Question about Westinghouse Televison & Video
My Westinghouse tv will turn on and stay on the logo screen for about 10 minutes then it will change to a fuzzy green screen. How do I fix this
  • Westinghouse Master
  • 2,800 Answers
Try replacing the tcon board
Posted on Mar 19, 2018
6ya staff
SOURCE:
Anonymous
  • 171 Answers
SOURCE: I fixed the blinking light, but still no picture
Here is the correct and official service manual on the unit. Check all of the diagnostics first, then go into the service menu and validate your settings.
http://www.techlore.com/download/22529/MitsubishiWS55859-WS65869-WS55909-WS65909-WS73909/
Posted on Oct 10, 2008
chaseme5
  • 12 Answers
SOURCE: My TV Screen turns green or blue after 10 minutes of the tv on
You have a chip that is overheating due to heatsink coumpound being dried up. You need to find that chip and heatsink and apply new compound to both parts.
Posted on Apr 06, 2009
Anonymous
  • 563 Answers
SOURCE: JVC 42'' plasma TV (PD-42WX84) screen turns grenn after 10 minutes
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Foxfire1600
  • 3 Answers
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
Posted on Jun 12, 2010
saccomr
SOURCE: my LCD tv model LN46A650A1FXZA picture turns green
I have the same issue. TV is ~ 2 yrs old. Ruled-out cable-box & HDMI cables (green present in menu mode with no cables attached).
Screen turns mostly green, with a crappy picture. After a few days, a normal picture just appeared. Today I powered-on, the green screen stuff came up, then a minute later a good picture for about 20 minutes, back to green-stuff for 10 seconds, then good picture.
Did chavez_debi get her issue resolved?
Posted on Aug 22, 2010
Westinghouse 32' flat screen tv .red power light comes on .when turned on screen shows westinghouse symble then fades away .green light stays on then tv turns its self off.
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 22, 2016 | Westinghouse Televison & Video
Why does my Westinghouse 32" flatscreenTV shows fuzzy psychedelic colors
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
May 01, 2014 | Westinghouse LTV32W6HD 32 in. LCD...
My volume for my TV wont work unless i plug in speaker, my TV takes a while to turn on, and the picture is fuzzy for about 10 minutes.. It randomly started doing that this morning.. the model number for my...
You will need to replace the capacitor in your power supply. I cannot remember the location of this capacitor. It is in the power supply, the value is a 10 volt 2200Mf cap at 105 degrees. This will fix this model every time. Thanks for asking and show all hands of support!
Aug 03, 2011 | Westinghouse Televison & Video
COLOR PROBLEMS
yes a difficult lesson to learn who ever the manufacturer. I would take it to a repair man and get a quote, maybe its cheap fix maybe its worth just getting a new one.
Jun 22, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My HDMI ports won't work on my Westinghouse tx-42f430s TV. I have things plugged into 3 ports and they all quit working. I had to connect the composite cales to get my TV to work.???
FOUND A SOLUTION! (at least in my case) thanks to some creative Google searching...
Apparently the HDMI ports can get into a state where they are unable to negotiate the input signal properly. The way to "clear" the ports and allow the HDMI signal to be detected is to perform a "reset" on the unit.
Just turn the set off using the power button on the right side of the unit. Then, press and HOLD the power button for at least 10 seconds, then release.
The set should turn on and essentially do a "reboot" where it displays the Westinghouse logo. After that your HDMI ports should be functional again.
It worked for me :-) Best of luck..
Nov 06, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
420 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
