Question about Frigidaire Refrigerators
Frigidaire Professional Fridge how do you remove crisper drawers; it almost looks like they placed stoppers too far back. Is there a trick to removing these drawers?
Brand new fridge but cannot get the crisper drawers out. I have called Frigidaire they say pull out and lift (much like every other fridge we have had) This does not seem to be the case
6ya staff
SOURCE:
Keith Smith
  • 42 Answers
SOURCE: kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Posted on Apr 06, 2008
Anonymous
SOURCE: Cannot remove plastic skids from under my new whirlpool fridge
The skids are bolted to the refrigerator from underneath. I think they are 13mm or so, you need a friend to help you tilt the fridge and then unbolt them from the bottom.
Posted on Sep 04, 2008
Anonymous
SOURCE: Water on the bottom shelf of the Refridgerator
I have a whirlpool refrigerator ET21NKXJW00. Getting water in crisper drawers, under drawers, and under bottom of freezer shelf plate. Took off bottom shelf from freezer and took out all the ice. Still getting water in crisper drawers. Help!!
Posted on Feb 01, 2009
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: water dipping on the inside of fridge towards back
Hi
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
Anonymous
SOURCE: Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Posted on Apr 21, 2009
How do I get the drawer out of my fridge. It is the drawer that is on its own in the middle of the fridge. It is on two side rails and it only comes out 2/3 of the way. Model is FRT17G4BW3
Thank you for your inquiry, friend!
I see that you would like to remove the drawer on your Frigidaire refrigerator, FRT17G4BW3. Typically, to remove that drawer you would need to pull it out and lift up on the shelf. It is on a track and there should be a stopper within the rack so that the drawer does not fall out. I hope this information has been helpful. -Matt
Oct 17, 2014 | Frigidaire FRT17G4B Top Freezer...
Humidity-Controlled Crisper Drawers
If you will post the complete model number including the string of digits starting with P, (if it has these) I will look it up and see what I can find.
You can usually go to sears.com, click on parts, enter the model number from the fridge decal, and pull up a parts diagram of the fridge.
Thanks/mike
Nov 11, 2007 | Amana ASD2620HRB Side by Side Refrigerator
Water collecting in bottom of fridge
Good Afternoon Friend,
I understand that you are receiving water at the bottom of your Frigidaire refrigerator, model# FPUI2188LF. What can cause this is either humidity coming from outside your refrigerator or maybe from the crisper drawers. Make sure your crisper drawers are set for a high humidity. Another thing that can cause moisture build-up at the bottom of your appliance is not covering your foods. Make sure that all foods and drinks are covered to cut down on moisture floating around inside your appliance. Hope this is helpful.
-Best Regards-
WP
May 15, 2014 | Frigidaire Fpui2188lf 21 Cf Top Mount...
Why are only drawers in fridge cold & not making ice?
Contact a professional. Sounds like either your damper door is not operating correctly and not letting enough cool air from the freezer enter, or there is an air leak that is making ice form .
Aug 12, 2012 | Frigidaire FRS3R5EMB Side by Side...
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
I have a frigidaire top freezer. the model is frt18s6j. there is water collecting underneath the crisper drawers.
Make sure the seals on your doors are in good condition. Also check that the fridge is turned to a correct temperature and not too warm. Also ensure that the freezer is performing as expected as poor performance may indicate a drop in the appliances capacity. Check that the back of the fridge has reasonable airflow around it as this can restrict capacity also.
Mar 12, 2011 | Frigidaire FRT18S6J Top Freezer...
Water in wood's fridge
If you have the wire metal shelf model, there is a wrap around cooling plate (back and two sides) at the top of the inside. The frost that forms on this while it is running melts off after the compressor stops and the water runs down, into the drip channel, and out the drain hole at the center of the channel on the back wall. Clean out that hole so the water will flow out instead of down the walls to the bottom of your refrig.
If you have the glass shelf model, you have to remove the metal cover at the bottom back of the refrig and clean out the defrost drain hole located there.
May 21, 2010 | Refrigerators
Crisper Door broken
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Fridge problem
There is a drain, usually at the bottom of the refrigerator compartment. Pull out the bottom two drawers and see if there is a drain. It is usually in the very back of the inside compartment. Make sure it is not clogged. Usually, this is the problem.
Oct 18, 2008 | Frigidaire Refrigerators
Hotpoint FFS70 fridge problem with draws.
Not sure which drawers you are talking about BUT have you tried switching over the two crisper drawers? They are not interchangeable, i.e. there is only one way the will fit inside the fridge.
Jun 12, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
Refrigerators Logo
389 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
