Question about Simbans Tablets & eReaders
On my Simbans Presto tablet i am getting alot of apps that say unfortunetly app has stopped
SOURCE:
  • 84 Answers
SOURCE: operating system,xp tablet edtion
I can get you a copy of the 2005 xp tablet edition os, you would have to use your own cd key and activation to make it legal. Although it will install with it's own cd key, licensing requires you to use legal activation and the key that came with your unit. Check with mpcdrivers.com
Posted on Apr 10, 2010
  • 3 Answers
SOURCE: my tablet as frozen i am unable toswitch it off
Hold down your power button for 15 seconds.
Posted on Feb 05, 2012
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
Posted on Oct 13, 2012
appdevices
SOURCE: i have a polaroid android tablet. it one day just started to not work anymore.
Just a thought, however, it might be that it automatically upgraded your Android operating system and now the apps are not compatible. Try deleting one of the apps and re-installing it. Hope this helps you - Learning Thermostat
Posted on Nov 19, 2012
TechyDrood
  • 2072 Answers
SOURCE: The App Store won't let me download anything on my tablet. I am using getjar because that is what works on my tablet. How do I fix the App Store on my coby kyros tablet?
I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
Posted on Nov 27, 2012
Need to reset simbans ultimax tablet pc due to space problems. get message of 'not enough storage to download app'. how do I do this?
To reset your tablet you need to go to setting then find backup & reset and when you are there you should click on factory reset
Aug 15, 2015 | Simbans Tablets & eReaders
When I want to install more apps says I have no more storage.yet I do .what's wrong Storage says available.
On your internal storage SD card there is an App partition. This is where all your apps are stored. Many devices have a small App partition like maybe 1 gigabyte. It doesn't take long to fill this up with additional apps.
Many Android devices display this App partition storage bar graph in Settings > Storage. It's usually the top horizontal bar graph. If it's all one color then it's full and it will perhaps say something like 1 gigabyte of 1 gibabyte used. The only way to get
more room to download new apps is to delete some of the old ones, or in some case a few of them might be able to be moved to the external SD card if your device has one in its slot.
May 21, 2015 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
Hi as soon as I go onto gum tree app it stops
Is Gum Tree an app?
Try uninstalling and reinstalling the app. Perhaps it is corrupt.
Mark
Motorola Support
Mar 06, 2015 | Motorola Mobility MZ604 Xoom WiFi Tablet...
My tablet toshiba excite pure is saying Unfortunetly, sysyem UI has stopped. It goes off when i push ok and comes right back. How do i remove it?
Have you tried to wipe the cache partition
App data
Step 1 Press the "Menu" button and tap "Settings." Touch "Applications."
Step 2
Tap "Manage Applications," select the "All" tab and touch an application name.
Step 3
Touch the "Clear Data" button to wipe the app's saved data. Tap "Clear Cache" to remove any cached data for the app.
Phone Data
Step 1 Turn off your Android device. Reboot the phone or tablet into Recovery Mode. The process is specific to the device model. For the Motorola Droid, press and hold the "Power" button and the "X" key on the slideout keyboard. Release the "Power" button when the Motorola icon appears. Press the "Volume-up" and "Camera" buttons simultaneously to open the Recovery Console. To access Recovery Mode with the LG Ally, press and hold the "Power," "Home" and "Volume" buttons simultaneously.
Step 2
Press the "Volume-down" button to scroll to "Wipe Data/Factory Reset." Press the "Camera" button to select it.
Step 3
Scroll to and select "Wipe Cache Partition."
Step 4
Highlight and select "Reboot System Now."
Mar 03, 2015 | Toshiba Tablets & eReaders
What can I do, Asus tablet says "launcher has stopped" and will not do anything?
Always try a reboot first. If that fails go into settings, go to apps, then might have to go to system apps, see if you can start it from there. If it starts and stops, could be another app is interfering or you got too much installed and are low in memory. You can try to install a startup manager app and make sure to turn off all unnecessary apps from auto starting. If that fails, you can then try to reset to factory defaults and start all over. Just reinstall your apps one at a time and make sure system is stable after each install.
Jan 03, 2015 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
Why isn't the X showing up when I try to delete an app on my tablet? Can I fix it?
Alot of preloaded apps can't be deleted unless you put an aftermarket system on your tablet
Sep 22, 2014 | Tablets & eReaders
How do i delete gallery photos
Open file explorer app and navigate to gallery and delete them.
If you dont have a file explorer app go to the google store and search for file explorer - install it and hey presto.
May 13, 2014 | Nabi 2
Proscan tablet
The app crashed. It could be due to the app, the operating system, or the hardware.
Feb 11, 2018 | Tablets & eReaders
Tablets & eReaders Logo
107 people viewed this question
Top Simbans Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Ken Strite
Ken Strite
 Mikey
Mikey
Are you a Simbans Tablet and eReader Expert? Answer questions, earn points and help others
