Question about Toshiba Office Equipment & Supplies
I have an error code CD 40 on a Toshiba estudio 2540. Do you know what this code means. Thank in advance. Joe
  • Toshiba Master
  • 727 Answers
Do u mean CE40? Because there is no CD40 error code...
CE40 is image control related service call where the image quality control test pattern abnormal.
Image quality control abnormal detection display/0 clearing
08-2528 Y
08-2529 M
08-2530 C
08-2531 K
From above u know which process unit giving problem, then further check the main charger, developer...
Posted on Oct 12, 2018
SOURCE:
  • 56 Answers
SOURCE: error codes
3-333 communications failure between the Foreign Interface
and the machine.
Press 0 and start button at same tame.
Enter 6789 and select confirm. Select dc 131 NVM read/write.
select input number an type:
752-002 0 = Foreign Interface disabled 1 = Foreign Interface Enabled
759-015 1 = Addition Device (Auditron) 2 = Subtraction Device (Debit card)
if you want to see current value select "read"
Posted on Nov 02, 2007
  • 1126 Answers
SOURCE: Toshiba estudio 166 C44 error code
Hold "0" and "8" while turning on machine.....continue holding until machine enters service mode. Enter "400" press enter. Enter "0" press enter. Power off / on. If code returns, machine needs parts replaced. Do Not keep resetting, may cause damage to Fuser Unit.
Posted on Sep 14, 2009
mce_sys
  • 41 Answers
SOURCE: toshiba estudio 4511 error code C440
Press 0-8 then enter 400 and make it 0 then press print switch, if doesen't work u have to change thermostar, then if not working change heater, if not then IH board, and the last solution is to change the system board.
Posted on Jul 24, 2010
  • 132 Answers
SOURCE: toshiba estudio 351c error code
Hi
I hope that this will help you
[CE40] Image quality control test pattern abnormality
(1) Use "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576)"to check the abnormal occurring condition for each color.
(2) Check "Output value display of image quality sensor / Low-density pattern (05-391-0 to 3)" to
check if the low-density pattern abnormality occurs for each color. The values under 320 for Y, M
and C, and under 220 for K are defined as low-density pattern abnormality.
(3) Check "Output value display of image quality sensor / High-density pattern (05-390-0 to 3)" to
check if the high-density pattern abnormality occurs for each color and identify the color which
pattern is abnormal. If the value is 630 or above, it is defined as high-density pattern abnormality.
(4) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "0" (Invalid).
(5) Perform "Enforced performing of image quality open-loop control (05-394)".
(6) Output the image quality control test pattern (04-270) more than one time and check the patch of the color identified in step (3) to see if the image is abnormal.
(7) Replace the image quality sensor.
(8) Set the values of "Image quality closed-loop control / Contrast voltage (08-556)" and "Image
quality closed-loop control / Laser power (08-557)" to "1" (Valid).
(9) Perform "Enforced performing of image quality open-loop control (05-394)" and make sure it is
completed normally. (Error [CE40] does not appear.)
(10) Clear all "Image quality control abnormal detection counter Y to K display/0 clearing (08-573 to 576).
Good Luck
Regards
Posted on Apr 12, 2011
To clear the code error c413 of Toshiba estudio 2505
How do i clear the error code C413 at Toshiba estudio 2505 thnx, regard asif ali
Feb 08, 2017 | Toshiba Office Equipment & Supplies
Error code C440
Toshiba eStudio 355/455 Full Service Manual - Tradebit.com
https://www.tradebit.com/.../155135538-toshiba-estudio-355-455-full-se...
Download Toshiba eStudio 355/455 Full Service Manual ... Configuring DepartmentCodes Configuring ... TSB-1013: C440 Error - Countermeasure .... DIG-ACC-145: MJ-1025 Bracket Change to Enable Installation on e-STUDIO205L/255/305
Aug 08, 2015 | Toshiba E-Studio 305 Digital Copier
C415 error code in toshiba estudio 2505f
This is a fusser related error code..
Oct 14, 2014 | Toshiba estudio 255 Copier
I have a toshiba estudio 2500c. I have error code C3B0. How do I fix it without calling a service person?
I have a toshiba estudio 2040c. I have error code C3B0. How do I fix it without calling a service person?
Sep 08, 2011 | Toshiba E-studio 2500c Color...
Toshiba Estudio 35 with error 424817
Yes I hate to say it but that is your total copy count. Now the problem is if your system is hooked up to a computer. Yes we need to know!!!! You might need to do a system restore.
Nov 04, 2008 | Office Equipment & Supplies
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
167 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
digivisionm
Level 1 Expert
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
