Question about Amazon Kindle Fire HD
Does not hold charge and will not connect to wireless connection.
    Novelist:
  • Amazon Expert
  • 231 Answers
Battery shouldn't go bad this soon but you may have gotten a bad one. Try again with a new battery.
Posted on Oct 16, 2016
SOURCE:
My Amazon Kindle is not able to connect to the wireless network.
Hi there, you are facing a technical issue into your Kindle device. It is the most common error which can be fix through restores settings. If you still getting the same issue after doing restore than you probably need to call at Amazon kindle support technical team. They will fix it without any charges from their hand.
Dec 09, 2016 | Amazon Tablets & eReaders
How to enable wifi only
  • First, tap on your Settings app (or icon if you have a shortcut on one of your home screens). It's the one that looks like a cog or gear. This will bring up the Settings menu.
  • On your Settings menu, tap on Wireless and network.
  • You should now see a list of wireless-related menus. Tap on the Flight mode - also generally known as Airplane mode - to disable all wireless connections. You'll know it's working because you get an airplane icon on your notifications bar.
  • Great, now you won't be getting any incoming calls. But wait! Now your Wi-Fi connection isn't working, either. Nice going, Jason, you regular Einstein. Hold on your horses, though, because we're not done yet. On that same wireless submenu, tap on Wi-Fi settings.
  • Click the option to Turn on Wi-Fi.
  • Look at your notification bar on your home screen again. You'll still have the airplane icon on, indicating that you won't get any calls. But you will also start seeing a Wi-Fi signal icon. Voila! Now you can connect to a Wi-Fi enabled router or hot spot without worrying about getting roaming charges.
Oct 06, 2015 | Samsung 10.1 Galaxy Tab 4 16GB White
The charging port is broken off, will the pad still charge wireless?
No. The wireless charger has to connect to the charging port via an add on cover on the device. Powermat Wireless Charging Pads from Duracell
Get a new tablet.
Mar 11, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
How do get wi-fy on my tablet?
It's a good idea to access Wi-Fi whenever possible to avoid data charges. After you've activated the Android tablet's Wi-Fi radio, you can connect to an available wireless network. Obey these steps:
  1. Open the Settings app.
  2. Choose Wi-Fi.On some Samsung tablets, you find the Wi-Fi item on the Connections tab. Choose Wi-Fi to view a list of available Wi-Fi networks on the right side of the screen. Otherwise, the list shows up full screen.
  3. Choose a wireless network from the list.When no wireless networks are listed, you're sort of out of luck regarding Wi-Fi access from your current location.
  4. If prompted, type the network password.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
  5. Touch the Connect button.
    The network is connected immediately. If not, try the password again.
When the tablet is connected to a wireless network, you see the Wi-Fi Connected status icon. This icon indicates that the tablet's Wi-Fi is on, connected, and communicating with a Wi-Fi network.
Some wireless networks don't broadcast their names, which adds security but also makes connecting more difficult. In those cases, touch the Add icon. This icon might also be labeled Add Wi-Fi or Manually Connect. To make the connection, type the network name, or SSID, and choose the type of security.
You also need the password, if one is used. You can obtain this information from the girl with the pink hair who sold you coffee or from whoever is in charge of the wireless network at your location.
  • Not every wireless network has a password. Still:
  • Be careful when connecting to a non-password-protected network. It's possible that the Bad Guys can monitor such a network, stealing passwords and other information.
  • Some public networks are open to anyone, but you have to use the web browser app to find a login web page that lets you access the network: Simply browse to any page on the Internet, and the login web page shows up.
  • The Android tablet automatically remembers every Wi-Fi network it has ever been connected to and automatically reconnects upon finding the same network again.
  • To disconnect from a Wi-Fi network, simply turn off Wi-Fi.
  • Use Wi-Fi whenever you plan to remain in one location for a while. Unlike a mobile data network, a Wi-Fi network's broadcast signal has a limited range. If you wander too far away, your tablet loses the signal and is disconnected.
Oct 29, 2014 | Nextbook Premium 8 Se Android
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
Oct 09, 2014 | Worryfree Gadgets 7inch Zeepad 7.0 Android...
Google support
Make sure device is fully charged. Try connecting to an open wifi access point (without password) to eliminate possibility of using the wrong password for a secure connection.
Sep 02, 2014 | Google Nexus 7
Kindle won't turn non
Try these:
Reset the Kindle
Hold down the power button, or hold the power slider to the right, for at least 20 seconds. Then release the power button or switch, and push it again to turn on the device. If that doesn't work, hold the power button or slider for up to a minute, then release it and try to turn on the device.
Is there a power issue?
When you plug your charger into the Kindle, the LED should turn yellow if the device is charging and green when the device is fully charged. If the light doesn't turn on at all, it definitely signals some kind of power issue. Replace the charging cord if possible.
The Kindle uses a micro-USB connector, the same as most mobile phones. Try changing the cord or if that doesn't help, try another power source - a different charger, or connect it to a USB port on your computer. Finally, gently wriggle the adapter where it enters the Kindle. If the charging port has come loose, this movement may cause the port to realign and the LED to illuminate.
Aug 04, 2014 | Amazon Kindle Wireless Reading Device
I cant get wifi connection on my kindle hd
Step 1: Remove any old connections in the Tablet by Long Press Forget Connection
Step 2: Reboot your Wireless Router
Step 3: Attempt to connect again
Step 4: If this fails, log into the Wireless router and charge the authentication mode from whatever you have now to WPA Personal and enter a Passphrase you can remember
Step 5: Connect to your Wireless using the new Passphrase
Apr 07, 2013 | Amazon Kindle Fire HD
Battery will not charge
Follow these steps if the Kindle battery is not charging:
  1. Connect Kindle to a different outlet.
  2. Verify the charge light at the base of the Kindle is on.
  3. Restart Kindle by pressing Home > Menu > Settings > Menu and select "Restart." Is the charge light on? Contact Customer Service.
  4. Is the charge light off? AC adapter needs to be replaced.
  5. Contact customer service for in-warranty options.
Follow these steps if the Kindle Battery is not holding a charge:
  1. Turn wireless off and fully charge your Kindle.
  2. With wireless turned off, Kindle battery life should be:
    At least 7 days
  3. If battery lasts less than the time frame given above, contact customer service.
If none of this helps, or you need to contact Customer Service here are the numbers:
In the United States: 1-866-321-8851 Outside the United States: 1-206-266-0927
Thank you.
Mar 03, 2011 | Amazon Kindle Wireless Reading Device
I cannot connect to the internet. My wireless connection says that it is connected to my wireless hub. All other computers in the house hold are connecting to the internet wireless, so it is not a wireless...
Do you have anti-virus installed? You may have a virus that prevents you from surfing the net.
Also check if you are getting an IP address. Go to start>run>type in cmd and press enter. On the command prompt(black screen) enter in ipconfig and see if you have a IP address
Jun 03, 2010 | Toshiba Portege M200 Tablet PC
Amazon Kindle Fire HD Logo
29 people viewed this question
Top Amazon Tablets & eReaders Experts
Norman Worley
Miguel Luiz Martins
Poul Brinchs Larsen
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
