Question about Apple iPad Tablets & eReaders
My screen changed from steps to calories on my iPad how do I get steps back
    Top Expert:
  • Apple Master
  • 64,728 Answers
Ask apple
Posted on Sep 30, 2019
6ya staff
SOURCE:
How to lock iPad
https://www.techwalla.com/articles/how-to-lock-an-ipad
Locking your iPad requires entering a four-digit pin every time you turn on your device.
Step 1
Select the "Settings" icon from the home screen.
Step 2
Tap the "General" tab on the left side of the screen.
Step 3
Hit "Passcode Lock" on the right side of the screen.
Step 4
Select the "Turn Passcode On" option at the top of the screen. You also can elect to change your password and when it is required.
Step 5
Enter in a four-digit pin that will act as your password.
Step 6
Select "Erase Data" if you would like extra security. This option will erase all data on your iPad if the incorrect password is entered 10 times in a row. You should carefully consider this option because it can be quite risky, especially if you tend to forget passwords.
Feb 19, 2017 | Apple iPad Tablets & eReaders
Ave a lock screen on my Ipad and cant remeber my apple ID
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPad with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPad". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Dec 04, 2016 | Apple iPad Tablets & eReaders
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
Aug 30, 2016 | Apple iPad Mini
How do i unlock my ipad i bought it used and i dont have a password and now it is locked and asking for password
You will have to restore it by connecting to iTunes on your computer. That will erase all settings including the password. If you have a backup you can get it then set up as a new device with a new password.
Sep 07, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I forgot my password, and disabled my ipad mini , and need to get back into it
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
For more methods, check: How to Reset Password on iPhone
Dec 02, 2013 | Apple iPad Mini
Ipad said disabled
please follow this step and fix it. God bless you
Corrupted software
It isn't often that Apple gives specific directions about how to fix your problem! Restoring the iPad will erase everything on it, so make sure everything on the iPad is stored elsewhere prior to restoring. To restore, connect your iPad to a computer with the latest version of iTunes installed. When your iPad appears under the devices menu, click the restore option under the summary tab. If you haven't backed up your data already, choose the back up option from the pop up window. Click the restore button to restore your Touch to factory spec.
Bad logic board
If attempting to restore the iPad and diagnosing does not fix the problem, the issue is probably the logic board.
Jul 27, 2013 | Apple iPad (16 GB) WiFi Tablet PC
How do you reset an Ipad? It's stuck on Itunes and won't reset.
Step 1
To reset the Apple iPad you should first locate the power button. This is the button on the top right corner of the iPad when you are holding it like a book, with the narrower sides on the top and bottom.
Step 2
Once you have located this button you will need to simply hold this button down for about 3 seconds or until you see the red slider icon (a red rectangle with a white arrow facing toward the right) come across the top of the screen. The slide area or the area to the right of the button will be labeled Slide to Power Off.
Step 3
If you want to just reboot to iPad you can do that by touching the red slider button and sliding your finger along the slider area toward the right side of your iPad. The iPad will automatically start shutting down, it may take it several seconds depending on the amount of space you are using on your iPad and the programs you had running when you requested the reboot.
Step 4
To turn the iPad back on or restart it after you have shut it down just press the power button (remember that's the button on the top right of the iPad).
Feb 20, 2011 | Apple iPad 32 GB 3G Tablet PC
Tablets & eReaders Logo
74 people viewed this question
Top Apple Tablets & eReaders Experts
john smith
 Mike M
Mike M
Ian_C
Level 1 Expert
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
