Question about RCA 36V430T 36" TV
Cant get closed caption feature back
I take care of an 87 year old lady who has a beautiful old zenith floor model console in a gorgeous wooden cabinet. She does not hear well & uses the closed caption feature to watch tv. Recently she went into the hospital & in her absence from her home, somehoe the closed caption feature was disabled & I am unable to get it back for her. I tried with her remote, but no luck,can you help us? Thanks! Lela
  • gocit Dec 06, 2007
    I have SONY KV-27FS13, Flat CRT TV,
    I can't have closed caption feature to work.
    I have done: I set up from the menu>Set up>Closed caption on CC1
    Please help me
    Thank you
  • Deborah J May 11, 2010
    i have a wide screen floor model television and i amtryin to set up the cc for a friend and for some reason i cant get it to work? help
I prayed to God for help & it worked!
Posted on Jan 25, 2008
I prayed to God to help me fix the closed caption problem, then sat down with the remote & started pushing buttons. In a few minutes, the closed captioning was back & I have NO IDEA what I did that fixed it, other than ask for DIVINE help!
Posted on Dec 27, 2007
Closed caption on
Posted on Dec 26, 2007
SOURCE:
How do I fix, and is it worth it, to repair the cassette mechanism I think on Zenith MC 6190. Machine is otherwise pristine. Purchased new back in the day...
Most likely a belt or belts have broken. That would be an easy repair, but unless you want to use it for cassettes, I wouldn't bother. Value pretty much nil.
Aug 12, 2015 | Audio Players & Recorders
Need a manual for this machine which belongs to an 87 year old lady?
well Anne since we have not the honor of make,model google them and add manual see if there is one to download for her
Mar 17, 2015 | Sewing Machines
I have a very old wooden china cabinet that smells bad. How can I improve the small without keeping the glass open at all times?
My grandmother has the perfect method for getting the old woodsmell out of her china cabinet. First,you crumple up newspaper and put it between the plates for 24 hours. Supposedly, newspaper sucks up scent. The next day, place a water bottle cap filledwith vinegar on each shelf. After 24hours, the bad wood smell should be gone. To get rid of the vinegar smell, place a water bottle cap filled withvanilla extract on each shelf. Leavethat in there for 2 to 3 days and you should have a beautifully smelling chinacabinet!
May 29, 2012 | Furniture
Need instruction book for older model 2826
Try Googling (invicta)(2826)(manual) without parens.
Aug 22, 2017 | Watches
Whirlpool washing machine 6alsr7244mw3 always out of balance in spin cycle. Machine balanced/level on concrete floor and doesn't matter what size the load is, in it.
A very common call I get on Whirlpool built direct drive washers, and one of very few problems they have, is that the machine vibrates like it's out of balance when spinning even without any clothes in the basket. Sometimes it'll walk across the floor if this is allowed to worsen.The cause is nearly always support pads. The entire mechanism rests on these three small plastic pads, and when they wear even a little bit, the machine will vibrate like crazy in spin, like its load is badly out of balance. Replacing these pads (part 285744, around 10 for the set will nearly always correct this problem. And they aren't hard to replace if you re just a little handy Here s how Unplug the washer. Remove the 2 Phillips screws that retain the console. On some machines, these are hidden under console end caps that must be pried off. On newer models they re on the back of the console Rotate the console fwd then up and back it will hang back out of the way if the washer s away from the wall far enough.Unplug the white lid switch plug and pry up the 2 large clips that hold the cabinet to the washer back panel.Tilt the entire cabinet forward and it ll unhook from the retainers on the base. Lift the cabinet off and set aside (not as heavy as it sounds With the cabinet off you ll see 3 large horizontal springs, one in each corner of the support 'tripod and one smaller, vertical one in the left-rear that counterbalances the motor's weight. Unhook all 4 of these springs and insert a small piece of 1 by (5 8 or 3 4 thick) board to prop the mechanism up, to access the pads one at a time. Insert the piece of wood between pad locations, on a side of the support triangle a helper's handy here Use a little lighter fluid to clean the mating surface of the support plate that these pads ride against before inserting each new one. Be careful not to scratch the support plate when working under it it needs to be smooth and contaminate-free. Knock the old pads out one at a time, by lightly tapping on their mounting pins from underneath with a hammer. Put each new pad in place in its mounting holes, carefully remove the wooden 'shim then stand up and push down ******* the tub on that corner. You ll hear and feel the pad snap into its mounting holes.Repeat this process for each of the other two pads mounted on the support tripod' (do the rear, 'fun' one last after you have experience replacing the other two and your washer will behave a whole lot better in the spin cycle. And if you have any trouble finding these support pads locally, let me know. I keep lots of them in stock. You can order a set here Oh, and remember to reach around and pat yourself on the back! You just saved yourself at least 100.00
Oct 25, 2011 | Whirlpool Washing Machines
I have an old (over 15 years) Zenith TV that I don't really want to get rid of. It is a console model in a very nice wooden 'case' on a swivel base. It's a very lovely piece of furniture. The TV has seen...
Have you tried to contact Zenith? They have a small office in Lincolnshire, Illinois I believe. Mabe you could get some info from them. They are now owned by LG (Lucky Goldstar)
Hope this helped you out. louie12fix on fixya or lmistyrel @aol.com bye for now.
Sep 17, 2009 | Televison & Video
Zenith 5R688
1852. Just after the birth of Nepoleon.
Apr 10, 2017 | Zenith XBV443 DVD Player/VCR
Parts for sale
booyahbaby.com has gorgeous stroller liners which fit many different stroller brands. I have a 20 year old Emmaljunga stroller & their liner fit my stroller beautifully.
Apr 10, 2008 | Silver Cross Durham Stroller
Redirect please: COLORTRAK 2000 - WORKS OK, Very old
John,
They say " beauty is in the eye of the beholder " ! At times,
I have older customers that want wooden floor models,but it
is a rare request.......older sets generally are not compatible
with modern equipment, therefore they have very little actual value or merit............if you could get a few dollars and the
recipient of the old-timer is satisfied...that's the ticket !!
Dec 20, 2007 | RCA 13R400TD 13" TV
RCA 36V430T 36" TV Logo
167 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
