Question about Samsung Cell Phones
,my Samsung jimi is taking a long time to charge
    Master:
  • Samsung Master
  • 515 Answers
You have to change your charger or use every time Samsung charger to charge your phone...
http://samsung.com/
,my Samsung jimi is taking a long time to charge - untitled 1-fjchyoordv4x4ap5xtwjxp00-1-0.png
Posted on May 26, 2017
    New Friend:
  • 3 Answers
Its either your charger or battery spoil. Try charging with another adapter. If the problem still there, then try changing the batt.
Posted on Jun 11, 2019
SOURCE:
WE HAVE TWO SETS ONE WORKS PERFECTLY WHEN CHARGING THE OTHER WILL NOT EVEN SHOW BATTERY AS CHARGING WITH EITHER CABLES. tHEY WERE PURCHASED aUG 2013 SO IT PRESUMED NOW OUT OF GUARANTEE.you please advise...
It is more likely either the cable or your are not using a Samsung charger for one. If you let their tablets get below 1% only a Samsung charger will recover the battery. In theory it should not be require but I have tested it a dozen times and every time switching to the Samsung charge for the next few charges makes it so any USB charger (under 2 Amps) will then work again.
Yeah, I think Samsung uses the standard 1 years warranty for everything. They are not exactly Weber or anything and do not provide long warranty periods.
Mar 31, 2015 | Samsung Galaxy Tab on 3 Mobile Tablet PC
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Unable to switch on my samsung T210 tablet
Feb 17, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
How long do i need to charge my new samsung galaxy 2 before its ready for use
After purchasing every new phone, 24 hrs continuously charging is required to use the phone first time. Please charge Samsung Galaxy 2 before use.
Jan 26, 2012 | Samsung Cell Phones
Interface Question (Alpine IVA D106)
the way u have it formated on the ipod might have something to do with that.
Apr 20, 2010 | Alpine IVA-D106 Car DVD Player
I have a Samsung OfficeServ 100 with an MCP1 card fitted. Someone has changed the Tech password, so I cannot now get into the programming on the system. Any ideas how I can either manually default the MCP1...
I have a Samsung OfficeServ 100 with an MCP1 card fitted. Someone has changed the Tech password, so I cannot now get into the programming on the system. Any ideas how I can either manually default the MCP1 or find the new passcode
Sep 24, 2009 | Lands Phones
Driver and passanger side door does not open
You need to take the inside door cover to get access to the inner workings of the window motor, linkages etc. If nobody has used a jimy in the past to unlock your door, (the reason I say this it's because the linkage could be disingaged when someone tries to unlock your door with a jimy) ok if that didn't happended than its the door selenoid (its a small actuator that releases the lock once your press the open door button.) If you are mechanicly incline, I suggest you take your tools and go to a junk yard to get your selenoid. In the process you see how everything works inside your door and it makes it easy for you to figure out how to install the part. The other reason its the price, if you get this part through the dealer it's a little expensive.
Good luck!!!!!!!!!!!!!!!!!!!!
Feb 07, 2009 | 2003 Nissan Maxima
Printing problem
quality - cartridge,charge roller,
4-5 papers - pickup presure pad, clean / replace.
long time to charge - fixing unit.- thermister.
Oct 22, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Cell Phones Logo
69 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
