Question about Samsung PN51E530 51-Inch 1080p 600Hz Plasma HDTV
How to fix vertical lines on Samsung plasma TV?
Model # PN51E530A3F. 2-3 inch wide band of coloured vertical lines from top to bottom on right side of screen. Lines are not intermittent and present regardless of input source. Lines are on top of menu screens.
  • Samsung Master
  • 1,682 Answers
Posted on Oct 16, 2016
3 Suggested Answers
6ya staff
SOURCE:
vinhson65
  • 257 Answers
SOURCE: Screen shows several horizontal and vertical lines.
Press the menu on the TV and let me know if the menu is effected. If the Menu if effected , you can try unplugging the power cord for a minute and replugging it back. If the issue still persists , a physical diagnostic is necessary to determine the exact defective part on your device. It could be a problem of main board or even worse, the panel.
Posted on Aug 14, 2009
roety
Eric Rotmil
  • 587 Answers
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Hi have a samsung 42 inch plasma, all of a sudden it has a band 20cm wide of dotted lines going across the whole screen, some channels or when playstation in use the band gets wider, does not seem to...
if the band is horizontal your tv has bad y-buffer board. Usually there are 2 buffer boards- top and bottom. if the problem is in the top half of the screen replace the top board, otherwise replace bottom board.
but better to replace both a the same time.
if the tv has a vertical lines from top to bottom it may have bad plasma panel and can be considered as not economical to repair.
Oct 03, 2012 | Samsung SPN4235 42 in. Plasma HDTV
Two inch wide vertical band spreads across half of screen
this is a problem is your scan section either letf or right scan boards are bad. if its under warranty take it back if not it needs to be serviced. you can probably do it yourself.
Jul 01, 2009 | Televison & Video
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Vertical bands on screen
bad x drive board on bottom of set where lines appear
Apr 27, 2009 | Televison & Video
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
Samsung PN51E530 51-Inch 1080p 600Hz Plasma HDTV Logo
3,971 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
