Question about Refrigerators
Fridge is on but not getting cool We can hear the sound of the fridge machine
    Top Expert:
  • Refrigerators Master
  • 6,265 Answers
Probably sealed system blockage or leak if compressor is running
Posted on Jan 10, 2019
the dr
  • 447 Answers
SOURCE: Freezer
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Posted on Sep 27, 2007
SOURCE: GE Fridge...no longer freezing or cooling food!!
Had to call in the experts...needed a defrost heater and 2 sensors.Hope this is helpful to anyone w/ a similar problem.
Posted on Jul 26, 2008
  • 479 Answers
SOURCE: Maytag Performa Model # PSB2151GRW Fridge is
the exach reason for this problem is listed here please know the problem
Compressor won't run or it is "clicking' on and off: This normally could be a bad start relay and over load for the compressor, dirty condenser coils need cleaning, condenser fan motor is not running or the compressor itself. To check the compressor properly you should test it with an amp meter, each compressor is rated in running amps ( see model/serial tag or the sticker on the compressor )...if the compressor is drawing too much current, this may be why it is shutting off. Check the model tag for proper amp rating. Some relays will be easy to notice the broken with them, they may be burnt. Example one, example two, example three. Some of these relays can be removed and give them a little shake, and if they rattle around inside the relay is likely bad. Compressors can also seize and click on and off or one of the electrical windings inside the compressor could have opened up. You can use a test cord to help check the compressor and this also will help with the amp test. If the compressor checks ok and you want to install a replacement start relay. You will need to find out which winding is which. You will need an ohm meter to determine the windings. First check to see if you have windings in the compressor. Then check to see if they are grounded. If the compressor has windings and they are not grounded, you can find which winding is which. Check for grounded windings by reading from each terminal to a good ground on the cabinet. Read from the top terminal to the lower left terminal. Read from the top terminal to the lower right terminal. Read from the lower left terminal to the lower right terminal. Write down the resistance of each reading as you go. The highest reading you get will be the run and start winding of the compressor in series with each other. The other terminal left will be the common terminal. Read from the common terminal to each of the other terminals. The terminal with the lower resistance will be the run winding. The higher resistance the start winding. Using the original style relay is always preferred, but using a general replacement can "get you by" if needed
or
Older refrigerators had electric heaters on the edges of the refrigerator cabinet to help prevent moisture from building up, especially in the hot/hazy weather in the summer time. These electric heaters usually had a switch where you could turn them on or off...had words like..."switch here to prevent moisture"...switch here in damp weather".... in the picture it is in the top left of the control assembly.
Then along came the energy crunch. The manufactures stopped using the electric heaters and started running a pass of the hot condenser tubing on the edges of the cabinet where the electric heaters use to be. This is often called a yoder loop tube SxS version and the yoder loop tube Top freezer version. This has now replaced the electric heaters. If you feel heat/hot around the door opening of your refrigerator you should....
- clean the condenser coils as a dirty condenser can make the tubing hotter than normal
- check/clean & replace if necessary the condenser cooling fan ( # F ) motor, if the condenser fan motor is slow or has quit the yoder loop pass will get very warm/hot to the touch
- If the condenser coils are clean and the condenser fan motor is running ok, check the fresh food and freezer section temperatures...if the refrigerator is not operating well and the temps inside are warming up, you could feel more heat/warmth than normal
Posted on Oct 02, 2008
SOURCE: Not cooling
Cooling fan, behind internal plasic panel is frozen up, happens with me regularly, self defrost function not working properly, i'm just fixing mine as I write. I have found that bottom drain hole was all full of ice also. Have cleared with anti-freeze/hot water till runs through. Take out all shelves, remove back panel, there are screws behind chrome bezel and also inde-odoriser recesses (those two square plastic covers). Unscrew plastic water chiller, be careful not to damage pipes. Remove the back platic moulding, unclipping wire connectors and cooling fan is fastened to back, it will be frozen up with ice! I use hair dryer/ de-icer to thaw, dry off as much as possible. Beware, moulding is mainly polystyrene, i.e fragile. I suspect that I keep getting problems because I didn't clear out the bottom drain hole, so it did not defrost. Tell tale sign is noisy fan (hitting ice) which eventually freezes up and stops blowing cold air which causes fridge to stop cooling, compressor still works though!
Posted on Jul 29, 2009
aasc
  • 1606 Answers
SOURCE: freezer defrosted completely. fridge is barely
The compressor relay is bad on the main control board . Unplug the refrig and pull the refrig out and remove the 8X10 small panel on the back . You will see a blue plug with 3 larger (120v) wires going to it . Remove this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . (this is on the plug NOT the board ) . Using a short piece of insulated wire , with about 1/4" stripped off both ends , insert 1 end into wire1 and the other into wire3 . Plug the refrig back in . This will start the compressor to verify the main control board is bad . Pt # WR55X10942 .
Posted on Aug 20, 2010
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Fridge not getting cool and i do not hear it running but has clicking sound
replace the ptc overload/relay mounted on the side of the compressor in the rear area of the unit,it helps start and operate the unit,thats where the clicking sound is coming from
Oct 16, 2012 | Magic Chef MCBR360HW 3.6 cu. ft. Compact...
Fridge is not staying cool but freezer works and we can hear noise in the back..sound like fan is running
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 11, 2011 | Kenmore Side by Side Refrigerator
Fridge side not cooling i have unplug for a minute and plugged back in starts fine and then i hear a click sounds like compressior is running but not getting cold
first off what is the brand name and model number?is the freezer cold?if so when you open the freezer door do you hear the fan blowing?all a fridge does is get cold in the freezer and the evap fan blows cold air from the freezer to the fridge side that's it,if you don't hear the fan when you open the freezer you have a bad evap fan motor,but send more info.
Apr 09, 2011 | Refrigerators
Whirlpool Mod ET18LKXHWo o Fridge not freezing,
Your defrost timer located inside the control panel is bad OR the defrost thermostat located on a freezer coil is bad.
Get down low and look up at the bottom of the control panel.
You will see a small round hole. Onside the hole is the defrost timer advance knob.
Use a flat blade screwdriver and SLOWLY turh the slotted knod clockwise until the refrigerator clicks off.
Wait a few minutes then open the freezer door and listen for a sizzling sound from the freezer compartment.
If you do hear a sizzling sound that would be the defrost heater melting ice.
If you do not hear a sizzling sound,unplug the refrigerator and remove the rear freezer panel to expose the cooling coil.
Clipped to the coil will be the defrost thermostat. It will need replacing.
If you do hear the sizzling sound the defrost timer will need replacing.
Jul 20, 2010 | Whirlpool Refrigerators
I hear a fan sound coming from my fridge
Ice is buiding up because the defrost is not working right...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | Samsung 25.8 Cu. Ft. Side-By-Side...
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Fridge not cooling
How old is your refrigerator? Is it still under warranty?
Jun 18, 2017 | LG LFD22860 Stainless Steel Bottom Freezer...
Kenmore fridge not cold
You might have to have a repairman check the charge of freon in the system.
Nov 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
