Question about Toro Garden
Toro snowblower 2005 model 38518 serial 250005897. I found extension spring broke and was hanging on the cable adjuster. where does other end hook to?
smilemaker
  • 790 Answers
SOURCE: broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
Posted on May 07, 2008
  • 24 Answers
SOURCE: cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
Posted on Feb 05, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I HAVE A JOHN DEERE LX188 MOWER. 17 HP. GOVENOR NEEDS ADJUSTING.
Your engine per John Deere is a Kawasaki FH500V
Here is the service manual (3.58 Mb pdf file) This should get you going again.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Posted on Jan 23, 2010
  • 308 Answers
SOURCE: what is the oil to gas mixture ratio on 1995 Toro
The proper mix is 50:1. The link to the manual is
http://ourfamilys.deandrea.net/BobKitty/User%20Guides/tosnowss.pdf
The fuel mixtures can be found on page 11. Hope this helps.
Posted on May 04, 2010
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
Where dose the extension spring go on a toro ccr2450snow blower go modle number 38515
goes on the arm for the idler pulley near the cable that actuates it. theres a small hole in the frame for the other end.
Dec 22, 2017 | Toro Garden
The spring on my auger clutch cable broke. Where does this spring connect too? I ordered a new cable and spring but I can't locate where the spring connects too. I have a model 317-611D000 snowblower
my auger cable is not working the auger so i adjusted it and it was to tight and the plastic holder that holds the cables poped off and broke,now the cable i adjust it and nothing happens,cable is all hooked up and seems ok but it will not work right,but the auger spins with out the cable,wondering if it needs a new auger cable
Dec 26, 2010 | Mtd Genuine 9460897 Snow Blower Auger...
How do I attatch the heavy spring that helps lift my snowblower to my 416-8 toro snowblower
lift the snow blower up as far as it will go and block it there, attach one end of the heavy spring to the place it attaches on the tractor now attach a come-a-long to the free end of the spring and using the come-a-long stretch out the spring until it is longer then you need it to attach to the other spot it fits on the tractor, pry it over to the spot on the tractor that it goes and slowly let off the tension on the come-a-long until the spring is firmly in its correct position on the tractor. One tip when you attach the spring to the come-a-long use a piece of rope or wire between the come-a-long hook and the end of the spring, so that you have room to attach the spring to the tractor and just remove the rope or wire when in place and you are done. Hope This Helps Don
Dec 05, 2009 | Garden
Toro Model 20043, Serial 9915314 (1999)
There could be a couple of problems.
One a spring or the cable might have broke.
Two the belt is broken
Three the little cogs inside the wheels are usually molded plastic and they could be stripped out. I would check the wheels first.
Good luck and let me know if this helped.
roundo4
Aug 07, 2009 | Garden
Long drive belt cant remember how to put spring back on
The 'j' hook hooks over the transaxle and just hangs there. The spring attaches to the stabilizer rod (reference # 43) and the other end attaches to the "j' hook hanging on the left axle.
Jun 20, 2009 | Mtd Garden
Snowblower Treads not turning
Hello, if you go to searspartsdirect.com type in your model number you will be able to find a diagram that will show you where and how the spring attaches
Mar 05, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
