Question about Cell Phones
I have a motomaster nautilus intelligent battery charger, and no matter what I do I have 8's flashing across the screen. is there something that I can do get it working again?
    Sergeant:
  • 292 Answers
Unplug, and leave it until the ;intelligent' part looses its power and all the voltage in it drains out and it will loose its memory.
After about an hour plug it back in an it will return to factory settings, If there is not an internal problem, it will work the way it did, (All voltages would drain out of most of them in 20 minutes, but a few would hold a charge overnight,) If there is an internal problem the display will go back to the flashing as soon as the 'intelligent memory' detects the problem. Is it possible that the detected problem is a bad battery?
Posted on Apr 03, 2018
  • Joe Imbrogno
    Joe Imbrogno Jun 13, 2019
    Mine has been unplugged and sitting idle all winter and it started flashing 8 as soon as I plugged it in. If it didn't lose its "intelligent" memory over the winter I'm not sure it will now if I unplug it for an hour. There must be a more direct way to clear it and get back to the factory settings.
6ya staff
SOURCE:
jaipai2004
  • 3 Answers
SOURCE: have an eliminator intelligent battery
· Automatically switches from full charge to maintenance mode to maintain batteries during prolonged periods of storage without overcharging or damaging the battery
Posted on Dec 09, 2010
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: recharge battery Cadillac Deville 2005
You do not need to remove the battery to charge the battery. When you connect the charger you MUST be careful to connect the charger's positive lead to the positive terminal to the battery and the negative lead to the negative lead to the battery before you turn on the battery charger. Connecting the charger leads the wrong way around most likely damage the vehicle's electronics.
When you finish charging the battery turn off the charger before you disconnect the charger leads. This will prevent arcing between the leads and the battery.
Posted on Jan 14, 2012
Testimonial: "Thanks for your advice, Chris! In the past, I used to remove the car cables (leads) from the battery before charging it. I have read and been told that it is best to keep the charging current away from the car's electrical system. I think that I will do this as well. Do you know of anything that I should look out for or be careful about (apart from connecting the cables (leads) to the correct terminals ("+ to +" and "- to -")? Thanks very much for your help!"
john h
  • 22434 Answers
SOURCE: Do you have to take the battery out of the car to charge it with a motomaster battery charger?
its the safest and correct way to charge it but you can charge it also in vehicle
Posted on Oct 16, 2016
Tom Chichester
  • 54195 Answers
SOURCE: I have a motomaster eliminator battery charger model 11-1546 how long does it take to charge?
That depends upon what it is charging
Posted on Apr 28, 2017
t0ny_pars0ns
Tony Parsons
  • 6100 Answers
SOURCE: I have motomaster 011-1571-8 battery charger. I dropped it and some wires popped off I don't know which contacts to attach them to, do you have a picture of the inside so I can reattach
This forum is for Cameras - pl repost this query in a forum dealing with motor vehicle accessories. Thank you.
Posted on Aug 16, 2017
How many amps to charge a car battery?
most chargers these days regulate the amperage as the battery charges. My Motomaster charger starts off at 16 amps on a depleted or low battery and goes down to 5 amps once fully charged. Battery maintainers put out about 2 amps.
Jun 12, 2014 | Vector Black And Decker High Frequency...
Pioneer r-1 tablet won't turn on
Cant you just take it back to shop.
Mar 21, 2014 | Tablets & eReaders
Recharge battery Cadillac Deville 2005
Jan 14, 2012 | 2005 Cadillac Deville
My charger is not chargeing
First check if it's the charger or battery that was defective. Unplug your old charger, and test it with a known working charger, see if the problem gone, if yes, then you need to replace a new battery charger.
Razor E200 scooter battery charger
Razor E300 scooter battery charger
May 30, 2011 | Razor E200/E300 Charger
Have an eliminator intelligent battery charger model CT-1200A 11-1513-8. Can this be used to keep a car battery charged for a period of say 3 months while car is not being used. I have this same question...
Nov 27, 2010 | Eliminator MotoMaster Mobile Power...
Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Nov 06, 2009 | Eliminator MotoMaster Mobile Power...
Cell Phones Logo
2,651 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
