Question about FUJIFILM Cameras
Fujifilm finepix s5700-I have a camera with a broken flash, it does not open itself, and a damaged display, I live in London, where can I give it for repair?
    Top Expert:
  • FUJIFILM Master
  • 22,172 Answers
Contact fujifilm
Posted on Jan 11, 2019
Testimonial: "Thanks."
SOURCE: finepix s5700 driver
sure :
http://www.fujifilm.com/products/digital/download/01/index.html
Posted on Apr 10, 2008
  • 3 Answers
SOURCE: Broken LCD Screen FujiFilm FinePix S700
i have a fuji s7000 that has a good lcd screen but the processor inside doesnt work. You could use it for parts.
Posted on Oct 30, 2008
  • 20 Answers
SOURCE: Fujifilm FinePix 3800 flash will not work
Normally when the flash stops working it is because the capacitor the camera uses to store the flash power ( that is what charges..not the bulb) burns out. This is a very difficult repair and should only be completed by a camera technician.
If the repair is over 10 dollars I would suggest a new camera.
Posted on Jan 28, 2009
  • 11 Answers
SOURCE: Fuji s5700 my flash is not popping up on auto
had a run in with fuji myself.. if it's going to cost that much to fix. you might as well get a new camera. they don't seem to care to fix or replace parts on their cameras
Posted on May 30, 2009
  • 22 Answers
SOURCE: flash won't pop up
I have a couple of Fuji S700 cameras and one of them recently came down with the same issue. The flash would partly open but not pop up all the way. I decided to open the camera up and find out what was really wrong. It had been sticking before and the above suggestion about blowing it out helps, but this issue is where it unlatches, pops up part way but doesn't go all the way up and if it doesn't go all the way up the flash doesn't work.
The problem is there is a spring insite the flash hinge that pops the flash up once the electronic latch is opened by the auto exposure circuitry. One end of the spring goes into a hole on the part of the flash that pops up and this plastic part is simply too thin for the force on it and it breaks over time. Bad design.
I should say I first thought about a couple of workarounds. One was real easy if you are not too handy. Take a small rubber band and run it from around the eyepiece to around the "lobe" under the flash. When you weant to use the flash, depress the shutter half way to unlatch it, then move the elastic from the lobe to under the raised flash and it will hold it up. You can leave it up all the time if that works for you. It didn't fit my case with the flash up all the time so I decided to forge ahead... Buying a new case might have been a wiser choice :-)
By the way, its not easy to get into the flash area. I pretty much had to completely disassemble the camera, and I got in a fight with a very high voltage capacitor for the flash that holds its charge for a VERY long time after the batteries are out AND it holds enough charge to get you a few times so use a resistor to discharge it when you get into that are or else... be afraid, very afraid. Seriously. Before you disassemble read on...
If you had a very tiny right angle philips screwdriver you could probably do this repair without taking things apart. The key is there are two screws that hold the top cover of the flash area on. This is the area you need to get at to fix this spring. These screws that are only accessible when the flash is popped up and even then you can't see them as they are recessed. If you can get those screws out somehow then you can do this without a nightmare. If you take the whole thing apart then welcome to hell. I am just on my way back from hell. Hope mine works when I get it back together.
I chose to epoxy a small bent pin in to replace the broken plastic part. I used a long square wire wrap pin, bent it to the right shape and cut it to the right dimensions then glued it in place using epoxy. There is a fair amount of room for glue in there, but be careful not to get it into the area where the lower shaft has to slide back and forth as the flash pops up and down. I used 5 minute epoxy and first just used a tiny dab to hold it in place and I positioned it carefully and let that set. Then I did another glue job to add some strength. Position, then reinforce.
I will try to post some pictures in a followup.
Posted on Feb 07, 2010
Flash repair on fujifilm finepix s5700
You need to take Camera to Camera shop, but the cost of repair may be more than Camera is worth !
Feb 14, 2015 | Fuji FinePix S5700 Digital Camera
Where can i download an instruction book for my camera (s5700)
http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s5700_s700_s5800_s800_manual_01.pdf
Aug 07, 2011 | Fuji FinePix S5700 Digital Camera
Ive lost the cd rom for my fuji finepix s5700.now i cant link my camera up with my pc.....
http://www.fujifilm.com/support/digital_cameras/software/
Search under s5700 or s700 and you will find a wealth of information and drivers and so on for your camera at the fujifilm.com site.
Jan 01, 2011 | Fuji FinePix S700 Digital Camera
FinePix S5700 LCD Screen Problem
you need to send it to fujifilm for repair. i dont think its too expensive at all. this is a common problem with many cameras
Apr 14, 2017 | Fuji FinePix S5700 Digital Camera
Have changed my camera to take black and white photos but need to take colour photos again - fujifilm finepix S5700
Turn the camera on. press "F" button to select F-MODE. Use menu button to scroll down to finepix color. Select STD (standard)
Jan 03, 2009 | Fuji FinePix S5700 Digital Camera
I have a fujifilm s5700 camara but i keep get any zoom error any ideas ?
The lens will need to be removed, stripped and then re-assembled.
The drive for the zoom / focus has been dis-lodged or damaged
Dec 18, 2008 | Fuji FinePix S5700 Digital Camera
Accessories for Fuji Fine pix S5800
You Can not put additional flash on S5600, S5700 and S5800.
Jun 18, 2008 | Fuji Finepix S5800 Digital Camera
Cameras Logo
Top FUJIFILM Cameras Experts
Falling star
Marvin
Marvin
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
