Question about Hoover Washing Machines
My Hoover Optima will not spin. It drains but will not spin with or without clothes in it. I've checked the filter Can you help me please
SOURCE:
  • 108 Answers
SOURCE: No draining on washing machine
I am not an expert on hoover - mainly hotpoint...but..
To empty your machine of water reset the programmer to Final spin. the machine should empty normally.
On hotpoint if you have a fast flashing light its most likely to be 1 of 2 things.
1. The belt from the motor has broken. (price for belt is less than 20 pounds.)
2. The brushes in the motor have worn down too much to make the drum turn. Look underneath the washing machine to see if black power (Carbon) is deposited under the motor.
(Price for set of brushes is less than 20 pounds)
Labour should be no more than half an hour by anyone decent.
Regards
Posted on Feb 22, 2008
ginko
  • 19396 Answers
SOURCE: hoover nextra optima HNL 6166
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
Posted on Oct 16, 2008
  • 135 Answers
SOURCE: water not draing away and machine is not spinning
Empty your machine manually by lowering the drain hose into a bowl or bucket. Then remove the kick plate and check the filter for blockages.Before replacing try the machine on drain to see if the pump is running, if problem persists there may be a blockage in the pipe from the drum to the pump.
Posted on Nov 15, 2008
  • 9 Answers
SOURCE: how to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Posted on Jul 19, 2009
  • 41 Answers
SOURCE: hoover 600mb doesn't spin
Valve blocked in rear of drum. Switch off power supply before cleaning. If the problem still occurs it could possibly be the brushes in the motor. both jobs are simple and very cheap to repair
Posted on Sep 03, 2009
My hoover optima washer drains but won't spin. Help
I would suspect the timer contacts are burnt .
Mar 04, 2015 | Hoover Washing Machines
My hoover optima 7 kg 1400 aaa will not go into the spin mode ?
drain pump needs to be replaced, washer needs to be empty then will spin. please comment.
Dec 03, 2014 | Hoover Washing Machines
Whirlpool awo d 4305 s draining problem clothes left soaking
Ok, replaced waste pump - slight improvement but clothes still bad... only just seen your solution Mike!!! I didn't even notice a spin control board there, I will check/swap it tomorrow as I've only just put everything back in place(incl. kitchen cupboards etc!).
Is this a common problem with this model?? There's a mountain of appliances near where I work and I'm free to take whatever I can find, I'd say some people just buy a new machine without even checking if the filter's blocked looking at some of these appliances!
Thanks all!
Aug 22, 2012 | Washing Machines
My hoover 1200 express washing machine will not spin - how do I check the filter is not blocked?
Hi jacqui wa33,
Please follow my Tip below, for detailed directions on how to access, drain 7 clean your Drain Pump Filter (Please Note: Your filter is located Bottom Left corner):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Hoover optima machine stopped mid cycle full of water. It will not drain
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Apr 01, 2011 | Hoover Washing Machines
Hi there, i have a hoover elite 1220 i think 7.5kgs i brought it second hand of ebay and it has been a good machine but it has started to play up lately. It washes all on the normal cycles and stuff i...
Following will be the causes for water not draining properly
1.There is a motor/Pump which operates to to drain the water check whether that motor is working.
2.Check filter and clean it
3.Check the drain pipeline whether it clear
4.Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
Sep 02, 2010 | Hoover HTC243 Top Load Washer
My hoover 540 washing machine started making funny noises a couple of loads ago (loud banging noise during spin cycle). Now it goes through whole cycle but when it gets to 'drain' part of the cycle,...
Sounds like a blockage in the outlet pipes or filter. It may be possible to drain it if you can get the outlet pipe (one from back of machine) outside, lay it flat on the ground as this will take it below the water level in the machine and may slowly drain. Once it drains out enough the machine should disengage the door lock to allow you to open it. Then check your filter and pipes for blockage. If no blockage is found then suspect faulty pump.
Jan 25, 2010 | Washing Machines
Water not draing away and machine is not spinning
Nov 15, 2008 | Hoover Nextra HNWL 3136 Front Load Washer...
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
