Trying to download my data on my pedometer and keeps giving me Line 6: opening and ending tag mismatch hr line 5 and body how do i fix this
    Sergeant:
  • Computers & ... Expert
  • 179 Answers
Why not copy the file and open it in notepad, its clearly some form of text or xml file. maybe its using a old format or a newer format which has extra fields
Posted on Oct 26, 2018
6ya staff
SOURCE:
emissionwiz
Marvin
  • 85206 Answers
SOURCE: vacume line
This is the power brake booster vacuum line, the little round thing is a vapor separator to keep gas from entering the brake booster and destroying the rubber diaphragm, the line goes to the intake manifold near the rear of the manifold, the length of the vacuum line is a good guide to where it hooks up, if you run the engine you will hear a very loud vacuum leak to say the least.
Posted on Nov 05, 2008
NextStepComp
Brad Hays
  • 185 Answers
SOURCE: XML Parsing Error at 2:32. Error 76: Mismatched tag
what website? This is a programming error that needs to be sent to the administrator.
Posted on Dec 31, 2009
supertech6
John Street
  • 513 Answers
SOURCE: My 2610xi suddenly is keeping the phone line open.
You are describing a FAX modem failure. You need the fax board replaced in the printer.
Posted on Apr 21, 2010
consultel1
george peters
  • 860 Answers
SOURCE: I NEED TO SET UP 4 PHONES TO HAVE A LINE 5 AND A
Programming is done on M7310, M7324 and T7316 sets.
To set up line appearence you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt,
press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the next key (bottom right arrow) till it says 025(or 031):unaaign press the chng key till the screen says appear&ring
Press the next key(bottom right arrow)
The display should say line 026(or 032): unassign
repeat the procedure the same as line 5 for line 6
press the release key when finished
Posted on Jun 24, 2010
Ed Mac
  • 731 Answers
SOURCE: how do I create a
Go here to download the user's manual
http://global.dymo.com/enGB/Manuals/LetraTAG_QX50.html
Posted on Feb 08, 2011
Where do I attach my Tag Master Pedometer with light for best results
Most pedometers need to be several inches from your center body or directly in line with your knee to accurately record the number of steps you take each day. The pedometers work by using a pendulum which moves the counter as you move forward or backward. Use the provided clip attachment to secure the pedometer to your waistband or belt. Walk for about 20 steps, stop and check the pedometer for accuracy. Adjust it closer or farther to your naval until the counter is accurate. If you have a large abdomen, secure the pedometer to the back of your waistband and recount your steps.
Sep 11, 2013 | Tag Master Pedometer with Light
How do I set up the GNC ProTrack GF-0008 Digital Pedometer Plus Body Fat Monitor:
I just won one from GNC and not sur if it is working properly, because screening is flashing in some type of error mode. removing battery was only way to reset.
1. First normal screen is the time display. (only shows 3 numbers.)
2. Press "set" then up/down for correct time.
3. after setting time, press up/down for 12h/24h format
4. Press "mode" & NO 1 flashes, showing Wt 50 Kilo & Man
5. Press "Start" and place one thumb on each end of unit to auto-read body fat.
6. Set weight in Kilos (not sure how to convert unit to lbs, before setting, so maybe use online converter.
7. Set ht, age, man/woman, stride, using up/down arrows.
Follow process for users 2-5,
Mar 07, 2013 | Generic GNC ProTrack GF-0008 Digital...
I have a 2000 durango 5.9 rt I have a miss cyl #6 I have done every thing to try n fix it here is the list. New intake and plenum gasket injectior leak down test only lost 5% in a half hr compression test...
Now please forgive me here as i do get amolished by other mechanics for trying to answer questions on american vehicles when iam in spain no iam not going to wind you up tonight by saying the world is round .anyway what i would do here is to ignore it as you have a distributor cap so how can the ECU sense no 6 misfire when its not connected to it i mean you could move the distributor and then change the leads round in the cap and would you still get the same code ,well i think you would and what i suspect is a mismatch of ECU where the line finished using distributors and went onto coil packs but you got the later ECU like friday night monday morning built car and having worked on a car assemble line at 18 yrs of age beleave me on this ,Just ignore the light or take the bulb out and clear the light when you go for the inspection as i do feel you are worrying about nothing and a little knowledge can be expensive or listen to the bar room mechanics who know a bit with one beer and are top motor vehicle technicians with 3 beers .If it runs ok and doesnt misfire or run lumpy leave well alone and do not play around with it .
