Question about Sansui Televison & Video
My tv doesnt want to go on.it shows the red light on the tv,but it doesnt want to switch on with remote or on the buttons
Sansui 32" led tv s/n ws 1134-397-1212 model nr: cty1232c
    Top Expert:
  • Sansui Master
  • 54,175 Answers
Open internal fuse or power supply failure
Posted on Jul 26, 2018
SOURCE:
  • 31 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
sounds like a hardware failure, let me know which model # it is and i will run through service manual.
Posted on Oct 26, 2008
its not hard to replace the bulb and you can go to any tv shop and have them order it.youll need to give them the make and model number off the back of the tv so they know what to order
Posted on Nov 03, 2008
SOURCE: Samsung WS-32Z419D 32" TV wont turn on.
THIS IS A DESIGN FAULT IN THIS MODEL AND ALL WS32Z MODELS,SAMSUNG KNOW THAT AND WONT REPAIR OR RECALL THE PRODUCT, SOMEONE SHOULD CONTACT THE FAIR TRADE OFFICE, THGOUSANDS ARE AFFECTED.
THE PROBLEM IN THE loptx THE TRANSISTOR J6920A AND THE CAP NEED REPLACEMENT AND IS AN EXPENSIVE JOB.REPORT FAULT TO SAMSUNG THEY SHOULD RECALL THESE MODELS AND REPAIR THEM OR REPLACE,AS THERE IS NO GUARANTEE THAT AFTER REPAIR THE SAME PROBLEM WONT REOCCURE AGAIN.
Posted on Mar 22, 2009
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
  • 304 Answers
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Posted on Apr 16, 2010
Hi where could I get a sansui flatview 32" remote?
Obviously you could get one from sansui or better yet try ebay they probably will have one it may be a few weeks until one or more show up. Some links to try:
Sansui TV Remote Controls
Sansui Remote eBay
NEW Orion Sansui JVC LED TV Remote Control 076E0TT011 Supplied with models... Replacement Remote for SANSUI HDLCD1909 HDLCD19WB HDLCD1909A
Feb 12, 2015 | Sansui Televison & Video
Circuit diagram
The red light indicates only that house power is getting to your TV. It is likely that the internal power supply has failed
Aug 17, 2013 | Sansui 32" TV
My Sansui 32 inch LCD TV is not working
The main digital board stopped working. No SCL, SDA. Contact any service technician.
Jul 01, 2013 | Sansui HDLCD3250 32 in. LCD TV
I need codes for my one for all remote my tv is a sansui
Hello
Three digit universal remote code for sansui TV are:
135/ 136
Four digit codes are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Feb 28, 2012 | Sansui 32" TV
My Sansui 32" Model LCD32hbw got stuck with the
Sure the power supply si working and the processor seems struck up to trigger the power but is not responding to the remote. So it is important that the main processor is checked to fulfill the working. Check for the +5 rail voltage, check for the input /output data, check the remote feed of data and the crystal oscillator.
It is possible that there is a failure around the processor or the memory.
Sep 03, 2011 | Sansui 32" TV
My tv doesnt show any images and the panel has the light of fopc on
Common problems on Sharp LCD tvs as tv it is agings,tv Power LED and OPC LED,LEDS lights flashes happen to mine Sharp tv many times and i had it two years,do this many times,tries to turn on the tv.By trying pushes the power button the remote again if OPC LED and power LED,LEDS lights flashes together.Everytimes the OPC LED and power LED lights flashes,just push the power switch on the tv remote and wait for the tv main Tuner signal board to kick in the backlight to light up tv to work.Have to do this like three or four times before the power supply board to kick it in to make Tuner signal to work.If u require to this more than 5 or 6 times the main tv Tuner signal board it is shorting out and beyond trying to kick in by the power supply board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
May 31, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
Our Sansui 32 inch 3212 has a blacked out triagular area in the middle of the tv screen that comes and goes. What could be the issue.
U still have Closed Captioning functions are on.Check ur remote control for a button that said CC.Used that button pushes couples times for all CC1,2,3 to off.Should have no more black squares showing up the tv screen again.
Dec 24, 2010 | Sansui HDLCD-3212 32 in. LCD TV
I need a code for my universal remote i have a sansui tv
I recommend using the auto-search function of your remote.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Jul 11, 2009 | Innovage Jumbo Remote Control
Sky code for a goodmans gtvl19w17 hdv
Try this : Turn TV on, point remote away from TV, press TV button on your SKY remote...hold down SELECT and the RED key together for about two seconds, until the red light (LED) on the remote blinks twice...key in the remote code for your model of TV on the remote keypad ( for Goodmans, try 065, or 0335 ) then press SELECT button ( the LED should blink twice to show code accepted ) press SKY button to exit. point remote at TV and test.....Job Done . !
Nov 19, 2007 | Goodmans W280NS Television
Televison & Video Logo
80 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
