Question about Cameras
Put new battery in camera can,t sync it is camera bad
  • 79 Answers
Give IT a reset..
Posted on Jan 11, 2019
SOURCE:
Why is my camera, coolpix l25 advising "battery exhausted" with brand new batteries, never had this message before?
First, I would check your batteries. Even new ones can be bad; you don't know how long they sat on the shelf. If you have a voltmeter, you can measure the output. If you do not, start by removing the batteries and making sure that the battery contacts in the camera and on the batteries are clean. If they are dirty. A new pencil eraser can be rubbed against the contacts to remove any oils or residue. Next, I would make sure your batteries are charged. A quick way is to check is to take them out and put them in another device that takes two AA batteries and see if it works. If the batteries are bad, put two new alkaline (non-rechargeable) batteries in your camera to see if it powers up. If it does and you wish to use those batteries, be sure to go into your menu and set the camera to use alkaline batteries because there voltage output is slightly different from rechargeable batteries . Remember that you cannot recharge those batteries and trying to do so can damage your charger and cause the batteries to explode. If the camera will not power up with new batteries, the camera will need to be sent in to Nikon USA for repair (see the Nikon website for information). If the camera powers up with the substitute batteries, either your rechargeable batteries have gone bad or you camera's battery charger is defective. For problems with the internal charger, it is probably more cost effective to buy an external battery charger then to send the camera in for repair unless your camera is still under warranty. External battery chargers are available for under $20. There is one other possible cause of battery failure. If the camera's internal circuitry has an electrical problem, especially a short circuit, the camera will draw excessive current from the batteries and run them down. If that is the case, you would obviously need to send your camera in for repair.
Jun 15, 2014 | Nikon Coolpix L26 Compact
The charging lights come on when the headset is placed on the stand then go out immediately. I put in a new battery but same problem. The headset is not working.
Seeing as you already ruled out a bad battery, it sounds like the unit has gone on you, GN Netcom does offer a full one year warranty on their wireless products, I would recommend calling your distributor, and seeing if you fall within the replacement range.
Jun 30, 2011 | GN Netcom GN 9330 USB Wireless Headset
Do I have to buy new batteries for my Wii remote?
if not turn on yes if u put new in still not work u sync it first hold sync in battery then sync in sd card on wii for more help click here
Apr 12, 2011 | Nintendo Wii Console
I have put new batteries in both my remotes and the lights keep flashing and will not connect to console
I believe, whenever you put new batteries in wii-motes, you have to sync them back to the console.
To sync: press the red button on the console (under the front flap). Then, press the red button on the wii-mote (in the battery compartment)
hope i helped!
Sep 14, 2010 | Video Game Consoles & Games
Wii fit board wont sync
Ok I feel a little silly, there is a sync button on the console (inside the flap by the power on button) and the board (inside the battery compartment on the underside of the board) as soon as I pressed them at the same time it worked. Goodluck everyone.
Dec 29, 2008 | Nintendo Wii Console
Kodak easyshare c613
Are you using Lithium batteries?
Most Kodak models are only happy running on Lithium batteries.
I have two Kodak cameras, both had various power-related problems. Since using Lithium batts, not a single glitch.
They are more expensive, but they end up costing less compared to the amount of alkaline batts replaced.
Worth a try.
Jan 01, 2008 | Kodak EasyShare C613 Digital Camera
Is my camera broke?
sounds like your battery or charger might be defective. I have this camera an when the battery is to low it flashes the screen.
I still use the original charger that came with it to charge the batteries,been thru 4 of those. It seems if they set a while without being charged the go bad.
Nov 04, 2007 | Video Cameras
Camera
hmmmm? try diffent new set of battiers I found bad brand new batteries before. also notice the + and - (- is bottom of battery) and make sure bat. door is snugly closed. other than that your camera just broke down. Murphy's law good luck
Aug 17, 2007 | Pentax Optio 60 Digital Camera
Cameras Logo
41 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
