Kelvinator full automatic wm error pr - Washing Machines
Kelvinator split system is flshing green light on unit and wont turn on...
I think this is a kind of error code. You need to look at the inflection, or on the Internet Kelvinator error codes. There you will definitely find the answer. http://airmaster.net/error-codes
May 30, 2018 | Heating & Cooling
Error Code E9 for Kelvinator KL15TL washing machine. How can I fix it myself?
My search came up with "low pressure sensor error". Theoretically you could replace this sensor yourself but it will depend if you will be able to ensure you do not damage the port it screws into and it doesn't subsequently leak. Found a link with an image of the different types of sensor units in it -
have Kelvinator model KSV80HRA showing an E9 error code
Mar 27, 2017 | Washing Machines
Completed full system cear and Pr Err keeps displaying.
Probably a printer error. Make sure it isn't jammed
Mar 31, 2015 | Retail Supplies
Kelvinator Problems I have a Kelvinator washer
google that error code
If you need further help, I’m available over the phone at https://www.6ya.com/expert/rick_4ed9a6c8e57209e6
Oct 06, 2013 | Freezers
Canon printer lbp 3310 paper sensor error flashing red when full of paper
my canon LBP printer 3310 the error is alarm light on what the problem
Apr 03, 2013 | Canon i-SENSYS LBP-3310 Laser Printer -...
What does inh.unit pr mean
INH. UNIT PR. means "Inhibit unit price". It means there is no price preprogramed for that department or PLU. Each department can be left open-priced, or preset. Open price is how you usually think of using a cash register: you enter a price, then touch the button. Preset price requires programing a price for a department in advance, but saves time in operation. You touch the Coffee button, for instance, and it automatically rings up the price you've set for a cup of coffee.
If you touch a normal, non-preset department without entering the price first, the register will error with the INH. UNIT PR message.
Touch the CLear key, enter the price, then touch the department.
Many of the Sharp registers, and I think the XE-A402 is one, allow a department to be both open and preset. It can also be programed to be inhibited completely.
The Owners Manual can be downloaded from Sharp here.
Dec 03, 2010 | Sharp XE-A402 Electronic Cash Register
I am getting a FE erroe on my LG WM-2277 HW Washer? What Part do I need?
Hi
Thanks for using FixYa. FE is Overflow error which means that the water is overflowing and the water level frequency is over 213. When FE error is displayed the drain pump operates to drain the water automatically. To resolve this issue you’ll have to check the water inlet valve and pressure sensor which can sense the water level in the tub, if any of this goes bad overflow occurs. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | LG WM-2277HW Front Load Washer
I've got an error 1 message on my Kelvinator air
Here is a Toll free number to Kelvinator. Good Luck!
Technical Support Center - U.S.A. 1 (866) 738-1641
Monday - Friday
8:00 am - 6:00 pm EST
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 13, 2009 | Heating & Cooling
LG WM-2277HW Front Load error code dE
de error code means the door is open. If code does not clear when door shut then could be door interlock or main pcb fault
Oct 24, 2009 | LG WM-2277HW Front Load Washer
Washing Machines Logo
27 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
