Question about Daewoo Washing Machines
My daewoo dwd-f1221 now seems to be taking 2.5 hours on cotton wash where it used to be 1.5 hours - why ?
3 Suggested Answers
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
Jahn27
  • 1554 Answers
SOURCE: Need a manual for a
Here's the link to the Instruction Manual for your Daewoo DWD-FD1221 Front-Load Washing Machine.
Posted on Nov 12, 2010
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
My front loader fills with water but then does nothing. The drum doesn't turn. Can hear clicking sound from the control panel as though it's moving through the cycle. Checked the belt and is in good c
Does it spin if you turn to spin cycle?
Try this:
Jam lid switch with something plastic or wood.
Put on spin cycle.
Spin the tub by hand.
If the bowl then starts spinning properly, your problem is the motor starting capacitor.
May 21, 2014 | Daewoo Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
Hi i have a 6.5 dwd f1221 and the drum has droped down a bit and is makeing a hell of a sound. Can you help
sounds like it slipped off it's mount, STOP USING IT. take the front cover off the machine, usually there will be 2 or 3 clips, use a flathead screwdriver to lift the clips while pulling the cover forward. Be careful not to damage the enamel. use pry bars or an auto scissorjack with some pieces of 2x4 tolift drum and set back on centre.
Apr 13, 2012 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Washing Machines Logo
Top Daewoo Washing Machines Experts
Marvin
Marvin
Paul Bade
Paul Carew
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
