Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag Centenial - Won't spin unless I lift and lower the lid.
I have the same problem with my Maytag Centenial. This washer is brand new. If I do a load of laundry the washer will agitate just fine, but won't spin unless I lift the lid and set is back down. It is not the lid switch, because the washer stops whenever the lid is lifted, and runs when the lid is lowered, so the switch is fine.
4 Suggested Answers
SOURCE:
Lumpy816
  • 246 Answers
SOURCE: Maytag Atlantis washer will not drain and spin unless you lift the lid
The cheaper thing to check first is is your lid bent? The lid switch is in the center of the lid. If it "droops" or has been bent, it shaft on the back of the lid cant hit the switch. Open the lid and apply pressure in the bottom, center of the lid. This usually corrects the problem without replacing the switch.
Posted on Jun 16, 2008
  • 22 Answers
SOURCE: Maytag Atlantis Washing Machine does not ever drain or spin unless lift lid
your machine needs a new lid switch assembly!
Posted on Aug 22, 2008
  • 219 Answers
SOURCE: maytag sav365zaww agitates straight through wash
would say it would be the timer if it was the lid switch it wouldnt vspin or agiatate
Posted on Mar 18, 2009
I cant reset my 2009 Maytag Centennial clothes washer
  1. Unplug the washer for 1 minute from the electrical outlet.
  2. Plug the washer back in and lift and lower the lid 6 times within a 12 second period (you have 30 seconds to start lifting and lowering the lid).
Apr 05, 2018 | Maytag Washing Machines
I dont know how to Reset my 2009 Maytag Centennial washer.2009 IMPORTANT
  2. Plug the washer back in and lift and lower the lid 6 times within a 12 second period. You have 30 seconds to start lifting and lowering the lid.
I want to use Woolite with my Maytag Centenial, how can I fill with washer with water without adding clothes?
Just put in wash cycle and wait for the water entering to stop them pop the lid. Naturally you did not have any clothes in there while the water was filling up the tub.
Aug 26, 2017 | Maytag Washing Machines
Maytag performance top load washer
follow this steps and fix it. God bless you
  1. No power to the washerMake sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
  2. Lid switchThe washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Read more: http://www.appliancepartspros.com/repair-help/washer-repair-help.html#1#ixzz2YbiV2et5
Jul 09, 2013 | Washing Machines
My mvwc300vw1 won't spin unless you lift the lid up to activate it
I'm not sure what you mean by "activate it." Are you are manually pressing down on the lid switch or are you saying that lifting the lid starts the spin cycle? You may just need to adjust it. For whatever reason the actuator on the lid isn't pushing the switch far enough to activate it. It is possible that the actuator broke in some weird way that makes it contact the switch when the lid is opened. Regardless the spin cycle should cease when the lid is opened. The actuator is the wire hinge on the left side of of the lid. They always break where the screws connect them to the lid so you should be able to see it by lifting the lid. You can go here for manuals and exploded views of your machine. The hidden lid switch and actuator are clearly visible if you click the "Top and Cabinet" diagram.
Now i want to say something about your machine. First to be fair i don't know what the reviews of this machine might have been and I've never owned one, but if it serves you well hold on to it. Maytag doesn't make them like that anymore. In fact Maytag doesn't really make them anymore. That repairman died years ago and was never replaced. I'd take a machine like yours (with manual controls and no brain) over every smart h.e. machine i've ever had the misfortune to work on or operate. Sure they save water and they are quiet now but the drain pumps are junk fixing to bust and in my opinion the reason people experience mold and odor problems. They oversuds chronically and then have to sit while the machine decides when and how you can proceed. Doors lock shut at the most inopportune times. Control boards cost hundreds of dollars to replace and diagnosing problems on a "smart machine" can sometimes be more than a little baffling. So treasure it. Just sayin.
Jan 01, 2013 | Maytag Atlantis MAV6000 Top Load Washer
May 31, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Washer not spinning
Sounds like the brake liner could be broken. When the machine starts to spin, the motor turns in the opposite direction to the wash cycle and causes the bowl to lift off the brake liner and the bowl then spins freely. Either the riser cam is worn/broken or the brake liner is broken. This is quite involved and you may have to call in a tech.
Nov 03, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
122 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
