Question about Coffee Makers & Espresso Machines
HOW DO WE CLEAN OUR MR COFFEE ??? - Coffee Makers & Espresso Machines
    Problem Solver:
  • 5 Answers
White vinegar is the perfect solution to clean coffee maker but you will need to clean it under running water.
Posted on Jan 12, 2019
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
I've never used that type of coffee maker before, bit I run a safe cleaner or just water only through the coffee maker. It will sanitize it.
Posted on Oct 12, 2018
5 Suggested Answers
  • 14 Answers
SOURCE: Mr Coffee clean light on. i threw out instructions.
What is the model number off your coffee maker and i shall e-mail you a manual
Posted on Mar 12, 2009
  • 161 Answers
SOURCE: I have Mr. Coffee 12 cup programmable coffee
I didn't think the D-link router actually had a clean light. ;)
my coffee pot flashes its light to let me know it needs cleaning. I just unplug it for a few seconds and the cleaning reminder goes away.
Posted on Nov 07, 2009
Testimonial: "IT WORKED! Thanks so much"
wiringlunati
  • 576 Answers
SOURCE: What can I use to clean my Mr. Coffee 12-cup
The standard way to clean a coffeemaker is t run white vinegar through it then run straight water through it. That is one of the few things that will clean without leaving a residue. Good luck.
Posted on Jan 05, 2010
  • 8909 Answers
SOURCE: I have a mr coffee
Spirit vinegar is not only perfect for the job of descaling but environmentaly friendly.
Posted on Jan 01, 2011
How do I get a manual for my Mr Coffee BVMCPSTX91-WN? the clean light is on and I don't how how to clean it or how to get the light off
The Mr Coffee web site has the manual on the product page: http://www.mrcoffee.com/coffee-makers/mr.-coffee-optimal-brew-10-cup-thermal-coffeemaker-black/BVMC-PSTX91.html . Click on the Service and Support tab. The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1426159971356/documents/instruction-manuals/BVMC-PSTX91_43_72624326.PDF . (You'll need Adobe Reader or a similar program to print the manual.)
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
Mar 12, 2015 | Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM"
The red light on my coffee pot is on and will not go off. I have run cleaner thru the regular cycle now what? Its a 12 cup programmable Mr. Coffee.
I know this sounds like a pain but it takes a while toget that silly light to stop. Decalcifying your MR. COFFEE® Coffeemaker Minerals(calcium/limestone) found in water will leave deposits in your coffeemaker andaffect its performance. It's recommended that you regularly remove these depositsusing MR. COFFEE® Cleaner or vinegar. MR. COFFEE® Cleaner is available at manyretail stores or by calling the MR. COFFEE® Consumer Service Department at 1-800-MR COFFEE(1-800-672-6333). 1. Follow packageinstructions to prepare one batch of MR. COFFEE® Cleaner. Pour the mixture into the water reservoir. Before decalcifying,remove the water filtration disk from the machine. NOTE: 4 cups or 20 fl. oz. of undiluted, white householdvinegar may be used as a substitute for the cleaner. 2. Place an emptyMR. COFFEE® 10-12 cup basket-style paper filter or MR. COFFEE® permanent filter into the filter basketand slide the brew basket in place. 3. Place theempty decanter back in the unit. 4. Press theCLEAN button until the CLEAN indicator light turns on (Figure 9). For your convenience the cleaning cycle isautomatic. The entire cycle will take 45-60 minutes to complete. During thecleaning your coffeemaker will: a. Slow brewapprox. 3 cups of cleaning solution. b. Pause for 30minutes (the CLEAN light will remain on to alert you that the process is active). c. After 30minutes, your coffeemaker will brew the remainder of the cleaning solution. d. When complete,the CLEAN light will turn off and your coffeemaker will turn off. 5. Discard the cleaning solution and rinse the decanterthoroughly with clean water. 6. Fill the water reservoir with clean, fresh water. 7. Place the empty decanter back on the coffeemaker. 8. Remove and discard the paper filter usedduring the cleaning cycle. If a Mr. Coffee® permanent filter was used during cleaning, remove it andrinse it thoroughly before replacing it in the filter basket. 9. Begin brewingand allow the full brew cycle to complete. 10. Repeat steps 5 through 9 one more time.
Mar 31, 2011 | Vacuums
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
9. Begin brewing and allow the full brew cycle to complete.
Mar 27, 2011 | Microwave Ovens
Mr.coffee LMX43 clean light on. will not go out
plug it out for 1 hour and plug it in back.this done so that the coffee maker circuit can reset itself.good luck.if that does not work the coffee maker needs to be taken down and clean.
Mar 04, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Cleaning
How do I clean my mr. coffee?
Jun 03, 2010 | Mr. Coffee AD4-2 Coffee Maker
What can I use to clean my Mr. Coffee 12-cup coffee maker?
Jan 05, 2010 | Mr. Coffee FTX24 12-Cup Coffee Maker
MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Oct 11, 2009 | Mr. Coffee 12-Cup Programmable Coffeemaker
Mar 12, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee TFTXC85
run 2 cups of vinegar through the coffee pot brew it do it twice. this will clean the calcium out. then rince out out and brew one batch of water to clean.
May 22, 2008 | Mr. Coffee TFTX85 Coffee Maker
Coffee Makers & Espresso Machines Logo
56 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Kolbrun...
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
