T-Con Board failure symptoms? - Televison & Video
  • Televison & ... Master
  • 2,800 Answers
No picture but backlights, blue screen, scrambled picture, distorted picture to name a few
Posted on Apr 04, 2018
SOURCE:
Where is the location of T CON board on NS LCD32
Cheryl, I will post links to what the T con board looks like so when you remove the rear panel from TV, you will be able to compare and find it easily.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
INSIGNIA NS LCD32 Con Board LC320W01 SLA1 6870C 0142B 2L
Amazon com INSIGNIA NS LCD32 CON BOARD CPT 320WF01C SD Electronics
Mar 23, 2016 | Insignia NS-LCD32 LCD TV
I have lines along bottom of screen
there can be two reasons for this type of symptom. the first one is t con board faulty and the second one is the lcd panel. in most of the tvs t con board is separate module in others its integrated to the lcd panel. if you you have to replace the panel too.
here i have added a video which will help you to identify the t con board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Nov 10, 2015 | Televison & Video
My TV has vertical lines
hi,
Probably the t con board is faulty. first you have to check is there is any bad contact in the connections on the t con board. Remove and reconnect all the connections on the con broad. if the problem exist even after that you have to go for a new t con board . in some tvs 32 the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
www.electro-medical.blogspot.com
Sep 25, 2015 | RCA Televison & Video
My sanyo dp42849 screen still has a picture but it has turned white. What is the problem and how do I fix it?
Sep 25, 2015 | Sanyo Televison & Video
Can you help me diagnos my problem with my Samsung tv
Probably the T con board is faulty. T con board is the one which drives the lcd pixels. Chekc the video to identify the t con board. Also try to remove the connection to T con board and reconnect it. some times bad contact on those connectors can lead to such problems.
Sep 23, 2015 | Samsung Televison & Video
I have a Vizio E320I-A0 and it has multiple vertical and horizontal lines on the screen, how do i fix that?
Sep 22, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Recently the picture became dark and heavily tinted with a reddish-brown color, how can I fix it?
Andy there are usually two inverter/backlight boards (usually on each side of the TV ) (inside the back cover). Most have Ribbon cables attached and lead to the screen. might try those. most of the T-con , inverter boards cost nearly the same.(according to the make and model of TV u have) even at $35 each it is still better that buying new TV .
Jan 27, 2015 | Sony Televison & Video
When I turn on the set, the right half of the screen is distorted. It flickers, different colors move from center to far right of screen, double images that appear as negitives and sometimes that half of...
Symptom shows problem with lcd panel (screen) however, t-con board that is part of lcd panel could be defective and cause of these symptoms.
T-Con board is located at top center of cld panel at rear and would be covered with metal shield. There are three type of t-con board utilized according to lcd panel and are available in shopjimmy.com
Please check what t- con board is similar with your tv board to order it. If you are not handy with electronics stuff repair then local tv repairman will help you to replace t-con board that might solve your tv picture problem.
Thanks.
Jan 29, 2011 | Samsung LN46A550 LCD TV
I have a Sony KDL40W4500 LCD TV which is only two years old and the TV has developed double/triple imaging, mainly on the right side of the screen. After about 15 minutes before I get a clear picture, but...
hi,
T-Con board failure or poor connection of flexible wire and LVDS cable. Sometimes these connection loosen up from their terminals. Try to unplug and reconnect these cables to refresh the connections. If the symptoms still persist you need to replace the T-Con board. T-Con board is installed on the upper side of your LCD TV and it has two flexible wire connected to LCD PANEL . stihl_070509.jpg
Jan 02, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
627 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
