Question about Memorex Computers & Internet
I have the Memorex 3202- 3223 and I need the installation cd
I can't get my Memorex dvd writer to play a DVD, is there something I need to do to start it?
Search Results
    Amazon.com: Memorex 98251 CD/DVD Writer 8x- External ...
    www.amazon.com/Memorex...DVD-Writer.../B002O0...
    Amazon.com, Inc.
    Rating: 3.5 - ‎51 reviews
    Amazon.com: Memorex 98251 CD/DVD Writer 8x- External: Electronics. ... my hp/xp has a writeable cd drive but a player dvd. wanted to save space on my hp ... hoops toget it to work, and I also feel cheated that I can't use the cd software that ...
    Customer Reviews: Memorex 98251 CD/DVD Writer 8x ...
    Amazon.com, Inc.Memorex 98251 CD/DVD Writer 8x- External ... See all 30 positive reviews> .... myhp/xp has a writeable cd drive but a player dvd. wanted to save space on my hp ... hoops to get it to work, and I also feel cheated that I can't use the cd software ...
Dec 29, 2015 | Memorex 32020019660 8X DVDRW External Slim...
I have an older Memorex Radio CD Player compact music system (wall mount) that I need to take off the wall or find a manual.
MEMOREX Portable CD Player Boombox FOR PARTS OR ...
www.ebay.com/.../MEMOREX...CD-Player...PARTS...-/151141511...
eBayMemorex Portable CD Player MP8806 CD/Radio Boombox Fast Shipping ... Sharp Boombox CD Cassette Recorder Player AM FM Radio Portable Parts or ...
Oct 15, 2015 | Cars & Trucks
Installed a dvd burner in my compaq sr1703wm
Memorex CD are a waste. please do not buy Memorex. Dell technical support does not rely on Memorex CD. Use some other brands
Jun 22, 2012 | Memorex Computers & Internet
I can't find my installation cd for my memorex scanner-where can i get another copy or even download it?
Well it should be detevted without the need of any drivers in Windows Xp, if you are using other OS, try installing the support cd that came with your Memorex scanner (it is the mini cd(always) in the package).
Thanks.
Aug 08, 2010 | Memorex MEM48U Flatbed Scanner
How do i install this device into my computer?
Well it should be detevted without the need of any drivers in Windows Xp, if you are using other OS, try installing the support cd that came with your Memorex Player (it is the mini cd(always) in the package).
Jun 27, 2010 | Memorex MMP8565 MP3 Player
Need to find out how to install my memorex double layer 16x
Ok here is what you need to do. Open the box that the driver came in and also the side panel of your computer. Remove the cables that are attached to the current CD-ROM drive and if you need to unscrew the screws that are holding the CD-ROM drive in place which you'll need a phillips screw driver for. Remove the old CD-ROM and put in the new one and reconnect the cables to the new one. If an installation disk came with it then put that in the CD-ROM drive and install whatever is on that disk. Afterwards you should be ready to go. If you need anything else please let me know!
Apr 05, 2009 | Computers & Internet
MMP9008 Wont turn on
I'm having the exact same problem, and I'm 99% certain I know how to fix it. Unfortunately I need the cd that came with it, and I don't have it. On the cd there should be a folder with some files to re-install the firmware on the player. It might have "stmp" in the name but I'm not sure. Assuming the cd does have those files, you want to first install the drivers that come in that folder. Then on the mp3 play, keep it unplugged, hold the on switch in the "On" position, and while keeping the switch held, plug in the usb cable to the player(make sure the other end was already plugged into the computer.) What this does is force the player to be detected by windows as a recovery device. Those drivers you installed were for this new setting. Once that's done you can run the firmware installer/updater from the cd, and it should re-install the original firmware. Then just unplug the player, wait 30 seconds or so, and then turn it on as normal. That -should- get it working again. If it doesn't, you might have to plug it back into your computer, the normal way, and format the player's hard drive. You'll lose whatever music and videos you had on it, but it might need to be formatted after a firmware re-install.
If I'm right about the cd having the firmware update(and I should be), and assuming my post is helpful, you might consider putting those files into a zip file and emailing it to me at polign at yahoo dot com so I can fix mine too. I've searched the internet for hours, and no once has it for download. I'd really appreciate it. And if you don't happen to have the cd, then I guess we're both out of luck.
Good luck fixing yours.
Nov 30, 2008 | Memorex Audio Players & Recorders
Memorex cd-rw/dvd-rom wont install
FOrget the cd in the box.
http://memorex.com/html/download_software.php?sid=15
Download the latest driver for the product, and matching your computer and operating system.
Oct 22, 2007 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Computers & Internet Logo
189 people viewed this question
Top Memorex Computers & Internet Experts
Ekse
Vernon Taylor
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
