do it. If he doesn't have a crystal in stock that fits, he can order it for you. It usually does not have to go to the factory. If it's just scratched - even badly - it can possibly be polished to an acceptable finish.
Apr 12, 2010 | Kenneth Cole Men's - WIDE SILVER FACE LINK...
How do you change the date on gc watch? product code is I47000G1. Thanks
again, like most other watches, pull the crown to the first position and turn clockwise or anti-clockwise, it depends which movement is inside the watch (in the second position you can set the time)
...shouldn't be so tricky....
Mar 12, 2010 | Guess GC Collection watch
Fossil Fs 4296
Yes, your watch definetely needs a new battery. Find your nearest watch repair shop and ask to replace battery. Your watch will tick as brand new.:))
Jan 08, 2009 | Fossil Rectangle Silver FS4296 Watch for...
I have a seiko flight watch, unknown of the model, second hand doesn't reset
I guess the blue faced SEIKO is a Flightmaster (Model: 7T92- OCFO)and it is a great watch. This is a common problem with most chronographs and this happens due to misalignment with usage.
All you need to do is pull out the locking crown all the way out (2nd Step) as if setting time. and then press and hold the top / left button and at first the milli seconds hand resets. after which you have to press the borrom / right button to move the seconds hand in to place. and then reset the time and lock the crown. You can repeat this for Milli Seconds, Seconds, Minutes & hours hands.
Hope this helps,
Krishna Chaitanya GT.
Apr 27, 2008 | Seiko 0512039FA Wrist Watch
Watches Logo
Top The Watches Experts
 Larry
Larry
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a The Watch Expert? Answer questions, earn points and help others
