Question about Sony BRAVIA Televison & Video
How do I turn off closed caption on a sony bravia tv
    Top Expert:
  • Sony Master
  • 52,423 Answers
Go to the initial set up procedure and disable it.
Posted on Feb 14, 2019
SOURCE:
mistersony
  • 320 Answers
SOURCE: closed caption
There are external close caption boxes that you can add to your system. But be aware: many cable boxes do not process the close captioning information "through", forcing you to use the close captioning on the cable box.
Posted on Oct 19, 2008
mistersony
  • 320 Answers
SOURCE: Closed Caption on Sony Bravia
Try a master reset on the TV. With the TV powered on, prss and hold down the up button on the remote (there are 4 buttons grouped together for up down left and right) and while holding down the up button, press the power button on the TV. The unit should power off and then turn back on and ask you to select a language. Let me know if this helps and be sure to rate this solution. Thanks!
Posted on Nov 11, 2008
SOURCE: Sony Bravia KDL-46Z4500 Captions
Try pressing the 'Display' button on top left of TV remote.
Posted on Feb 03, 2009
  • 59 Answers
SOURCE: Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Posted on Jun 08, 2009
  • 197 Answers
SOURCE: Closed Caption not working on my Sony 40" Bravia LCD TV (KDL-40
turn cc on receiver
Posted on Jun 09, 2009
How can I turn off CC on my SONY 52XBR. I used the Remote control settings and selected off on the cc display, but the cc never turns off. I also used the menu button on the side of the T.V to select
If Closed Captioning is being displayed even though the CC option in the TV menu is set to Off , then it is being produced by another device, such as a cable or satellite set-top box. To remove the Closed Captioning from the TV screen, it must be disabled on the device that is decoding the Closed Captioned signal.
NOTE: Some set-top boxes may automatically display Closed Captioning on the TV screen when the set-top box sound is muted. If this is the case, turn off the Mute function of the set-top box
Oct 31, 2014 | Sony Tv Xbr Bravia Kdl-52xbr5 52 Lcd Tv...
How to remove closed caption on Sony Bravia TV
Check the menu of set and a box if used--both usually have that feature.
In menu look for closed captions (CC) and turn off--settings may exist for leaving it to only come on if sound is muted.
Do not if using a box for signal overlook that also having the same feature.
May 31, 2012 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Sony Bravia KDL-32XBR4, closed caption turned on and being displayed. We wanted to use the "display options" to make the closed caption bigger. The "this is how it will look" looks...
Go into the tv menu again,Go to"Display Options"closed captioning u pick captioning bigger for as a default,but did u push the button on the remote said Enter?Press the enter button for the defualt caption will see the left side of the tv captioning default u want.Now the if u,used the CC button.U will get the bigger bold matalic captioning u want.
Nov 24, 2010 | Sony Televison & Video
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Cannot lose close captions from screen even though it has been turned off at the menu. Any suggestions?
Check the caption settings in the menu for your video source, (cable box or satelite reciever), the signal could be originating there.
Dec 04, 2009 | Sony BRAVIA KDL-32S2010 32 in. LCD...
Nov 11, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony 46" XBR2 Cannot turn off closed caption
With TV on, turn off DVR and hit menu on DVR remote - you can disable CC from there.  Worked for us - got the idea from another fixya post.
Jul 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Closed caption
Dec 02, 2007 | Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD...
Televison & Video Logo
152 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
