Question about Simbans Tablets & eReaders
I have a simbans tango tablet gifted at xmas and the sound is not working.I can hear with headphones. What to do? I'm in Canada.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 104 Answers
Swipe down from the top and check the settings in "audio profiles" See if the speaker is muted.
Posted on Jan 25, 2018
5 Suggested Answers
SOURCE:
  • 400 Answers
SOURCE: sound problems on tablet
It sounds as though the switch on the phone jack is not making connection when the phones are unplugged. You can probably clean it by spraying some contact cleaner in the jack, then plug and unplug the phones several (lots of) times. I've had good success with WD40, but it does leave a residue. If this does not fix the problem, you can open the tablet by gently prying the screen off with thin blade (a knife might work). Work your way around the entire screen until the body separates. Gently open and perhaps you can access the jack switch to clean it, if it is not sealed. I hope this is helpful to you.
Posted on Mar 23, 2014
  • 419 Answers
SOURCE: For Christmas I received an Archos tablet and my headphones jack stopped working. Instead of playing sound through headphones while they're plugged in, it plays through the built in speakers. Is there
Every thing is low quality chines junk these days and probably head phone jack input is broken and it is not repairable as all similar items ,
Posted on Jan 13, 2015
  • 47 Answers
SOURCE: When I plug the headphones into my Samsung Galaxy 10.1 tablet, the sound comes from both the headphones and the speakers on the tablet, shouldn't the speakers be turned off by the headphones?
As mentioned above, SoundAbout should work.
Posted on Jan 15, 2015
ameliawang93
  • 1001 Answers
SOURCE: my headphone jack not work when i put it in my tablet i can still here the sound from my tablet and the headphones from the tablet it is a irulu Tablet,
  • Advanced Technology,The buletooth headphone ensure clear speech within 10 meters and high-fidelity stereo music .
https://www.amazon.com/Charm-Bluetooth-Headphones-Runing-Exercise/dp/B01DUA9C6Y/ref=sr_1_3?ie=UTF8&qid=1483410860&sr=8-3&keywords=Charm%2Bsonic&th=1
Posted on Jan 03, 2017
I hold my power button and volume botton but my simbans tablet wont turn on even when charged
Sounds like the power button switch has given up on you. With a lot of care and time, you can fix this yourself for a few dollars if you buy the part and tools on eBay, or you can just take it to a repair shop.
Jun 03, 2018 | Simbans Tablets & eReaders
How can I download a driver from Simbans so I can download and upload to my PC?
You just connect it with you USB cable and transfer using Windows Explorer. It will be shown as a Removable Drive.
No drivers or software exists. Brand leader is iPad, which does have some capabilities via iTunes.
May 05, 2016 | Simbans TM S10W 10 Inch Tablet PC - QUAD...
User manual simbans ultimax 10'' tablet
Your manual is here.
Turn your device on and off To turn on your device, press and hold the power key.
To turn off your device, press and hold the power key, and then tap Power off?OK.
Manuals
Dec 29, 2015 | Simbans Tablets & eReaders
Need to reset simbans ultimax tablet pc due to space problems. get message of 'not enough storage to download app'. how do I do this?
To reset your tablet you need to go to setting then find backup & reset and when you are there you should click on factory reset
Aug 15, 2015 | Simbans Tablets & eReaders
My headphone jack not work when i put it in my tablet i can still here the sound from my tablet and the headphones from the tablet it is a irulu Tablet,
Make sure you push the headphone plug into the jack completely. If you're sure that it is, then the jack on the tablet has failed. The sound gets switched from speaker to headphone in the jack itself.
Aug 08, 2015 | Tablets & eReaders
My tablet has no sound why?
Lots of possibilities. Most likely something is wrong with the headphone jacket. If a contact is lose or something came between it, it could block the throughput. Then you could have switch sound of, or even the speaker or amplifier is defect. Try a headphone to see if you hear something through there. When you get sound through the headphone, only a bad connection and a bad speaker are left. If the head phone does not work, it could be a bad connection or a defective amplifier.
Jan 18, 2015 | Tablets & eReaders
How do I load APS to SD card, my Simban 100 will not load anything beyond 8gb internal memory.
one way that always works though a few steps.
get an sim adapter for the sd card for your computer they are cheap to buy.
connect cable to your simban 100 an copy what you want off of it too.
now put all you want on the sim connected to your computer with sim adapter.
when finished you now have any apps you want on the card. generally.
if you want to load apps from the sim you have to go to security setting in tablet n set it to allow that.
Jan 05, 2015 | Tablets & eReaders
Headphone jack on kindle fire doesnt work
If the sound works on your Kindle Fire's speakers and will not cut off and reroute sound to headphones when you plug them in to the headphone jack port on the side of the Kindle. Try the following:
If you have a set of blu tooth headphones then enable blu tooth connection to a source of sound like, You Tube, Spotify iTunes etc. You will be able to hear sound on your blu tooth headphones this way. Turn of the blu tooth headphones, then try plugging in your regular wired headphones into the Kindle and reconnection should be achieved.
Jul 07, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Simbans Tablets & eReaders Experts
Andrew Taylor
Andrew Taylor
Ken Strite
Ken Strite
 Mikey
Mikey
Are you a Simbans Tablet and eReader Expert? Answer questions, earn points and help others
