Question about Cameras
When setting up I get nothing. What do I do? The light did not come on after I pulled the yellow tab and pushed the battery button.
Did batteries come in it"
  • Cameras Master
  • 6,100 Answers
We can offer no help without knowing more about the equipment to which you refer.
Posted on Jan 12, 2019
6ya staff
SOURCE:
ThaMp3Doctor
Corey Knoettgen
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
Anonymous
  • 3 Answers
SOURCE: C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Posted on Sep 28, 2009
Anonymous
  • 59 Answers
SOURCE: Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Posted on Oct 20, 2009
Testimonial: "I repclaced the charger...no is ok again...thx for the help :-)"
jepito
Kevin Groce
  • 216 Answers
SOURCE: I have a Dell Inspiron 1525 that won't start.
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Posted on Dec 27, 2009
potek18
Archie Cruz
  • 528 Answers
SOURCE: I cannot find a way to open the compartment to
This help?? >>>>>>>>>>>>>>>
Where do I change the batteries for my mouse? I can't find where the batteries go.
Answer
This article applies to the following products:
All Logitech cordless mice
For some cordless mice or trackballs, there is a slot for the battery door on the bottom of the mouse. Between the slot and the outside edge of the door is a thin strip of plastic. If you compress this thin strip of plastic towards the slot, the catch on the door will release and the door should open.
On other mice, the battery door is on the top of the mouse. Simply slide the top of the mouse cover down and lift the door up. There should be an etched diagram on the door indicating which direction to slide the door.
Once you have opened the battery door, remove the old batteries and dispose of them according to your local waste disposal regulations. Then insert the new batteries into the battery compartment using the diagram in the compartment as a guide. When you have finished inserting the batteries, replace the battery door.
Posted on Mar 28, 2010
Testimonial: "have tried suggestion with no luck. Have pushed, pulled, stuck in keys, etc. I will now have to go to the store for help. Please change this to easy."
How do you connect 200897 battery, it is no longer working
I just bought a battery (readily available) for $16 and here is how I replaced it, but first, make sure UPS is disconnected from 120 Volt service. (Old battery number SW1233 with F connectors.)
Turn the UPS over and look for 1 tiny screw (even with the "in" telephone wire socket). Remove the screw (turn CCW). Push the button marked push, then slip a steak knife or sharp putty knife into the joint in front of the screw hole. Twist the tool enough to start the battery cover moving backward (to your left).
The battery is upside down. Lift it high enough to grab wires and pull them off the postst.
Verify battery you bought fits the housing. With UPS upside down, place battery on right side with lugs toward the power cable. Push red wire onto red post. Hold the battery upside over UPS. Push black wire onto black post.
Visually ensure the wires both run in their channels (otherwise the battery will not seat and the cover won't slide on.) Push battery into slot until it bottoms.
When the battery is bottomed properly, hold the cover about 2/3's over the battery housing, push it down, then push it toward the screw hole (to your right). If this operation, or the cover jams near the screw hole, check the battery. It must be absolutely bottomed in the slot. The cover won't go on easily even when everything is perfectly aligned.
After the cover is closed and the screw replaced, plug the UPS into a wall socket. The on/off button has a mind of its own, so ignore it. The green light may light and there is one beep. The backup yellow light may blink. The green light may stay solidly on. Pull the cord plug out of the wall. Now the UPS green light may go out and you will hear a ratcheting sound (the UPS is making AC from the 12 Volt battery current). Because you have no device plugged into a "battery-backup" plug, the UPS will shut off automatically in a few minutes.
The last test is to reconnect the plug to the wall service, then plug a monitor, a music system, or something similar into a Battery B/U connector. The green light should light. When the UPS is again unplugged, the yellow light (Backup) flashes and there is a repeating beep. Plug UPS back in. Only the green light will be on. That's it, all done.
I use Newpoint UPS to back up my telephone/modem. During a brownout, SPS powers those units almost 2 hours.
Note: This UPS is not suitable for powering or charging Laptops because the power output is too dirty.
R Hicks
Oct 22, 2013 | Newpoint (200897) (DHN200897) UPS System
Cannot remove battery from laptop
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
Jan 03, 2010 | Panasonic Toughbook CF-51 Notebook
Oct 18, 2009 | HP Compaq nx7300 Notebook
Acer Aspire One Netbook ZG5 will not turn on
you should be able to press ESC to exit hibernation, or remove the battery, remove the plug, press and hold the power button for 60 sec, and reinsert battery and power and turn on. when restarted, right click on desktop, click properties, and click the screen aver tab, click the power button, click advanced, and remove the check box beside enable hibernation on the "Hibernation" tab. it shouldn't do it again
Apr 20, 2009 | Acer Aspire One Netbook 8.9" Notebook
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Battery light yellow won't come
allow battery to complete charge (green lite)
Or change battery if chrge not completing.
(check your AC charger)
Jan 11, 2009 | IBM ThinkPad T30 2366 Notebook
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
Power up problem
it has nothing to do with the ram, it is the issue of the adapter or battery for toshiba laptop, if the output volatge form the adapter is not steady, the light will get yellow and blink,try it on another toshiba laptop. if it is normal, u should test the toshiba laptop battery by the multimeter, connect the electroprobes wiht the anode and cathode, if the pointer does not fixed in a short time ,the battery is the issue. change it for a new one.
Jun 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Cameras Logo
42 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
