Question about Aircrafts
Why do the left propeller on aircraft spin clockwise and the right engine spin counter clockwise?
Why don't both of them turn clockwise or counter clockwise? Why don't both of them turn clockwise or counter clockwise? How about single propeller aircraft?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 82 Answers
Its easier to control the airplane with that balance, a twin like that would be easier than a single for the same reason that the prop rotation makes the plane easier to turn to one side than the other.
Posted on Jan 29, 2018
How do you start a plane?
Technically anyone could get in and start a big jet aircraft, but it would have to be pointing in the right direction. Getting a large transport jet going is allot more complicated than just starting the engines. The whole aircraft has a multitude of systems that have to be brought on line even before the start is selected. Failure to do so would have the computers on board sulk until you said good morning to them. The first operation, thus, is to 'power-up' the aircraft, this means to establish electrical power. This can be done in two ways, one being establishing a ground power unit and secondly, the aircraft's own auxiliary power unit, which is normally a little jet engine in the tail of the aircraft. The APU as it's called (auxiliary power unit) will also supply air pressure for cabin air conditioning and to the air starter units used to spin the main engine turbines at high speed to start the main engines, when commanded to do so. This is why the air-conditioning temporarily goes off when the engines are starting, because the APU cannot supply both engine start air and conditioning air at the same time.
After electrical power has been established, the on-board computers will come to life. Some computers are in their own little world and control things that are fully automatic, you only hear from them if they detect a defect in their own self test. Other computers are in pairs and threes, they monitor each other and alert the pilots and engineers via other computers if any detects faults in the others. There are two or three inertial navigation systems that are driven by lazar light. In each unit there are at least three lazars in different orientation. These units can detect the slightest movement and calculate the position of the aircraft by adding that movement to the aircraft's current position. The IRS units are very - very clever since they measure the movement by measuring the shift in the light spectrum when the aircraft moves. Since they measure movement, they have to know the speed the world spins at and the speed of the earth through space, to deduct that from the small movement on the aircraft in order to calculate the position. Allowing the IRS units to come on line is essential and must be done before main engine start. The aircraft must be completely stationary for this to happen.
After all that has been done the main navigation computers are programed for the route to be flown and with other information. The Flight management computers (as they are called on some aircraft) can also acquire their own information, like how much fuel is on board, and in flight the airspeed of the aircraft the angle at which the aircraft is at and from that it will calculate the weight of the aircraft.
So when all the systems are up and running and the computers have done their thing and have been programmed where required we can carry out all the other checks, switch on the galley power and call for a cup of tea and when we have drunk that we are nearly ready to start the main engines.
When ready to start the main engines the air system has to be re-configured to enable the starters to operate, following that the normal procedure is to place the engine start switch in the auto start position, where all the starting functions are carried out automatically. Both pilots monitor the engine start as sometimes things can go wrong like a hung start or a hot start. These sort of malfunctions can seriously damage a multi-multi million dollar engine in a flash and no pilot would want to be responsible for that. As the engine spins up to speed, at a predetermined percentage RPM the captain will select the fuel switch to the run position which will allow the fuel to be injected into the engine for light-up. Following a normal start the air system is then reconfigured once more as part of the after start check list, along with other post start items.
All in all what I'm trying to say is that it is a complicated procedure and not just about turning a key like a car. So if you were to board a dead aircraft on the tarmac and turn the start switch nothing would happen.
So what if the engineer wanted to run an engine for an engine test, would he have to follow the same procedure? Well, apart from loading the flight data into the flight computer, he would have to do everything else, if only to prevent all sorts of warnings that would occur trying to short cut the procedure, since the only warnings he would wish to see is anything that is relevant to the engine start, otherwise engine starting and running warnings may well be disguised by other more insignificant malfunctions. Hope this has been helpful.
Jan 04, 2017 | Aircrafts
How to know if the aircraft is airworthy?
From a pilot's point of view, every aircraft comes from the factory with a checklist of things to look at specifically before every flight to ensure airworthiness. It's generally called a walk-around inspection, checking flight controls for security and condition, tire condition, engine for obvious problems. propeller, fuel and oil quantities. and many other things. The walk around also includes checking to ensure all required paperwork is there including weight and balance, airworthiness certificate, aircraft registration, operator's manual. etc. I would also check the log book to verify the transponder check was done within the past 24 months and the annual or 100 hour inspection is current. From an A&P mechanic point of view much the same applies, however I would look much closer at the maintenance logs for engine and airframe.
Are there any aircraft still in production that use a radial engine?
Until relatively recently the answer would certainly have been yes. The Antonov AN-2 was still being produced until 2001, and many are still in service carrying passengers and freight.
Sukhoi Su-29 (and others in that line) are still in production (as far as I know). These are aerobatic aircraft with radial engines, made in Russia, and prized for their performance. I believe the newer Su-31 also uses a radial engine.
Is hydrogen the only source of fuel that can replace the current jet fuel for airplanes?
Well technically you can make a ducted fan plane but it is highly inefficient as battery technology is still in its infant stages as well as batteries are still very heavy. Secondly Jet engines are basically high bypass turbines.. They can technically run on many different fuels such as diesel, kerosene, and propane.
Hmm! Anyone on YA ever flown on a prop passenger plane like the DC3?
Yes. There are propeller driven airliners in service today, mostly on short routes.
When you increase throttle and engine rpms what happens?
If you are flying level you climb. If it's a propeller plane and you don't add rudder to counter "P factor" you may also turn a bit.
Why no whole-plane parachute system on commercial flights?
Aircraft too heavy. Weight is extremely valuable/expensive and the weight of a parachute system would be too heavy and costly, sacrificing room for paying passengers.
Aircrafts Logo
154 people viewed this question
Top Aircrafts Experts
Ira Hartzog
Level 1 Expert
Elapatha Kumarasiri
Level 1 Expert
Are you an Aircraft Expert? Answer questions, earn points and help others
