Question about Refrigerators
Can I put fridge freezer in garage - Refrigerators
  • 4,293 Answers
Hi there
YES yes
You can lots do it make's more room in the house then.
Posted on Jan 11, 2019
3 Suggested Answers
dmftrucker
  • 1922 Answers
SOURCE: plugged a new tumble dryer into an extension lead
you have more than likely ruined the control board on the refrige,a dryer and refrigerator should each be on their own dedicated circuit,they use an enormous amount of current to start, and even if one is running and the other starts thats enough to trip even a 30 amp receptacle, and furthermore extension cord use on these types of appliances even a large gauge cord i.e. 12 ga. that will carry 20 amps is not even a good idea because of voltage drop,as this causes motors to draw excessive current and over heat the motors and reduce appliance efficiency too
Posted on Nov 09, 2009
ghurzang_shi
SOURCE: The freezer section of the fridge freezer in our garage works intermittently while the fridge section works well. Why?
idm serial number
Posted on Feb 13, 2014
Why is E522B fridge not cold but freezer working fine?
Hi , First thing you need to check is that the fan is working in the freezer to push the cold air into the fridge. If you have a magnet put it up against the sensor on the door sill so as you can leave the door open.
Jun 03, 2014 | Fisher and Paykel Active Smart E522B...
Fridge freezer kept in cold garage. Freezer works from time to time but fridge stopped work. Could it be a thermostat problem or due to temperature of garage?
The problem is with the garage temperature. The temperature sensor for the refrigerator is in the fridge compartment, but the evap coils are in the freezer. Refrigerators were designed to work in an air conditioned space. When they are put into unheated spaces, it does not work well. The fridge thermostat typically is set to 40 deg F. If the outside temperature is close to that, then it does not turn on the compressor as much so the freezer will have a hard time staying below freezing.
There are garage refrigerator kits for people who put fridges in un heated garages in the winter. They just simple electric heaters that warm the fridge's thermostat to cause the compressor to run more often. This helps the fridge to maintain temperatures better in the freezer compartment. The same thing can be accomplished by putting a small wattage bulb in the refrigerator compartment. Just remember to remove it during the warm weather otherwise you will pay a large electricity bill in the summer months.
Dec 09, 2010 | Smeg FAB46X Top Freezer Refrigerator
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
Had a fridge freezer in garage. Just found that
more than likely the defroster inside the freezer has gone bad. This defroster is located in the space between the fridge and freezer and activates to defrost the freezer and stop build up of ice in the freezer.. If it is bad the freezer will not keep the fridge nor freezer cold.
Dave
Jan 08, 2010 | Zanussi 3.46 cu. ft. / 98 liter Upright...
I recently brought a Crosley fridge and put it in my garage. A few days ago we opened up the freezer section and everything thawed out and spoiled and stunk. The fridge part smelled as well. We lost over...
This makes no sense. The sensors are supposed to sense the internal temperature of the fridge/freezer, not the room temperature! It is faulty, get it repaired under the manufacturers warranty and if the manufactures agent says it is faulty, they are liable for your loss.
Mar 26, 2017 | Refrigerators
Freezer won't work in garage in cold weather
Modern fridge/freezers are built to automatically defrost themselves. To do this they require that the room temperature is well above freezing to allow the defrost to take place. If you site the freezer in too cold an environment it is unable to defrost itself and will eventually stop working. It sounds strange but if it is too cold the freezer cannot work. The solution is to buy and fridge/freezer that does not automatically defrost itself if you want it to work in a cold environment.
Dec 06, 2008 | Refrigerators
Does outside temperature affect performance of freezer
Top mount refrigerator installed in a garage and the food in the freezer is defrosting when
the temperature in the garage goes below 55 degrees fahrenheit.
On top mount refrigerators you cycle the compressor and fan/fans from the food
compartment temperature. When the room temperature gets colder than 55 F, you have
long off times waiting for the food compartment to warm enough to trip the cold control.
This long off time is allowing the freezer temperature to get high enough that food can start
to defrost.
There is a kit for refrigerators installed in applications where the temperature can go as low
as 34 F and still maintain good freezer temperatures. The kit part number is 5303918301
and it contains a heater that mounts in the control box and an instruction sheet advising
how to install the heater.
Kit 5303918301 contains:
Part # 5303950194 Instruction sheet
Part # 241532101 Heater
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Frigidaire Freezer Runs Warm in Cold Weather
hi there the problem you have is that the temp in the garage is to low, the fridge part of your fridge freezer has priority and will only activate the compressor when req'd ie. in cold weather the fridge may not need to switch on the compressor for days at a time this is when the freezer will defrost.
All you can try doing is having some very low heating in your garage in the cold weather
hope this is of help.
Dec 11, 2007 | Refrigerators
Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
Nov 27, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
