Question about Dometic Refrigerators
Error 51 flashing not starting on gas dometic 3way has automatic mode
If voltage to ignitor bad ignitor if not sparking if no voltage to ignitor bad control board
    Top Expert:
  • Dometic Master
  • 10,337 Answers
Posted on Apr 30, 2019
SOURCE:
Therinnaiguy
  • 1420 Answers
SOURCE: Goodman GMP075-3 ignition problem
OK, if the furnace is not lighting for even a few seconds, you have either a bad gas valve, bad wire, bad control module or no gas. The pressure switch is not the issue. Check all wires to the gas valve and look for 24 volts across them when the ignitor glows and you hear the click. Then test for 24 volts to ground. It could be a bad ground wire.
Posted on Oct 21, 2008
  • 6 Answers
bad board,i have had several board failures on goodman
Posted on Dec 31, 2008
SOURCE: Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Posted on Dec 10, 2009
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
Posted on Dec 11, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Dometic RM3801. Propane ignition failure.
The older units has a 3 VDC glow coil the newer units have a 12VDC igniter.
Fromwhat your described above the next paragragh is your ignition system.
The igniter control voltages in the newer SPARK type igniters are (+) = 12VDC, (L)= high voltage lead (Spark plug voltage! I.e ruin your meter type voltage), (-)= Ground L is the lead that passes the HV spark from the control unit to the ignitor plate. The L lead should pass one heck of a hit if is workng correctly.
If not look at the HV lead to see if it is grounding out somewhere.
If the gas safety valve is not sensing gas pressure... you will not have 12VDC to the + terminal of the ignition moudule.
With the gas on and you have 12VDC at the ignition module + terminal then most likely the ignition module is bad.
Kelly
Posted on Apr 17, 2010
I just brought a 40gal rheem gas water heater and its not sparking
if voltage to ignitor bad ignitor if no voltage to ignitor bad board or temp sensor
May 26, 2018 | Rheem Water Heaters
Dometic rm2652 re-ignitor
Dear sir/madam,
Turn the refrigerator off and remove the wire
between the electrode and igniter. Now turn the
refrigerator to the gas mode. If no internal
clicking sound is heard the igniter is defective.
It is important to remove the high voltage wire
that goes to the electrode from the igniter when
you are checking the igniter for operation. The
high voltage wire and the electrode can be
shorted to ground causing the igniter reigniter
to think that the flame is lit, resulting in no
spark on gas operation.
thanks
good luck
Sep 14, 2008 | Dometic RM2652 Refrigerator
I have freightliner 2017 dometic fridge is trying to start but wont
check gas line to ignitor if ok check ignitor if no gas board if voltage to gas valve bad valve
May 20, 2018 | Dometic Refrigerators
Have fuel but no spark at the spark plug 35000 btu
The electrodes might need cleaned. I am attaching a link, please check out the FAQ section, then scroll down and click on FAQ for spark plug heaters. I hope this helps. Reddy Heater Parts Sales Online Mr Reddy Heater Parts Master Heater Parts...
Jan 21, 2018 | Reddy Heating & Cooling
Gmnt100-4b won't spark. Gas valve opens but ignition module won't produce a spark. after three tries it goes into lockout.
while cycling if voltage to ignitor and no spark bad ignitor if no voltage to ignitor bad control board or safety circuit open
Jan 17, 2018 | Pool & Spa
Dometic rm 2807 igniter won't spark
if lines clean to ignitor and wont spark see if voltage to ignitor if voltage bad ignitor if no voltage bad board
Jul 11, 2014 | Dometic RM2652 Refrigerator
Refrigerators Logo
461 people viewed this question
Top Dometic Refrigerators Experts
Sheldon Dedek
John Tripp
John Tripp
Paul G
Paul G
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
