Question about Memorex Computers & Internet
My traveldrive from Memorex is showing blank.
SOURCE:
SOURCE: Memores 4G Mega Traveldrive doesn't read
Step one is try it on another computer. This will seperate issues....is it the drive or the USB port (hardware or software actully in both cases are possible.
Step two, if it works elsewhere, is to check under device manager, and reinstall the driver (if not embedded in the drive which most are)....both USB and the disk.
Step three is to download (again assuming it did not work) the disk diagnostics from Memorex (most drive manufacturers have a host of utilities and they may exist even for flash drives - they use them internal to their mfg operations as well). Check to see if it's good. It is possible that it just lost the embedded driver by the way in which case you need to put it back on the drive...haven't done that but assume it's possible and available.
Can give you more "stuff" to do but this will probably solve the problem....and I am guessing it died. If it did they are not expensive...and even cheaper if you really don't need 4 gb...few people do for personal and even work data.
Check at pricewatch.com (not a seller) for pricing. This site is used by GEEKS United for finding "stuff".
This gives you some options.....Tango
Posted on Jan 25, 2008
SOURCE: MEMOREX TRAVELDRIVE 1GB
Tohono, sorry about the other confusing mis-interpretations of your problem. I'll try to help you understand.
First of all there is little reason for a write protect error on your drive unless you have either inadvertently set an file attribute incorrectly or a protected system file has been stored on the drive, or in some cases a virus wll write protect itself when it installs to a drive.
A simple fix for all the issues assuming you have no data you wish to save, is to format the flash drive only. Please don't format your C: partition, only the USB flash drive, okay.
More detailed instructions are below
http://www.memorex.com/downloads/manuals/TravelDrive_Users_Guide.pdf
Posted on Feb 28, 2008
  • 51 Answers
SOURCE: how do you remove the data from the traveldrive memorex 256 mb
just format it
Posted on Aug 20, 2009
  • 211 Answers
SOURCE: I have just upgraded to a Windows 7 system. My
  1. break all ur partations and recreate them ... and then format the usb drive
Posted on Jan 10, 2010
laikexpert
  • 281 Answers
SOURCE: How do I get my memorex usb 2.0 traveldrive to
Download and Install.
Memorex usb 2.0 traveldrive Driver Download:
http://www.opendrivers.com/categorycompany/1375/1300/storage-memorex-free-driver-download.html
Posted on Feb 08, 2010
Memorex ultra traveldrive usb 2.0 driver windows 7
it looks like is empty but i now it has my records!!! what I must do?
Feb 27, 2013 | Memorex Ultra Traveldrive - 160GB USB Hard...
Memorex Ultra Traveldrive - 160GB USB Hard Drive
There are programs specifically designed to do that. I can't give you specifics but just do a quick google and you should find it. Also, if those don't work, you should bring it to a data recovery service center which they will do it for you. It really depends on the severity of corruption
Nov 12, 2012 | Memorex Ultra Traveldrive - 160GB USB Hard...
I have deleted what was in the usb traveldrive and it still shows that it is full capacity. How do I find what else I need to delete? It doesn't show me anything is in it but it's telling me there is.
Hi!
To see all the contents of the drive, go to Control Panel, switch to classic view and open Folder Options, then go to View and in the list, choose "Show hidden files and folders"
Hope this helps!
Jan 03, 2011 | Memorex Mega TravelDrive 4 GB USB Hard...
Need software for 512mb traveldrive using Windows 7
The TravelDrive is a "plug-and-play" device, and Windows 7 supports Plug-and-Play.
So, any device-drivers are included, and will automatically be used when you connect the TravelDrive.
What problems are you having? Symptoms? Error-messages? Does the TravelDrive work in some other computer? Does any other USB device work in the USB port that you are using for the TravelDrive?
Dec 18, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
How to use
you can download your memorex mega travelDrive 4 manual from this link
http://www.memorex.com/PageFiles/1180/manual.PDF
and learn well how to use hope that was helpfull
Sep 11, 2010 | Memorex Mega TravelDrive 4 GB USB Hard...
I purchased a memorex 160GB traveldrive. I would
Things to ponder before deleting
Rather then deleting them right away, try moving the "day the files were uploaded" to another drive. Then try accessing the files on your memorex. Do the files and folders open properly? There not corrupt? Has the memorex hdd drive recreated the folder you just moved? etc...
Once your satisfied that yes there are two copies then you could safely remove one.
Nov 07, 2009 | Memorex Ultra Traveldrive - 160GB USB Hard...
Computers & Internet Logo
35 people viewed this question
Top Memorex Computers & Internet Experts
Vernon Taylor
Harrie
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
