Question about Sharp Televison & Video
Lcd tv screen goes black after a few seconds but sound still plays. The flashlight test will show the image for a short period of time but then it goes away and is completely black.
Sharp PN-E702
  • 108 Answers
Hello... It sounds like you have a backlight failure, and the image going away during the flashlight test is due to the TV going into "Protection" mode. A service technician may be able to go into the service menu and clear the lamp error codes and get the TV working, or it may need the backlights replaced. I hope this helps...
Posted on Nov 18, 2017
SOURCE:
  • 75 Answers
SOURCE: BLANK LCD SCREEN
The shutter in the lens is stuck closed. You need to take the camera to a shop where they will replace the lens assembly.
Posted on Mar 25, 2007
skotkolr
  • 558 Answers
SOURCE: Sharp LCD TV, Screen goes black sound stays on
Capacitors on the power pack are going bad they need to be replaced that should fix the problem.
Posted on Apr 07, 2009
  • 26 Answers
SOURCE: my monitor flickers then goes black
It could be the capacitors on your monitor's Power Supply. Open up the lcd and check the power supply board see if you see any "BULGED UP" capacitors. If thats the case you most likely just need to replace the bad capacitors. Go to radio shack or electronics supply store buy the same capacitors with the same mF and volts. If you can't find the same ones then always go with higher voltage. Replace the bad ones with new ones following this video. Make sure you note the negative terminals on the CAPS before you remove them. The shorter side on the new CAP is always negative.
Posted on May 03, 2009
  • 21 Answers
SOURCE: we just set up our 37 in sharp and get no picture
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
  • 66 Answers
SOURCE: Sharp LCD TV picture goes off few seconds after
it has problem in picture tube
Posted on Nov 16, 2009
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
Jan 03, 2017 | Hisense Televison & Video
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
We will get a black screen but still have sound.
Sounds like a main board that controls everything on the screen and then some.
Since a LCD do the flashlight test (what I call it) : darken the room as much as possible and with a flashlight and the set on look closely at the screen, see a very very faint image of the picture or not?
Dec 22, 2012 | Vizio 42 in. LCD TV
After i power my polaroid tv on the screen shows for about 3 seconds then goes black what causes that
Its a Lcd so if it stays on turn off all the lights (we want a dark room) and with flashlight look carefully at the screen to see if you see a faint image of a picture there or not.
Dec 06, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
Screen turns on for a few seconds then goes black...
mhaupt, Tell me if it is both BLACK and BLANK or just BLACK after you do the flashlight trick !!! This is no joke!! understand?? When the screen goes black hold bright flashlight where you saw an image on the screen (icon or win start button) and tell me what you see or don't see!!
Get back to fixya with new comment to your original post. 12fixlouie
Oct 27, 2009 | Sony SDM-HS73P 17" LCD Monitor
TV was playing, then the screen turned black.
If the screen is black and you have sound then lightly press and shine a strong flashlight against the screen. If you see an image around the edge of the flashlight, an image is being 'displayed'. The problem is probably in the Inverter/CCFT or the power going to the Inverter.
Feb 01, 2009 | Insignia 37" LCD Flat-Panel HDTV
Screen goes black
Hai,
Do you see any dull image on the screen ?
If yes the inverter Card/Backlight of the screen is having problem.
Regards,
Aby
Dec 22, 2007 | Rosewill R900J 19" Flat Panel LCD Monitor
Televison & Video Logo
158 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
