Question about Samsung Galaxy Cell Phones
I have recently migated from a ADSL line to a Fibre line. My Samsung S7 conects to Wi Fi but drops the connection almost immediately. What setting should I change. Thank you, Wynand Marais
  • Samsung Master
  • 5,331 Answers
How far away?
to router are you ,? is it a new router with FIOS (fiber)
we can't see what you have there.
learn your credentials on the router
and set your S7 to that.
ssid
wpa/wpa2
and passphrase matched.
Posted on Oct 30, 2018
    Sergeant:
  • 179 Answers
You might try connecting using WPS instead if your router has a WPS button. Others say their s7 does not detect/connect to 5ghz signals. it might be possible under the advanced settings on the S7 to FORCE 2.4ghz connection to check if thats more reliable. It is common for wifi chipsets to not like each other. Most routers are Dual Signal capable and Its worth looking at the router settings to see if you can also switch on GUEST signal for OLDER devices. Galaxy S7 How do connect to Wi Fi on my Samsung Galaxy S7 Samsung Support...
Posted on Oct 29, 2018
6ya staff
SOURCE:
Anonymous
  • 146 Answers
SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 15, 2008
Anonymous
SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
Posted on Apr 18, 2008
Anonymous
  • 92 Answers
SOURCE: Wi fi on ACER Aspire 4810T connects intermittently
Log into your router and change the channel and see if that helps. Failing that try rebooting the router to factory settings and deleting your connection from the laptop. Then start from scratch again...Hope this helps...Please let me no...
Posted on Nov 18, 2009
darkpain
marios basileiou
  • 316 Answers
SOURCE: I can't connect to my wi-fi settings
Activate and connect to a WLAN
1.In range of WLAN network, access an application or menu that needs a wireless connection.
2.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
3.Press <Menu> → Turn On Wi-Fi.
The device will display available WLAN connections.
4.Select a network profile from the list.
The device will attempt to connect to the WLAN.
5.Select a network type and press <Next>.
6.Enter a pre-shared key for WLAN and press <Next> or <Finish>.
7.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type and press <Finish> (if necessary).
Create a new WLAN
1.On the Home screen, press <Start> → <More> → Settings → Connections → More... → Wi-Fi.
2.Select New...
3.Enter a network name, configure connection settings, and press <Next>.
4.Enter network authentication settings and press <Next>.
5.Set the IEEE 802.1x access option and the extensible authentication protocol (EAP) type (if necessary).
6.When you are finished, press <Finish>.
Posted on Jan 08, 2010
virtualhost
virtualhost
  • 2185 Answers
SOURCE: My Samsung Galaxy 3 -
To be able to find out the MAC address of your Samsung Galaxy phone, please do the steps below:
1. Press the Menu button, under the display on the left hand side.
2. A menu panel appears onscreen. Press Settings.
3. The phone's Settings menu appears. Press Wireless Controls.
4. From the Wi-Fi Controls Menu, press Wi-Fi Settings.
5. Press the Menu button (to the left under the display).
6. A menu pops up onscreen. Press Advanced.
7. The 12-character MAC address is listed in this menu.
There you go, you just have to add the MAC address where required in the appropriate place in the Wi-Fi router's configuration set up.
Please let me know if this helps you. Thank you for using FixYa.
Posted on Oct 13, 2010
How do I connect my Visor Go R57 to Samsung Galaxy S7
Samsung Galaxy S7 EDGE Plus comes with with Android Oprating System Quad core cortex A57 & Quad core cortex A57 Processor, 64GB internal storage, 4GB RAM, No SD Card Slot, Super Amoled LCD capacitive 2560 x 1440 pixels, 5.7 inches touchscreen, 16M colors, 20.7MP pixels, autofocus, back Camera, GPS, Wi Fi, 3G and 4G Suported Smartphone by Samsung. Samsung Galaxy S7 Edge Plus UAE Dubai Price of Smartphone amp... http://www.mobile57.com/ae/phones
Mar 28, 2015 | Samsung Cell Phones
How to enable my netgear DG834G v4
By setting it up . Do you have the instruction manual this would be a good starting point. Although you did not give a lot of information I will offer you a bit of information. This router is an ADSL router so you need to have an internet service provider that can provide ADSL on your phone line. Once you have an internet service provider give them a call and ask them to guide you in how to set up ADSL and connect this dg834G router to their network. ADSL requires ADSL line filters on all phones. While you are setting up the ADSL you might want to also setup encryption on the WI FI settings security and give it a network name. in the router.
Jan 03, 2015 | NetGear Computers & Internet
My big pond login
Go back into WiFi, select Connect. The information for your WiFi connection should still be there, usually the strongest signal or the one nearest the top of the list. Otherwise, when you set up the iPad it should have taken a backup of all the settings. You can go into iTunes and do a restore from the most recent backup.
Jul 21, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Galaxy samsung phone. He can't find wi-fi
He should read the manaul or call his cell phone provider's tech support.
If he still can't find wi-fi the wi-fi is turned off or hidden which can be corrected by the person who manages the wi-fi acces point.
I hope this helps him.
Jun 16, 2011 | Samsung Galaxy S GTI9000 Smartphone
I have a ASUS RT N10 Wi-Fi Router. I connected the wi-fi Router to my Desktop after-which I am not able to access the Internet. If I connect my desktop directly to my ADSL Modem, I am able to connect to ...
Check to see if you can plug the wan port to your adsl modem and then plug your pc to the router. on ADSL, some ISPs will record your mac address to avoid sharing. Just see I your router supports cloning your mac. All you do is login to your router from your pc, and it should be under your Wan settings. Use DHCP unless specified otherwise, and ensure to enter any pptp login info if your ISP provided any.
Dec 27, 2017 | ASUS EZ N Wireless Router up to 150Mbps...
Does LG E500 Have built in wi-fi? if so how do I activate it. trying to set up ADSL
Yes it has Wi-Fi. go to control panel/ network connections right click your wireless connection and view available wireless network
Jan 23, 2010 | LG E500 Express Dual Series Notebook PC
Nov 17, 2009 | Acer TravelMate 4062WLMi Notebook
How do i connect my samsung jet to the internet through wi-fi
Hi, The basic is: 1. On your home screen, click on the bottom right "menu" button. 2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings" 3. Click on "application settings" 4. Click on "Browser profiles" 5. At the bottom right you should see: "Search for wi-fi". Click on it. 6. It will now serch for your home wi-fi network. 7. Once it find your network, click on it and enter your security detail. 8. Now you network is listed as part of the Browser profiles. 9. Now you can select your wi-fe network as your default browser profile.
Now when you open the browser it will try to conect to your wifi to start browsing.
Enjoy :) Ed
Oct 27, 2009 | Samsung Jet S8000 Cell Phone
Samsung jet s8000
The basic is: 1. On your home screen, click on the bottom right "menu" button. 2. Got to the 1st screen , where the little gear icon for "settings" is at the bottom right corner. Open "Settings" 3. Click on "application settings" 4. Click on "Browser profiles" 5. At the bottom right you should see: "Search for wi-fi". Click on it. 6. It will now search for your home wi-fi network. 7. Once it find your network, click on it and enter your security details. 8. Now you network is listed as part of the Browser profiles. 9. Now you can select your wi-fe network as your default browser profile.
Enjoy :) Ed
Sep 19, 2009 | Samsung Jet S8000 Cell Phone
Cell Phones Logo
118 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
