I have a ellies/elsat decoder 2013 model S1 its stuck on ses 05 and it cant let me scan channels on is20. Keeps saying no satellite found. It also failing to download new software
SOURCE:
  • 12 Answers
SOURCE: My HP PSC 1315/1310 will not scan
you either have corrupt or missing twain drivers
go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=374568&
and download the latest?
Posted on Mar 14, 2009
raklein62
  • 360 Answers
SOURCE: No scan software visible
Go to hp web site. Under support and drivers is a start by selecting a task. Click on to it , that will give you enter a product. I entered C4180 and hit go and it seem to know what I was look for HP photosmart C4180. I ended up at a download site for the HP product. Click what you need and download it.
Posted on Sep 21, 2009
SOURCE: Hi Ihave a Zennox Camcorder Model :DV5217 .I cant
i have zennox DV5212 video camera.i can not charge battery which i use cable from zennox.do you know where is the shop who they can check for me it is problem from video camera or from charger.please email to me georgezhang@hotmail.co.uk
Posted on Mar 02, 2010
  • 736 Answers
SOURCE: I am setting up my proview pa-32jk1sa, for the
chances are that your reciever is outputting conventional NTSC .. not high def ... so you would scan for standard channels not hdtv .. if chanel selection is done by the satelite reciever then the scan will only find one channel 3 or 4 usually (or better yet you can use Svideo or component oututs if it has them .... if the receiver is a block converter that uses the tv to tune channels then you should get more channels detected ..
Posted on Jun 24, 2010
freetek
  • 5569 Answers
SOURCE: I forgot how to use
If the decoder is newer than the remote, there may not be a code setting for it. You can probably get the code list for your remote here:
Remotes
Posted on Nov 24, 2010
HDMI input works ok. Hooked up external antenna. Did channel scan. It will only scan for analog channels. Has analog raster on screen. It has no information on menu page for digital channel scan.
do you have the air option in the scan menu see
http://tv.manualsonline.com/manuals/mfg/sanyo/dp42841.html
page 9 important fact cable digital gets wiped by air digital channels
You may be able to get around this via a digital hd tv decoder box and then have it on a hdmi input on the TV as a backup to the cable if you can't have both cable digital channels stored and aerial digital channels stored
Oct 09, 2016 | Sanyo DP42841 42" LCD TV 1920x1080,...
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
Need to tune in Philips Tv 14pv284/05 lost manual
If you're trying to scan for channels, this option should be found in your menu. I am not sure what your menu looks like, but usually there is a "Channels" setting in your menu. You can then select "Start Scan" or "Scan for Channels." You might also look for anywhere that says "Initial Setup" or somewhere in the menu that says "Add/Remove Channel." For some reason, Philips does not allow you to look this model up on their website. If you can't figure out the menu you should try calling Philips customer support.
LCD Television (2008 and newer)
1-866-771-4018
Televisions (purchased before 2008)
1-866-310-0787
May 01, 2011 | Televison & Video
My screen is blue. says cable. i dont have cable and cant get the tv to do any chanel.
What is the make and model of the television? If it has a HDTV off air decoder then you can try this....A little trick i learned years ago. Get a paper clip and bend it into an "L" position and then insert that into the very center of where the cable goes into and then scan for off air channels. You will know if this is working when it says it found "x" amount of channels as it is scanning thru the channels. Give that a try and see if that at least gives you a picture... IF that works then you can get off air signal HDTV for FREE. And you might want to invest in a HDTV OFF AIR ANTENNA.. For free tv. Let me know how that works for you and then we can go from there. Good luck and have a great afternoon. SINCERELY HDTV GURU JAY
Mar 15, 2011 | Televison & Video
I forgot how to use the remote one for all urc 7544 i need to set a elsat decoder
Remotes
Nov 24, 2010 | One For All URC 7740 Remote Control
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
May 17, 2010 | JVC LT-37E478 TV
I have a Regency Touch K 100 ( NO MANUEL ) Scanner
I have searched like crazy and cannot get you a specific answer. I found the Manual for sale on eBay in PDF format.
http://cgi.ebay.com/Regency-Touch-K100-Scanner-Manual-PDF-File_W0QQitemZ150385008548QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item2303a51fa4
For $5 it might be worth it.
For all of your scanner needs: ScannerMaster
Nov 17, 2009 | Radio Shack Radio Communications
I have a phillips plasma tv. model 42pfp5532d/05. i canot tune in the digital channels. what do i need to do ?
to get digital, you need to do the autoprogram or channel scan.. then it will find them and add them to your channel. point your antenna toward your towers and re-scan the channels. if you want digital cable, you need a cablecard (where applicable) or cablebox to decode..
Feb 18, 2009 | Zenith P42W46X 42 in. Plasma EDTV
Unable to get digivox-t to find channels on chorus.
chorus 00:CE 19 2E 87 80 61 74 90 01:62 FA D9 F3 CE 05 FA 79 new codes
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
No OTA channels
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
Oct 03, 2007 | JVC HD-52G886 52" Rear Projection HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
