My 50 Viore dlp tv turns itself off after just a
My tv turns itself off after just a few minutes.
  • 6,784 Answers
HI, this may be a simple cooling issue. try inspecting the cooling fans that are located near the power sector. if these cooling devices are not operational, they will cause the power board to shut down periodically, due to heat build up.
If the fans are operational, this will confirm a weak and defective power power board.
Posted on Jul 21, 2009
I have a 46" dlp hd akia , making a loud rumbelling sound with no picture , bulb is good and working , fan is working too ???
Posted on Nov 28, 2009
2 Suggested Answers
SOURCE:
Angel Petter
  • 114 Answers
SOURCE: my viore 50
Hello there cjchris7!
first of all i need to know how old is your TV?
have you ever clean the back were the lamp is?
have you ever change the lamp of your DLP?
does it make strange sound's in the back wen it's one?
can i make a suggestion first all check does questions and then try to clean your TV to see if i works if not. probably is the tv lamp or if it makes sound maybe the dmd board depending on what is your answers ...
i will pas along some websites so you can look for prices and stuff.. hope it works!
any thing you need just reply..
have a good one!
http://www.discount-merchant.com/SearchResults.asp?Cat=303&Search=philips
http://www.bizrate.com/dlp-parts/
Posted on Jan 26, 2010
Sound goes away
Perhaps. Sounds like an MTS decoder problem.
Apr 14, 2014 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I'm trying to reset my viore tv but it want stay on long enough
My Stand By light,Timer/Temp light,Lamp light is blinking. My T.V will come on for just a few minutes then it shuts off. then my lights flash on and off.
Mar 12, 2011 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My 50" Viore DLP Television has white dots showing
Bad Light Engine/Optical unit Assy Block
Encompass Parts Distribuiton 1-800-638-3328
UED 1-800-648-6657
Dec 14, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore tv turns off by itself
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Mar 30, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
I have a 46' viore ipt46dl30 and when it turns on all the screen is really flickery. and most the colours come up purple, but this goes away for about 5 ten minutes and the flickery purple screen comes...
Viore ipt46dl30
Same problem, cleaned color wheel, put a few drops of wd40 on bearings, worked good for two months.
Started flickering again, need to replace color wheel.
Feb 03, 2010 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
My viore 50" dlp tv keeps turning off every few minutes
Ck Fan that cools Lamp if it stops running then it is defective But it could be you just need to Replace Lamp Call Mats 1-800-628-1118 and Look up online Encompass Parts for your TV,this is there # 1-800-638-3328 Also look on E-Bay found Lamp for my DLP for 85.00 thier.
Nov 18, 2009 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
Televison & Video Logo
863 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
