Question about Fisher and Paykel Refrigerators
Hi there I have an old fisher and paykel Fpg2kra bs model fridge. Just wanting to check the temp. 9 looks to be lowest in refrigerator side based on diagram underneath but stuff keeps going off. Freezer in same setting is fine. Drawers seem coldest
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 102 Answers
9 is too warm set perameters 1-7
you need sevice
check to see what lights are flashing ,in what order
Posted on Jan 20, 2019
SOURCE: Fridge and Freezer losing cooling
we bought a f&p fridge freezer and in summer noticed it wasn't cooling and the freezer wasn't freezing, when the service guy came out he noticed our ducted air con was blowing onto the fridge, once we had redirected the air con outlet the fridge started working as normal, apparently f&p's work on air being convected around the cabinet of the fridge and air blowing on the fridge can effect the temperature of the convected air. hope this helps you or someone
Posted on Dec 10, 2007
skotkolr
  • 558 Answers
thermostat control to deice the freezer is malfunctioning need a service tech to replace it so it doesn't keep the deicer on . Its exactly that, a warmer to deice the coils.
Posted on May 27, 2008
SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Posted on Sep 29, 2008
SOURCE: Fisher Paykel Fridge Freezer
I have a Fisher and Paykel E442B upside down, which is a very similar model, and I just fixed the same problem (temperature was around -4C even though I set the fridge temperature as warm as possible).
The cause of my problem was excessive ice build up on the side of the evaporator coil (which is in the back of the freezer compartment behind the rear plastic panel). I had the same problem around a year or so ago, so I expect it to be a regular occurence. To defrost the coil, I removed all the drawers in the freezer, and the plastic insert by pulling out the bottom of the panel out and rotating it upwards until it released at the top. There are a couple of snap-in tabs holding the panel in, so with a bit of pulling they released. The tabs are either side of the slot at the bottom of the panel.
I then supported the panel horizontally on the top shelf so that I didn't have to disconnect the thermostat wire and the circulating fan wire.
52de81a.jpg With a small fan heater set on low, aimed roughly at the ice buildup on the left hand side of the evaporator coil, I defrosted the ice built up. This took around 2 hours or so. Then put it all back together and it worked fine.
I'm not sure why the ice build up on the side caused the problem, but presumably it interferes with the proper flow of cold air to the fridge compartment.
If you don't seem to have ice build up like I did, then it could be a thermostat problem, or a fan problem (a symptom of which would be fridge being colder at the bottom than at the top).
Posted on Oct 04, 2008
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
Fisher & Paykel fridge is showing F20 fault in screen and beeps when door is opened
SOLVED: Fisher paykel French door fridge shows F20 error - Fixya
www.fixya.com/support/t16590488-fisher_paykel_french_door_fridge_shows
Feb 15, 2013 - F20 does not stand for 20 degrees Fahrenheit you pleb. It is a fault code. Your fridge probably beeps 20 time when you open the door and then stops. To fix is simple and takes 5 mins. Remove the top left hand hinge cover and you will find a broken wire. Just switch off the fridge and then connect the wires ... What does F20 mean on my F & P Fridge. When I ...
14 Feb 2018
What does F20 mean on my F&P fridge. It beeps ...
14 Feb 2018
I have an f20 error on my fisher and paykel fridge ...
16 Nov 2017
SOLVED: Error code F20 on RF610A Fisher & Paykel
9 May 2011
More results from www.fixya.com
Fisher Paykel Refrigerator F20 Error Code ' Wills Creek Community ...
www.willscreekcommunityforum.com/fisher-paykel-refrigerator-f20-error-code/ Sep 27, 2017 - If you are experiencing a F20 code on your Fisher Paykel refrigerator, you will hear a constant beeping sound when you open the frig door. This error code means there is a broken wire on the top of the door hinge (usually left side). If you are even a bit handy, A simple solder job is the fix and can save you ...
Apr 29, 2018 | Fisher Refrigerators
Fisher paykel e224b fridge not cooling. everything working fine but fridge was originally pulled apart before i looked at it, need to know which thermistor is which (black and white ones in the freezer...
Kitchen Laundry Appliances Fisher Paykel US
Are you sure that is the part number. I went to the above link and could find nothing with a part number of E224B. Please look on your unit and verify there is no other numbers. If you find additional information please post it and we can attempt to help.
Semper Fi,
Z
Feb 01, 2018 | Fisher and Paykel Active Smart E522B...
Hi, Have model E522B fridge, freezer cold but fridge even on lowest setting is only just getting cold. Can I fix it myself? Thanks for your help
The only thing a home owner can do to fix this is to make sure ALL the coils under and behind you fridge are clean. If that dose not work I would very strongly suggest calling a repairmen before you attempt to fix.
May 02, 2011 | Fisher and Paykel Active Smart E522B...
Ice maker has quit making ice
Lower the freezer temp. The icemaker won't come on until the temp is low enough.
Mar 10, 2009 | Fisher and Paykel E522B Stainless Steel...
Hi, I have a 12 year old F&P fridge, model C270 which is working fine but has leaked twice this week. The leak appears to be coming from the base of the fridge as there is water beneath the...
what might be happening is that the drain hole for condensate is blocked causing water to gather beneath the crisper. look for a channel under the evaporator (the icy cold part) and there should be a drain hole some where near check this is not blocked.
Dec 07, 2008 | Fisher and Paykel Refrigerators
May 27, 2008 | Fisher and Paykel Active Smart E522B...
Nov 23, 2007 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
Top Fisher and Paykel Refrigerators Experts
Carmen Mikulic
Colin Stickland
Colin Stickland
Jose Pino
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
