Question about Juki Sewing Machines
I have a juki lu 562. Adjusting stitch length. For some reason it will not go to 9, 10, , 11 on scale. Will not go any farther than 8, then turning wheel opposite goes to 12.
    Novelist:
    Scholar:
  • Juki Expert
  • 90 Answers
Turn it to either extreme and then see if the feed dogs hit the plate when you hand turn the hand wheel towards you. Sometimes the feed dogs or plate have been replaced and they have set the stich length so that the feed dogs won't hit the ends of the plate.
Posted on Oct 28, 2017
5 Suggested Answers
6ya staff
SOURCE:
charlymonty
  • 3741 Answers
SOURCE: I have a Juki Lu-562. The safety clutch counter
click this link directly .http://www.raichert.com/adobe/LU562%20LU563.pdf ------ its mentioned on page number 12 of the link.ablout the clutch spring adjustment. --------- check out.keep updated.thanks.
Posted on Nov 10, 2009
rdc513
SOURCE: I have a Juki LU-562 sewing machine I was sewing
Like most of the older sewing machines, the lu-562 is usually an easy fix when it comes to issues of timing and even broken parts. First determine where the spring came from and that should point you to the parts that need replacing and/or readjusting. But, by all means DO NOT continue operating the machine until its fixed. Without actually seeing the machine, it sounds as if the needle bar spring failed.
Posted on Feb 28, 2011
SOURCE: How do I change the stitch length in my Juki LU
hi there
the graduation of the stitch length is marked on the feed graduation plate attached t the main shaft,to adjust the stitch length rotate the hand wheel slowly as you keep pressing the push - button stop the bed until the tip of the push- button enter groove of the accentric mechanism, when it is entered rotate the hand wheel eigher towards you or away from you as you keep pressing the push - button until the desired stitch length indicating mark on the graduation plate appears on the hole of arm. when appear release the push - button and check stitch length.
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
Posted on Jun 22, 2011
99rannellis
R.A. Ellis
  • 12731 Answers
SOURCE: how to loch the stitch on Juki-562?
If there is no reverse on the machine, you can shorten the stitch at the beginning and end of the item. Or, you can sink the needle, pivot the item 180 degrees, sew a short distance, then pivot back 180 degrees and stitch over the first stitches. Other than that, tying the thread tails in a knot.
Posted on Nov 14, 2016
Help plz. my juki lu 562 wont sew
Not enough information to provide an answer.
Jan 22, 2018 | Juki Sewing Machines
Juki 8700- stitch length won't go below 2.5. Knob gets stuck. How to make stitch length lower?
SLIGHTLY unscrew the large screw in the center of the stitch length knob, turn the knob to the right several clicks and retighten the screw. DON'T take it completely out, or you will make more work for your self.
Jul 07, 2016 | Juki Sewing Machines
Juki LU-562 I heard a clunck and the bottom walking foot doesn't work right .
Hello, I have a different model Juki but it sounds to me that your safety clutch has been tripped. The safety clutch functions when an excessive load is applied to the hook or the other components during sewing. At this time, the hook will not rotate even if turning the handwheel. When the safety clutch has functioned, remove the cause and reset the safety clutch by pressing and holding the push button on the top surface of the machine bed, while strongly turning the handwheel in the reverse direction of rotation. The resetting procedure is completed when the handwheel clicks.
Jan 07, 2014 | Juki Sewing Machines
How to put Lu-562 back in timing
try youtube or ehow
sewusa.com
Apr 15, 2012 | Juki Sewing Machines
How do I change the stitch length in my Juki LU 563
hi there
BEST REGARDS
AHRAF ABOZID
CAIRO - EGYPT
Apr 02, 2011 | Ludwig LG8B2 Industrial Sewing Machine
I have a Juki LU-562 sewing machine I was sewing thick leather it made this clunk noise and a spring flew out of it underneth it now the hook just turns and it doesn't sew.
Sep 28, 2009 | Juki Sewing Machines
Looking for a manual
JUKI HOME SEWING DIVISION 8500 NW 17 th Street Miami, FL 33126 Phone: (305) 594-0059 ingrid@juki.com she will send you one
Mar 25, 2008 | Yamata FY700 Mechanical Sewing Machine
Sewing Machines Logo
511 people viewed this question
Top Juki Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Wayne Buss
Douglas Plant
Douglas Plant
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
