Question about Panasonic Cameras
Suddenly my panasonic dmc-fx100 shows overexposed pictures (bright white field with pink surrounding) Any idea what might cause this?
SOURCE:
montecarlo
  • 50 Answers
SOURCE: Why are all my pictures pink
put everthing in auto and you will do fine
Posted on Nov 11, 2007
  • 280 Answers
SOURCE: Pink where theere should be white picture
It my be the gama board. It is hard to tell sometimes the logic board can be at fault.
Posted on Jul 10, 2008
  • 34 Answers
SOURCE: White parts of picture turn bright pink after about 30 minutes
sounds like red pixelation. contact vizio and describe your problem. use an alternate input and try to duplicate problem but you may have a bad main board and or av connector. check with vizio some parts are lifetime warranty and free service call. hope this helps, j
Posted on Apr 08, 2009
jyackle5
  • 8197 Answers
SOURCE: lost manual panasonic dmc-fx100
You can download the manual here.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FX100K
Good luck and please rate FixYa!
Posted on Apr 12, 2009
  • 11967 Answers
SOURCE: panasonic lumix dmc-fx100 problem
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 10, 2010
Camera makes overexposed pictures wiht lines can this be a software problem ?
Nope, this is a hardware problem and the camera needs to be worked on. Notice how your display works fine but the finished product exhibits the anomaly. The recording end is messed up.
Aug 12, 2015 | Panasonic Lumix DMC-TZ7 Digital Camera
Software download panasonic lumix dmc-fx100
If you are missing the disc you might also be missing the user manual for your device, so besides downloading the software I suggest you also download the user manual:
Panasonic DMC FX100 manual
Nov 11, 2012 | Panasonic Lumix DMC-FX100 Digital Camera
Someone was looking through my photos on playback mode on my panasonic DMC-FX100. Then gave it back and now it says "no valid picture to play". not sure if they multi deleted everything. No photos are...
It's no problem at all to get them back. Please see this post for several free software that you can download. You'll need to use a card reader with these programs though:
All the download links listed in the article are through CNET, primarily to verify that these are malware free software, and to give you a chance to read user reviews on the software before downloading.
Sep 12, 2010 | Panasonic Lumix DMC-FX100 Digital Camera
When i export my pictures the videos remain on my camera..what am i not doing right?
The pictures do not get deleted automatically when you export them. You have to delete manually.
Jun 30, 2010 | Panasonic Lumix DMC-FX100 Digital Camera
Lens sticks out when lumix dmc-fx100 turned off
disassemble the len unit,replace the broken parts and assemble,if u can do OKif not get it done by camera tec.
Mar 09, 2010 | Panasonic Lumix DMC-FX100 Digital Camera
Pictures taken indoors now have white clouding
hmm it would be easier if i could see this for you
I suspect you have got it on the wrong setting and it is overexposed. Have you got it on auto? what ISO (film speed) is it set too if you set it too low any bright liht will cause clouding like a film of white milk on the screen. Set it to 64 or 100 and the aperture to F8 and take a pic to see if it improves.
Please ratew our help to keeep free service online ++++
Aug 30, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
SHOWS TURN OFF-ON THE CAMERA VERY OFTEN WHY? when I take pictures or when I´m reviewing the pictures.
your batteries may be low.. recharge them or replace them with the new ones.. if your problem persists i am here.. let me know/.
Jul 10, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
Panasonic dmc-fx100
The manual can be found in the link below.
DMC-LZ2 Instruction Manual
Mar 26, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
Cameras Logo
66 people viewed this question
Top Panasonic Cameras Experts
rajiv6089
Level 1 Expert
AJMAL KHAN
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
