Question about Refrigerators
To find gaskets for fridge door and freezer door. Model 3211RFD
    Top Expert:
  • Refrigerators Master
  • 5,691 Answers
Sears parts direct.com
Posted on Jan 10, 2019
Amigaman
  • 248 Answers
SOURCE: refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Posted on Nov 12, 2007
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
SOURCE: how to install door gasket for subzero freezer model 3211
I think you just unscrew and take off the metal trim on the door and then replace it. I have a similar issue where did you find the gasket for sale. If you dont mind could you email me at maclaren at tulane dot edu with that info. Thanks, James
Posted on Jul 26, 2009
57 varieties
  • 1653 Answers
SOURCE: Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Posted on Aug 29, 2009
Macmarkus
  • 2605 Answers
SOURCE: the divider that seperates the freezer from the
Hi, Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further. Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Posted on Jul 31, 2010
Help to restore 1954 GE fridge door gasket. The gasket brackets are missing.
Hello Karen
Try somewhere like this
Refrigerator Parts
Gaskets for Antique or Vintage Refrigerators - YouTube
? 4:55
https://www.youtube.com/watch?v=39IRu2ATUA0
Jan 27, 2011 - Uploaded by AntiqueAppliances
... on two doors, no locks on the doors and not have the back cover. Do you have any pictures of this this ...
IMAGES
1954 GE fridge door gasket Google Search
Dec 01, 2017 | GE Refrigerators
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
How to find out if there is a leak on the top of the freezer compartment of my whirlpool french door fridge there seems to be an icicle ?????
Most likely your freezer door or fridge door is not closing properly. Poor rubber seal (door gasket)???
Most likely moist room air gets inside through a door leak
Sep 17, 2014 | Whirlpool Refrigerators
Hi, I think the seal is damaged on my fridge freezer. It is a CB18m/1c/fan whirlpool fridge freezer. Where do i look for a replacement seal? Thank you
Is a package/or a shelf blocking the door? If a gasket is required & damaged it would be noticeably different than the look of the rest of the gasket. The door originally was held straight by the screws behind the gasket & a undamaged door liner(cracked with weight of packages will cause it to twist), if it is twisted than it can be realigned by twisting it straight & may have to loosen the screws a little first & then snug them back up after it has been twisted straight. Gaskets generally have a flat magnet in them to pull the door up to the body of the fridge & with a model number(or take the gasket to them is the worse scenario) can be obtained from a Major appliance store or they can order it.
Dec 12, 2013 | Refrigerators
Fridge door squeaks, freezer door bumps
Slacken the three screws, align the door and tighten the screws up again. Try not to lean on the door when it's open.
Apr 21, 2012 | Refrigerators
I have an Estate refrigerator by whirlpool Corporation, model # TT18DKXRQ01 with a 12-07 mfg. date. When you open the refrigerator door, as it closes, the freezer door always opens and closes. Apparently...
I also own a model # TT18DKXRQ01 Estate refrigerator and my freezer door pops open when I close the refrigerator. As you stated, this is caused by the magnet in the freezer gasket not being strong enough to hold. As far as I know, they do not make a stronger freezer gasket but even if they did, it would probably be too costly considering that a standard gasket replacement costs $80.
My solution was to install an adhesive child safety lock on the top of the freezer near the door handle. I purchased the 'Safety 1st Lock Release Fridge Latch' model # HS038 from my local Walmart store for around $5.
You may find this solution to be slightly inconvenient at first but you will get used to it. It sure beats losing food because the freezer door was accidently popped open.
Product information:
http://www.safety1st.com/usa/eng/Products/Home-Safety/Latches-Locks/Details/482-HS038-Lock-Release-Fridge-Latch
Oct 13, 2010 | Estate Refrigerators
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
HOW HARD IS IT TO CHANGE OUT THE DOOR SEAL GASKETS ON MAYTAG FRIDGE/FREEZERS? MINE NEVER SEALED RIGHT AND NOW I AM GETTING ICE CONDENSATION IN THE FREEZER AND DRIPS ON THE FRIDGE TOP. MODEL # MTB2456DEW
Hello, Its not that hard to change a gasket..If you peel the gasket to one side underneath you should see the screws holding it in place...remove all the screws and put the new one in place...Once the new gasket is in place it's not going to seal right so here is a tip...get a heat gun or hairdryer and close the door of the freezer...warm gasket up until you see the gaps close..once you see it has a good seal you are all set. Good Luck!!! Mike
Aug 27, 2009 | Refrigerators
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
