Question about Apple iPad 32 GB WiFi Tablet PC
I WANT RESET SECURITY PASSWORD - Apple iPad 32 GB WiFi Tablet PC
Remove iCloud lock from iPad
I am not aware of an ' iCloud Lock '. If you mean the user set passcode, the only way is to do a Factory Reset.
iCloud has a password, and that is the same one you use at the App Store. That has to remain in place to protect your credit card use. If you have forgotten that password, you can click Forgot Password link and a reset will be emailed to the email address associated with your iCloud/iStore account.
May 03, 2016 | Apple iPad 4th generation
Forgot password. How can I reset my Apple account?
From Apple:
If you forgot your Apple ID password If you're having issues signing in with your Apple ID password, use these steps to reset it and regain access to your account.
Your Apple ID is the account you use for everything you do with Apple, like shopping the iTunes Store, signing in to iCloud, buying an app, and more. To reset your password, you'll need to know the email address for your Apple ID. If you're not sure which email address it is, there are a few ways you can find your Apple ID.
Reset your password
After you reset your password
Get more help Reset your password You can reset your password when you go to your Apple ID account page and click Forgot Apple ID or password. Enter your Apple ID, then click Next.
After you enter your Apple ID, there are a few ways you can change your password:
Answer your security questions
If you know the answers to your security questions, select "Answer security questions" and follow the steps to reset your password.
Use email authentication
If you select "Get an email," we'll send an email to your primary or rescue email address that you can use to reset your password. Didn't get the email?
If you use two-step verification
If you set up two-step verification, you can use it to change your password. You just need a recovery key and a trusted device. Follow these steps:
  1. Enter your Recovery Key.
  1. Choose a trusted device. We'll send your device a verification code.
  2. Enter the verification code.
  3. Set a new password and select Reset Password.
If you permanently lost your recovery key or access to your trusted device, you can't change your password.
If you use two-factor authentication
If you have two-factor authentication, you can reset or change your password from your trusted iPhone, iPad, or iPod touch when you follow these steps:
  1. Go to Settings > iCloud.
  2. Tap your name.
  3. Tap Password & Security.
  4. Tap Change Password.
  5. Enter a new password.
These steps will work only from a trusted device with a device passcode enabled. If you don't have access to a trusted device, you can reset your password when you follow these steps:
  1. Go to iforgot.apple.com and enter your Apple ID.
  2. Enter your trusted phone number and click Continue.
  3. Enter the verification code that we send to your trusted phone number.
  4. Provide any additional account information requested.
  5. Choose your new password.
If you can't sign in, reset your password, or receive verification codes, you can request account recovery to regain access to your account. Account recovery will take a few days, depending on what account information you can give. After you reset your password After you reset your password, you'll be prompted to sign in again with your new password. You also might need to update your password in Apple services and on your devices. Get more help If you're still having issues signing in with your Apple ID and password, make sure that you're entering the correct Apple ID. In most cases, your Apple ID is also the primary email address of your Apple ID account. If these steps didn't help you change your password, contact Apple Support.Last Modified: Feb 19, 2016
Feb 15, 2016 | Apple iPad 32 GB WiFi Tablet PC
FORGOTTEN PASSWORD. HOW DO I RESET
You cannot reset it without the original password. That is why we have security passwords on our devices.
Jan 14, 2016 | Tablets & eReaders
Reset my password
  1. Go to My Apple ID and select "Reset your password."
  2. Enter your Apple ID, then select Next. If you don't remember it, choose Forgot your Apple ID.
  3. After you enter your Apple ID, there are three ways you can reset your password. Choose an option below:
  • Answer your security questions. Use these steps if you know the answers to your security questions.
  • Use email authentication. We'll send you an email that you can use to reset your password.
  • Use two-step verification. If you set up two-step verification, you can use it to reset your password. You just need your recovery key and a trusted device.
Dec 02, 2014 | Apple iPad Tablets & eReaders
My mini ipad is disabled connect to iTune
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Connecting to iTunes, only works if you had it installed on your computer and made a backup on the PC. If you know the password belonging to the Apple ID o the screen, you could try entering that.
Or perhaps you try this site?
http://www.wikihow.com/Reset-a-Forgotten-Password-for-an-iOS-Device
Jul 27, 2014 | Apple iPad 32 GB WiFi Tablet PC
I can unlock my iPad its disabled in it say to connect it to iTunes but I want to can I reset it without connect it to iTunes cause I don't have a computer to do it.... If I can reset it to unlock it is my...
Perhaps you even could try this? How to Reset Forgotten Password for an iOS Device
Jul 21, 2014 | Apple iPad Tablets & eReaders
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
How can I reset my FaceTime birth date info
To set birthdate tap settings,tap FaceTime and make sure set to on.Tap apple Id then view account.Enter apple Id password then enter.Under security info tap manage apple Id.Enter password again then signin.Tap password and security ,then answer both security questions then tap continue.At bottom edit birthdate then tap save.
Aug 31, 2012 | Apple iPad 32 GB WiFi Tablet PC
Apple iPad 32 GB WiFi Tablet PC Logo
96 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
