Question about Sony BRAVIA Televison & Video
Sony bravis xbr 6 blinking lights
Wont turn on not overheated
    Top Expert:
  • Sony Master
  • 54,195 Answers
Open internal fuse or power supply failure
Posted on Jan 23, 2019
6ya staff
SOURCE:
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
Anonymous
  • 6 Answers
SOURCE: SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Posted on Dec 29, 2007
Cybertech
Jose Zetino
  • 149 Answers
SOURCE: Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Posted on Apr 08, 2008
Anonymous
  • 44 Answers
SOURCE: sony kds 50a2000 power light blinking
Your lamp has blown. You can order the lamp from Sony and replace it yourself. You can purchase the lamp here:
http://www.sonystyle.com/webapp/wcs/stores/servlet/SearchCatalog
Other vendors also sell this lamp at a cheaper price (check the net)
Posted on Jan 02, 2009
1860ph
  • 30 Answers
SOURCE: My sony TV wont turn on.
Un plug and let stand for one minute. If it still does blink then use the reset on the remote and press it while pressing the power button on the TV.
Posted on Feb 07, 2009
Sony xbr KV-34xbr910
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Apr 06, 2014 | Televison & Video
Why does my Sony Trinitorn xbr not turn on and flashishs stanby?
It is shutdown, protection. See if the light blinks a specific number of blinks, pause and repeats the number of blinks= that would be a error code.
A model number would be helpful if it is blinking a error code.
May 26, 2012 | Sony Televison & Video
Sony trinitron xbr (9 years old) failing to power up
Turn it off u leave on to long ur CRT Tube will dies soner.Resolder the FBT,the flyback transformer, the big block of plastic with a red wire with a cap hook to the and the transistor beside it.This transformer is the HV to the CRT to get power.
Jan 15, 2010 | Sony FD Trinitron KD-34XBR960 34" TV
My sony xbr 60 picture turns off and on
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
Nov 07, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
KDS R60XBR1 Red Light blinks 3 times when turning
on my xbr tv there is a little *** that sticks out on the lamp cover. the wrapped and it wont work light flashed 3 time with a new cover it worked fine. there was a t. s. b. for an over heat problem new fan and sensor and door. go to sony.com its there
Mar 22, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sony Trinitron XBR, Stand By Mode?
Generically, the 6 or 7 blinks usually indicate a problem with the horizontal circuit. In order to provide accurate diagnosis and suggested solutions, the exact model number is needed. Please update this with tha number and I will post more details.
Thanks,
Dan
Mar 18, 2009 | Televison & Video
The 6 or 7 blinks usually indicate a problem in the horizontal circuit. Since the TV recovered once, the problem is most likely to be a bad solder connection in that area. If you can solder, resolder any connections on the board that appear grainy or have rings. That may resolve the problem. If not, update this and we'll look elsewhere for defective parts.
Dan
Sep 16, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Televison & Video Logo
62 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
