Question about Refrigerators
I have a Kemore Coldspot model 106... Yesterday I heard a pop as I was getting water and the water stopped.. the micro switch sounds like it's still working I want to be able to take the panel off to look... Any ideas how to do this?
I would check the water solenoid on the back of the refrigerator, where the water line hooks. You should have two solenoids, one for ice maker, and one for water in the door. Should be no reason to pull the door apart.
Posted on Jan 13, 2019
SOURCE:
SOURCE: micro stopped working
Try looking at the microswitches behind the door.
Posted on Apr 14, 2008
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
  • 572 Answers
SOURCE: Kenmore Coldspot model 106 - Snowing in freezer!
its not defrosting. check heater operations. bimetal near heater. check defrost timer
Posted on Feb 08, 2010
livewire874
  • 618 Answers
SOURCE: Need a manual for the
Try this site http://www.manualsonline.com
Posted on Dec 03, 2010
SOURCE: kenmore coldspot model 106: top freezer leaks
Have you tried adjusting the freezer temperature to a higher level? This worked for my Kenmore. It will take a couple of days to quit leaking.
Posted on Dec 19, 2010
Kenmore coldspot 106
It can be a defective=> W10408180 Water Inlet Valve
or the problem can be a defective=> 2162361 Micro Switch
2162361 Micro Switch Can you unplug the wires going to the W10408180 Water Inlet Valve? I am here to help you solve this problem if you like. If the wires going to the W10408180 Water Inlet Valve are disconnected and the water continues to flow the problem is most likely the W10408180 Water Inlet Valve being mechanically stuck open The 2162361 Micro Switch can be tested after we prove that the=> W10408180 Water Inlet Valve is not stuck open. I am here if you need me, Thanks Sea Breeze
John Tripp
Dec 02, 2013 | Refrigerators
Kenmore coldspot model 106 9445781 the icemaker motor makes loud noise. Sounds like its under a heavy load.
Suggest you take the ice maker out and defrost it. You propably have ice crystal buildup and causing it to labor harder.
Jan 16, 2012 | Kenmore Side by Side Refrigerator
How old is my Coldspot refrig Model 106: 9738312?
http://www.kouba-cavallo.com/refdate.htm
your model #'s dont match coldspot numbers.. but here is a website to help..
Dec 28, 2010 | Refrigerators
Feb 08, 2010 | Refrigerators
Kenmore coldspot refrigerator model #106 RUMBLING!!!
Does it have automatic ice cube maker not hooked up to water? If you do make sure thin stainless bar isn't straight down. on the side of ice maker.
Nov 15, 2017 | Kenmore Refrigerators
I own a 3.86 model and have used it two times. I
was you using the machine on a electic extension & was it full unwoven.
chance thermal overload in switch knocked out.
there is also a little micro switch on the bypass valve that might be stucking , just in clip and test.
Jul 02, 2009 | Northstar Professional Series Pressure...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
