Question about Toshiba Office Equipment & Supplies
Toshiba e studio copier wide streak in color down the middle of the calibration page how can i fix that
    Champion:
    New Friend:
  • Toshiba Expert
  • 250 Answers
Check the charge cleaner for that color it might be stuck in the middle of the pin array
Posted on Feb 06, 2018
SOURCE:
  • 208 Answers
SOURCE: Streaking Printer
On that product, it is just as likely that a single color drum is bad. Not the developer. That is a more likely problem then the developer.
Posted on Dec 20, 2007
SOURCE: Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Posted on Dec 21, 2007
SOURCE: Color Streaks down length of page
This is a laser printer, neither a copier nor a multifunction unit, therefore it has no glass. At least, I cannot find any glass in it.
I finally had an authorized Ricoh repair center examine it and found streaks on the black unit that pulls out of the right side (I forget the part's name, <$90). We replaced it and things are better but streaks of color remain. They suggested replacing the color one (about $400) but the cost is prohibitive right now, so I'll live with those streaks.
On a related note, I remain unimpressed with this printer's quality and inconsistency. For example, greys often print in pink; nothing has ever resolved this. I refuse to put any more money into it. When I can afford to do so, it will be replaced, probably by a Xerox Phaser.
Posted on Feb 28, 2008
  • 136 Answers
SOURCE: Dark streaks on copies from Xerox XC356 copier.
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Posted on Mar 05, 2009
  • 341 Answers
SOURCE: I have a 2inch wide band down middle of screen on
1) Have you installed new drivers or software or drivers? If so, remove them and restart the computer.
2) Try applying pressure with your fingers on top of the screen. If the band dissapears or dimishes, you may have a broken screen and it will need to be replaced.
Posted on Mar 19, 2010
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
To stop auto calibration in toshiba color mfd
Better not to turn off the calibration, otherwise it will cause other errors.
If your colour printing is less than 5% ration, perform following. Turn the code 08-2692 "Prevention of color toner low density / ON/OFF setting" to ON, and then set number of sheets to be judged at the code 08-2693 "Prevention of color toner low density / Judged
number of sheets setting".
08-2693 u can put higher value such as 20 or above to delay the colour calibration.
Mar 25, 2014 | Toshiba E-studio 2330c 2830c Color...
Canon NP6221 makes copies black and white with black streak down middle. How can it be fixed--works well otherwise.
They are manny cause of black copy.
1.over tone.
2.arching on main charger or dirt on main charger.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Blank streak down page when printing
clean the laser glass or replace the image unit for the color with the blank strip
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 05, 2014 | Konica Minolta Magicolor 1600W Printer
Toshiba 3511 color print problems
Hope it's not the calibration. This could happen due to transfer belt timing problem. There are sensors and reflectors inside the transfer belt assembly. They may be dirty. Clean them or replace the transfer belt if required.
Oct 03, 2012 | Toshiba E-Studio 3511 Color Copier
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
Pages printing with streaks.
try making a copy on the glass, does it come out with the streaks or clean?
If clean then look at the strip glass on the copier there is a pen dot or white out that 's giving you the streak. clean.
Jan 24, 2008 | Toshiba e-Studio 232 Black and White...
Open Questions:
519 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