Mar 03, 2012 | 2000 Dodge Durango
Hi, Can any body help us? We have a M7324 on a Norstar Compact with two line pools, Pool A is on Line 1,2,3 and Pool B on Line 4,5. We want to add another line on Pool B so I tried configuring Line 6 which...
On the cross connect do you have a CO connected to that line. That is most likely the cause of no dial tone. If you don not know how to check that call a phone system expert to connect and verify your system.
Feb 15, 2011 | NorStar M7324 Telephone
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
(Make sure your toy is powered on.)
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Jul 02, 2010 | LeapFrog Tag Reading System
Where in the HTML do I paste the Google Analytics tracking code? I pasted it just before the '[/body]' tag at the end of the template, but the status on the overview page is "Tracking Unknown". I use...
It'll take 24 to 48 hours for google to start receiving Analytics data from your blogger.com
If you cant wait 24 hours for Google to find it by itself? Follow the steps below to fix it, but please make sure the tracking is already installed correctly like in the image below, before proceeding at all! (Paste the code above body tag) d4b4322.jpg
1)Sign in to Google Analytics and select your site. 2)Find 'Edit' on the end of the bar: 66bfd3e.jpg
3) At the top of the page, on the same line as 'Profile Settings', you'll find something that says 'Tracking Unknown ( Check Status )' e569def.jpg
4)Simply click 'Check Status'; if your tracking javascript is installed, Tracking Status: will turn into something like "Loading" and after a while, it will be successfully tracked!
If not, check your code in blogger.com and try repasting it.
Feb 07, 2010 | Google Analytics
Dec 29, 2009 | Computers & Internet
Table Mismatch Download Again
This is the only Solution to "Table Mismatch"...
If a “Table Mismatch” is displayed, recycle power and reflash the printer. Can get “Table Mismatch” after replacing CMX Board.
“Table Mismatch”
Flash Upgrade Instructions Using the printer’s Parallel Port: You have ethernet, you can FTP download.
1. Print a configuration on the printer prior to the download. After the flash is upgraded, the printer will be at Factory settings and you will need this printout to restore any non- default settings.
2. The PTX flash code is on a CD you should have received with printer. Don’t have? I can email you the Flash program.
3. Turn the printer's power off.
4. If there is a cable connected to the printer’s serial port, disconnect it.
5. Connect a cable from the LPT1 port on a PC that has a DOS prompt mode to the printer’s parallel port.
6. While holding down the Online & FF(Paper Advance) keys, power up the printer. The printer will display "Waiting for Program Download".
7. At the PC’s DOS prompt, go to the directory where the file is located C:\Temp and
type "filename.exe -pb<ENTER>" where filename is the name of the file that you downloaded in step 2.
NOTE: there is a space before the -pb
8. The printer's display will keep you informed of the status of the download. When the download is complete, cycle the printer’s power.
May 15, 2008 | Printronix Line Matrix P5215 Printer
Table Mismatch Download Again (Printronix P5215)
hi
i have an error " tabel mismatch download again" on my printonix p1000q1
how can i solve it please help me as soon as Possible please help
Sep 14, 2007 | Printronix Line Matrix P5215 Printer
Open Questions:
AOL MAil CuStOMeR {1-855*536*5666}#O@ Service PHoNe NuMbER OREGON call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Nov 12, 2019 | AOL Computers & Internet
AOL MAil CuStOMeR {1.~855:.536**5666}#O@ SuPPoRt SUPPORT NUMBER call or contact AoL mAiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL mAiL USA Calling AoL mAiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL mAiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL mAiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL mAiL USA's phone numbers against each other. Contacting AoL mAiL USA in General WhileI:855:,:5365666 is AoL mAiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I:855:,:5365666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL mAiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL mAiL USA.
Computers & Internet Logo
Ekse
Marvin
Marvin
